Parking Brake Doesn't Hold - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-03-2010, 07:20 PM Thread Starter
sayporsha's Avatar
Date registered: Jun 2005
Vehicle: 2000 ML55 AMG
Actually, it does now but I wanted to post pictures of how I fixed it. It was clicking but not holding. I searched this forum & found factory diagrams of the parking brake assembly but I still couldn't tell what was supposed to make it hold so I took it out to see.
First, remove the plastic panel above the pedals. Remove the two 13mm bolts holding the pedal assembly. One is hidden inside the large round bore in the pivot. Unplug the switch. Use screwdrivers & pliers to remove the cables. Work carefully so you don't break the plastic cable ends.
You know that clicking sound it makes? It's just a noisemaker and does nothing to hold the pedal in position. Here's a picture of it. Mine is held in place by a dab of silicone because the tip of the plastic clip broke off:
So what holds the parking brake? A clutch in the form of a slinky-like spring wrapped around a drum:
In this pic you can see both ends of the clutch spring. On the left it is clamped down to hold the tension around the drum. On the right it contacts a lifter arm that releases the tension and the clutch's grip on the drum to let the cable pull the pedal back into position (parking brake off):
Here's the end the spring before re-tensioning:
To re-tension the spring, move the pedal to the fully depressed position, loosen these two T-40 torx bolts, pry the spring down to snug the spring around the drum & tighten the two bolts. A bench vise is helpful:
Here's the end of the spring after re-tensioning:
Before installing the pedal assembly, get under the car & turn the eccentric in the attached .pdf instructions fully counter-clockwise. This resets the automatic cable adjuster. It's in the tunnel, above the front of the driveshaft. You get one chance to pull the cable & attach it to the pedal because releasing the cable turns the eccentric to take up the slack. If you are unsuccessful attaching the cable to pedal, get under the car again & reset the eccentric.
I hope this information is useful. This forum has helped me a lot, so I wanted to give something back.
Jeff
~ 2000 ML55 AMG Bordeaux Red/Charcoal
~ 2006 Porsche Cayman S
~ 1973 V8 Vega (where it all began)
sayporsha is offline
post #2 of 2 (permalink) Old 10-04-2010, 10:12 PM
Purple Moderator
Date registered: Jul 2005
Quoted: 1482 Post(s)
I found that out the hard way and ignored the step about the pre-load.
Had to do it again the right way.
Noodles is offline
ABS, ESP,ETS brake, parking brake lights, no auto-shift, speedo to zero mwaarle W163 M-Class 16 11-28-2015 03:21 PM
Parking Brake light on despite parking brake not being engaged jckazz333 W163 M-Class 6 04-29-2010 09:15 AM
Left turn= brake fluid and parking brake light? MLROSS W163 M-Class 3 11-22-2008 10:40 AM
A parking brake, a parking brake, my kingdom for a parking brake!!! Capt.wrongway Unimog 10 10-04-2006 12:30 PM
Problem Fitting Rear Brake Disc Rotors over Parking Brake Shoes? Guest (MBNZ) W124 E,CE,D,TD Class 7 04-03-2002 08:22 AM
