No FM Radio Volume - Mercedes-Benz Forum
post #1 of 45 (permalink) Old 10-01-2009, 06:48 AM Thread Starter
boosoo's Avatar
Date registered: Feb 2004
Vehicle: 2001 S55 AMG, 2005 E500
No FM Radio Volume
My 03 ML500 has no FM volume. CD, NAV and AM work fine. I've pulled fuse 10 and 21 in hopes that would fix it. No luck. Any ideas?
boosoo is offline
post #2 of 45 (permalink) Old 10-01-2009, 06:56 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 897 Post(s)
So it's not volume issue but rather no FM reception. When using scan function does receiver stop on known FM stations in your area?
Please, update your profile with vehicle and location info.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 45 (permalink) Old 10-01-2009, 11:28 AM Thread Starter
boosoo's Avatar
No, it's volume. It does stop on known stations and you can barely hear (very faint) the sound if you turn it up all the way. Every so often it kicks in and is fine for a bit, but once you kill the engine and restart it is the same way.
boosoo is offline
post #4 of 45 (permalink) Old 11-01-2009, 07:18 PM
Date registered: Feb 2009
hi guys i have the same issue.
blah5 is offline
post #5 of 45 (permalink) Old 11-02-2009, 07:28 AM
Vehicle: Black 2005 ML 500
Quoted: 5 Post(s)
One possibility is the FM antena signal amplifier unit located in the rear hatch. Some people had problems with grounding and the unit failing.. There are some posts showing the location of it..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Yokohama Geolander HTS + Bi-Xenons(+ Drew's e-code mod, though the reflectors rusted off and do not give out much light anymore), Yakima roof bars, Akebono pads all around. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history. After all these years of owning my current 2005 ML 500, it is a major unreliable vehicle with a very large/expensive repair/defect history and has been like this since brand new.
AC_ML is offline
post #6 of 45 (permalink) Old 12-25-2010, 10:16 AM
Date registered: Feb 2006
Vehicle: 2001 ML320 4X4
Guys I have the same issue on my 2001 ML320. Any fixes yet?
Please let me know.
Thanks!
oalvarezjr is offline
post #7 of 45 (permalink) Old 12-25-2010, 08:24 PM
Date registered: Nov 2007
Vehicle: 01C240 gone; 02ML320 gone; 04E320.4M; 06 ML350
Slim chances that is the FM antenna amplifier: he has the stations but has very faint sound ...
Here is my experience, the CD on my HU stopped working about 10 months ago. Then, the FM gave up on me. I looked around to get it repaired, and I found this alternate solution on some other BMW forum.
“Jimmy Chen in New Jersey will do repairs for a fraction of the cost. Jimmy posts repair services as auctions on eBay for BMW and Mercedes. I called Jimmy and talked w/him about the problem with my display. He said it could be repaired for $180 and to mail a check for the amount and the unit to him.
Finding only limited posts/comments about him, and the fact that there is no physical business I was a bit suspicious. I searched a bit more and found some positive comments/threads on the web and decided to go for it. I mailed my display to Jimmy, and about a week half later (I am in California) I got it back.
I plugged it in and it works perfectly. So far so good!
Disclaimer: While my experiences may not reflect what you might experience, I am completely satisfied with his repair and service. I'll keep you posted as to the longevity of the repair.
In case you have this problem, here is his info:
Jimmy Chen
Alpine Electronics Repair
140 Hirshfeld Pl
New Milford, NJ 07646
Phone: 201-312-2317
email: [email protected] “.
Also, you should check the eBay # 180602808658.
In my case I wanted to get BT, iPod and NAV, so, I ended up with an aftermarket all-in-one HU that has LCD touch screen, tuner, GPS, BT, iPod, video, rear view camera, sat, SD card, USB, etc., for a total of ~$850 installed. I wish I would have done this swap four years ago. It’s such a difference.
athus3 is offline
post #8 of 45 (permalink) Old 01-24-2011, 05:24 PM
slik560's Avatar
Date registered: Aug 2007
Vehicle: 1999 Porsche 911 / 2013 ML350 / 2006 Mini Cooper S
Quoted: 29 Post(s)
Any other feedback?
Ironic that just today, the FM on the radio of my 2003 ML320 stopped working. No volume at all. All stations accounted for. The first time it happened, it came back on. After work when I started the car, no FM again. This time it has stayed off.
While I'm sure Jimmy Chen does great work, I wanted to try to find something that did not involve shipping the radio off somewhere.
My other issue with the whole setup is fluctuating volume.
I hate to take it to the dealer just for a radio issue. I'd rather put the money towards a new aftermarket unit.
Any help is appreciated.
Kevin
2013 ML350
1999 Porsche 911
2006 R53 Mini Cooper S
slik560 is offline
post #9 of 45 (permalink) Old 01-25-2011, 05:54 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1550 Post(s)
First check fuse #40 in the underhood fuse box, which powers up the amplifier. Then if OK..................
Your present problem (no volume) might be caused by the malfunction of the speed dependent microphone. Remove the rear view mirror and disconnect the connector to the microphone.
Then remove fuse #21, which powers up the radio and reinsert. You must make sure that you have your radio code available, or else you will have to call a M/B dealer to obtain it.
43sqd is offline
post #10 of 45 (permalink) Old 01-25-2011, 06:15 AM
slik560's Avatar
Quoted: 29 Post(s)
Thanks 43sqd
MANY thanks for the information. I plan to do all of these steps, but it's interesting that this morning when I started the car, the FM came on for about 3 seconds, then cut out. So, back to the CDs. Then while on the way to work, I hit the FM button again, and it was back. It stayed on all the way to work.
So, the problem now falls into the most dreaded category of issues: "intermittent".
Regardless, I will do what you have outlined and cross my fingers.
Kevin
2013 ML350
1999 Porsche 911
slik560 is offline
Radio Volume dahappybanana W163 M-Class 6 08-10-2007 05:57 AM
Radio Volume soluna Audio & Telematics Forum 0 06-28-2007 01:00 PM
Radio Volume mbfred R170 SLK-Class 11 05-29-2002 08:50 AM
radio volume Hope W163 M-Class 3 04-05-2002 11:11 AM
E320 Tape Volume vs Radio or CD Volume Guest (MBNZ) Audio & Telematics Forum 8 10-19-2001 08:10 AM
