I'm still (as weekend time permits--sigh!) hunting a loss of oil. Have the many other suggestions, but at this point I'm trying to understand the oil filter/oil cooler seals and I've read enough posts to completely confuse myself. My 2002 ML320 does not appear to have a cooler like is show in Detane's DIY or the .pdfs. See pics--there's nothing to the right (passenger's side direction) of the oil filter housing--the upper coolant hose dives into the engine block there. I've also seen references that say the cooler was dropped after engine #30-0331040; if I believe the Russian VIN decoder site my engine is 112942 31 053011. So I don't think I have the cooler. Correct?
But what was done instead? Do I still have seals somewhere where the housing attaches to the block or front cover? It seems like a one-piece casting, but there might be something going on in the back that I'm not spotting.
As 43sqd pointed out, no cooler. Drain the oil, take the filter out and you will see a nut at the bottom of the filter housing. You will need a thin walled 46mm socket. One gasket to replace after its removed between the oil filter housing and the block. Not sure of part number right now but only purchase from the dealer.
As 43sqd pointed out, no cooler. Drain the oil, take the filter out and you will see a nut at the bottom of the filter housing. I believe it's 43mm but not sure. One gasket to replace after its removed between the oil filter housing and the block. Not sure of part number right now but only purchase from the dealer.
Wow. I'm still not seeing the split line, but it makes sense that there's a bottom seal even if there's no oil cooler. 46 mm--will any non-impact one do, or is there a particular thin-wall that's thin enough?
OK, I hate to go against the wisdom of this board, but I think there's no cooler and also no oil housing seal on the bottom. I don't see a nut (picture) nor any split in the casting. It certainly doesn't look like bula's diagram above.
For future reference, this is an early build (bought in Sept 2001) 2002 ML320. Many catalogs, including the Mercedes one (used by dealer sites and parts.com) show a cooler, side seals, and a bottom seal for 2002 and V6 engine in both the listings and the diagram. One or two put the caveat about engine number on it (which I doubt is even relevant in 2002); the dealer catalog does not.
I'm having an issue with an oil leak on my 1999 ml320. My oil filter housing looks just like yours. Did you have a leak other than the timing chain expansion plate, Does it have a oil filter housing seal? Please help.
To settle this debate, only the very early 6 cyl. ML's (1998 and early 1999) had the oil cooler. Then it was discontinued and only installed on 8 cyl. models.
Note that the installations were based on engine numbers, not vin #'s.
I think this only aplies to the USA. My engine number is 30 465424 and looking at ebay you get the same result. Even upto a 2002 320. Like i have said i don't think i have seen a 320 in the UK without an oil cooler.
The epc you get 43 in the usa is different from the pc based most use in the EU. Mine tells me if its not for my build model and does frequently say USA ONLY. My vehicle started life with an american vin as found on a sticker behind one of the rear panels and was converted to wdc163154 as an export. If i gave you my usa vin your system would probably have all the info.
Agree--try to locate it if you can. In my case I had a gradual loss, but could absolutely not see any sign of it at the little timing chain cover plate. I was suspicious it was in the front, but that may have been residual from the valve cover leak. I've replaced the gasket at the intake pipe in the rear of the engine; currently monitoring the level to see if that did the job.
Thanks! The oil leak was coming from the area of the oil filter housing seal or timing chain cover plate. I changed the timing chain cover plate and seal. The leak seems to be gone. I had already purchase the seals for both repairs but when I realized that my oil filter housing was not removeable, I wanted to make sure that I wasn't missing anything.
Mine is 99ML320 also and it doesn't seem to have separation on the filter housing. I looked inside the housing and it doesn't have the big bolt that fits the 46mm socket.
