DTC P185800 & 1858-002??? - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 11-03-2014, 08:45 AM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 5 Post(s)
Currently only P0170.
A pending P0173 comes in after several days. After making a change, I clear the DTC's, maybe that's not the best way to go in this case.
Seems to me the P0170 started after replacing the Bank 1 ,#1 , O2 sensor... I ordered another one and will swap that out. If that doesn't address the issue I will have another spare I spoze.
4.9V and 11.6V at the MAF. Cleaned contacts while I was there.
Fuel pressure holds (ign off) for 30 mins solid.
Loking for next logical steps. I appreciate the knowlege share.
Alex
Halexb is offline
post #12 of 18 (permalink) Old 11-03-2014, 09:22 AM
Motivational Poster
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Quoted: 333 Post(s)
Where did you order your MAF sensor from? Source?
There's a LOT of fake MB parts turning up. I've been bitten myself from knock-off Chinese parts that do not perform. Advance Auto has been getting these fakes which is where my CPS came from. Compare the markings on your new MAF to the one you removed. Look for suspicious molding lines, erratic writing where 'Bosch' is, etc. If your MAF sensor is good, then it has to be a leak somewhere.
2005 S430 4Matic 'Morton' W220.183 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #13 of 18 (permalink) Old 11-03-2014, 11:51 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1544 Post(s)
Alex
I think the entire problem here is you changed O2 Sensors in the belief that changing them would fix codes P0170 and 173.
If you still have the original O2 sensors, reinstall them and go from there.
Also tell us where you got them.
43sqd is offline
post #14 of 18 (permalink) Old 11-04-2014, 10:50 AM Thread Starter
Quoted: 5 Post(s)
Sensor #1 bank 1 purchased from Parts Geek.
I'll swap it out with the original.
New one is on order from AutoParts Wharehouse (ordered it a couple days ago during "fishing" expedition.)
I'll try to capture the "new" O2 sensor data on my mighty i980 and compare with original.
As usual, Ich bedanke mich.
Alex
Halexb is offline
post #15 of 18 (permalink) Old 11-10-2014, 10:33 AM Thread Starter
Quoted: 5 Post(s)
Swapped out the O2 sensor with orig.
Same codes P0170.
Removed the intake manifold using the info from this site (thank you very much!).
Found ughliness:
Cleaned up everything as best I could.Replaced throttle body gasket, intake manifold gaskets, injector o-rings, EGR gasket, ensured good vac hose connections and re-assembled.
I cycled the system (drove it from cold to warmed up) 5 times.
No MIL.
Passed California smog test!
Drove it 825 miles in 2 days (to and from racing in the desert) and got 26+ MPG as best average.
Musta had an intake leak under the manifold?
Now I have enough spare parts to do this job again...
Thank you all for the tremendous amount of information and support.
Alex
Halexb is offline
post #16 of 18 (permalink) Old 11-10-2014, 01:26 PM
Great job. You found it all by yourself, as you went the extra step.
43sqd is offline
post #17 of 18 (permalink) Old 11-10-2014, 02:44 PM Thread Starter
Quoted: 5 Post(s)
Thanks 43sqd but W/O you and the other contributors I never would have gotten there.
Happy motoring.
Alex
Halexb is offline
post #18 of 18 (permalink) Old 03-14-2018, 08:32 AM
Date registered: May 2014
Vehicle: 2005 ML350
Quoted: 9 Post(s)
Hi Alex,
Can you post the link to repairing(DIY) the intake manifold.
Thanks for you help.
Chris
3815Kauai is offline
