w163 ML270 cdi abs pump - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-28-2011, 06:04 AM Thread Starter
Date registered: Feb 2011
Vehicle: 2001 ML270 cdi
hi, i need your help. my ABS pump for my 2001 ML270 cdi is busted, no brake fluid is pumped out on one of the holes from the silver metal box of the ABS pump.
The part number of the unit is A1634310712, problem is I am having a hard time looking for the exact part number. would anyone know if other part numbers would work with my car? will an ML320 ABS pump with the same year work on my car?
I am from the Philippines and the car was originally an import so I am having a hard time looking for parts here. If anyone could help, I would greatly appreciate it, I couldn't use my car for more than a month already. thanks
gjo507 is offline
post #2 of 12 (permalink) Old 03-28-2011, 06:15 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 828 Post(s)
Post your VIN number.
Some owners ware successful repairing pump motor.
https://www.benzworld.org/forums/w163...light=ABS+pump
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 12 (permalink) Old 03-28-2011, 06:21 AM Thread Starter
thanks for the reply,
my chassis no. is WDC1631131X739739
I had been searching these forums for almost a month already, and honestly read most of the articles regarding ABS pump, even tried some of the suggestions like resoldering the circuit board, but to no avail. it really seems that the mechanical part of my ABS is the busted one and not the electrical part.
I did a test on the 4 holes on the silver metal box connected to the 4 tires. I bled the brakes and loosened the 4 knots on the metal box, 3 of the holes emitted fluid except for the one problematic one.
gjo507 is offline
post #4 of 12 (permalink) Old 03-28-2011, 07:43 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 828 Post(s)
What kind of problem are you having?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #5 of 12 (permalink) Old 03-28-2011, 07:55 AM Thread Starter
As stated on my previous post, there is no brake fluid coming out on one of the holes of the metal box of the ABS pump, which specifically leads to the rear, left tire. As a result, my brake system is not working, and the brake pedal is down straight to the floor. The motor of the ABS Pump is working bec. 3 out of the 4 holes, there's fluid seeping through and when I bleed the from the 3 tires connected to those 3 holes, there's fluid coming out.
The part numbers of mercedes is so confusing and wondering maybe other part numbers aside from the one I posted would work. I kinda am giving up on trying to repair the unit anymore.
gjo507 is offline
post #6 of 12 (permalink) Old 03-28-2011, 08:27 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 828 Post(s)
Hydraulic unit with pump. Part number 004 431 04 12. $1940.00 MSRP. Fits all ML up to 2002.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 12 (permalink) Old 03-28-2011, 08:37 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 828 Post(s)
Witek_M is offline
post #8 of 12 (permalink) Old 03-28-2011, 08:45 AM Thread Starter
Great. Thanks. Will check those out.
gjo507 is offline
post #9 of 12 (permalink) Old 03-28-2011, 01:56 PM
Purple Moderator
Date registered: Jul 2005
Quoted: 1495 Post(s)
It is a shame parts.com does not ship overseas. The MB OEM part is $1350 their.
If you have a friend or family member in the US you can get it that way.
Noodles is offline
post #10 of 12 (permalink) Old 09-02-2011, 08:10 PM
Date registered: Sep 2011
My left front tire blew while driving today prompting my ABS light to come on. It now stays on while driving. I drive a ML320.
Thanks
Last edited by lawrence Nwolisa; 09-02-2011 at 08:19 PM. Reason: Added model of vehicle.
lawrence Nwolisa is offline
ETS ABS EPC ML270 CDI 2003 eviebo W163 M-Class 2 12-23-2010 05:40 PM
w163 2001 ml270 cdi tiptronic auto 5 speed mercsl320 W163 M-Class 1 04-19-2010 04:55 PM
Carlsson C-Tronic ML270 ( W163 ) Haydn W163 M-Class 0 12-01-2009 10:10 AM
ML270 / W163 Window mechanism BriBar W163 M-Class 3 11-13-2009 05:37 AM
ML270 CDI Year 2002 ABS and ETS light jonastra1 W163 M-Class 4 09-21-2007 06:27 AM
