Removing the passenger seat of 2000 ML320 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-04-2011, 11:48 AM Thread Starter
Date registered: Feb 2009
I am trying to remove the passenger seat of a 2000 ML320. I have a built-in lock box that makes access to the underside of the seat tight.
My question - I need to disconnect the wiring from the seat obviously before removing the seat. It feels like there is just a push in tab on each short side of the connector. But pushing these tabs and pulling and trying to wiggle the connecor does nothing.
I can not actually see under there at all. I am just totally clueless about it just being a simple connection that should just pull off? Or do I just need to pull harder? Thanks for answering just a basic question.
katietsu is offline
post #2 of 4 (permalink) Old 09-04-2011, 12:06 PM
Vehicle: 2002 Mercedes ML320, 132k
Quoted: 8 Post(s)
Darn--I've done the driver's seat, but now I don't recall the connectors. If you can look at the ones under the driver's side more easily, I think they're the same type. You should also have enough slack to unbolt the seat and tip it a little for access.
rocketman4321 is offline
post #3 of 4 (permalink) Old 09-04-2011, 01:10 PM Thread Starter
The lockbox blocks the view connections even with the seat tipped up. All I can make out is that it is a large black rectangle.
katietsu is offline
post #4 of 4 (permalink) Old 09-04-2011, 01:14 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Quoted: 2 Post(s)
The clip (large black rectangle) you see push's to one side or the other, at the same time it slides it will disconnect the connector. You will have to remove the four place connector that is contained within the slide lock first. I think it was blue or red on that car.
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
Removing the passenger seat travis04240 W201 190-Class 5 11-23-2009 07:23 PM
Removing Passenger Seat netdvn W210 E-Class 16 07-09-2008 04:21 AM
Removing Passenger Seat! momomo W202 C-Class 2 03-15-2008 07:14 PM
Why is removing the driver's seat not like the passenger seat? Halfwise W123 E,CE,D,CD,TD,TE Class 12 10-22-2007 08:48 PM
SRS Light - Need help removing passenger seat avikanal General Mercedes-Benz 0 07-08-2007 10:05 AM
