C1401 ABS/ETS/BAS lights come on randomly - Page 36 - Mercedes-Benz Forum
post #351 of 354 (permalink) Old 06-25-2019, 08:45 PM
Firewater's Avatar
Date registered: Jan 2009
Vehicle: 1985 500 SEC EURO AMG/LORINSER; 1988 560SEL, 1995 S500 Sonderschutz
Quoted: 200 Post(s)
Originally Posted by WE47B1ME View Post
A gazillion diy's on the forum here. Use the search function. It's easy. (To use search and replace the brushes ). Bust out your soldering iron.
Sent from my BlackBerry Key2 using Tapatalk
Crawl back into your hole you blackberry using, moron.
For Posterity:
The brushes pull out of the bottom of the brass sleeve when you trim the copper shunt. When installing the new brush, thread the copper shunt through the bottom of the brass channel and through the first two coils of the spring. Illustrated well here in this video:
Firewater is offline
post #352 of 354 (permalink) Old 06-25-2019, 08:48 PM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 232 Post(s)
For Posterity:
The brushes pull out of the bottom of the brass sleeve when you trim the copper shunt. When installing the new brush, thread the copper shunt through the bottom of the brass channel and through the first two coils of the spring. Illustrated well here in this video: https://www.youtube.com/watch?v=cFYF7TnWfRE
Cool.
WE47B1ME is offline
post #353 of 354 (permalink) Old 06-25-2019, 09:06 PM
Date registered: Dec 2011
Vehicle: 2000 ML 430. 2007 Landrover D3 3.9L. 1976 Bristol 411
Quoted: 27 Post(s)
How do you replace the brushes inside the motor? I do not believe that you have to pry on the brass housings. Correct?
Correct. I removed the bearing so that you could take the plastic cap off. I cut the original copper braid going to the old brushes and slid the brushes out. I soldered the new copper braid to the stub of the old braid. See attached photo.
You need quite a small, fine bearing puller to get that bearing off. I bought the smallest one I could from my local tool shop then ground the ends of puller arms so I could get them behind the bearing. Before pulling the bearing, measure from the end of the shaft so you know where it needs to be when you put it back on.
nivekau is offline
post #354 of 354 (permalink) Old 06-26-2019, 02:08 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 807 Post(s)
For Posterity:
WTF!!
mattml430 is offline
BAS, ASR, ABS Lights on, w/C1401 code tiffe320 W210 E-Class 29 01-29-2015 11:16 AM
BAS/ETS/ABS lights... Daniel W163 M-Class 10 12-23-2012 07:51 AM
ABS,ETS,BAS lights came on?? soulsociety714 W163 M-Class 12 03-20-2011 03:51 PM
BAS/ESP,ETS,ABS lights all on zmanzbo W163 M-Class 38 12-01-2009 09:09 PM
ETS, BAS, ABS lights ON!!! bcaese W163 M-Class 7 08-12-2009 04:37 AM
