Cup holder damping broken - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-19-2008, 03:48 PM Thread Starter
NewsHound's Avatar
Date registered: Mar 2003
Vehicle: ML320, ML500, S550V4, ML550
Quoted: 2 Post(s)
My driver side cup holder springs out with a bang, while my passenger side opens gently.
This link shows the cup holder installation procedure whicb I have followed.
Inside the cup holder opening on the left face there is a 0.5" diameter rotating gear which engages with the cup holder and seems to have friction enough to slow the holder as it springs out.
The gear is held from behind by two small black plastic tabs, but one of my tabs is broken causing the gear to misregister with the holder.
If I undo the two bolts lower down holding the parking brake lever I can almost pull the surrounding plastic dash out far enough to get to the gear to replace it, but the surrounding part is held fast at the top.
Can anyone let me know how to remove this surround?
The gear is not available as a part (only the cup holder assembly, $73) but I can fix it in place somehow if I can get to it.
Any help appreciated!
ML320 1999 M1, M2, M7 3rd row, Bose, Sunroof, Tow pkg, Fogs activated
ML500 2002 Sport pkg, M3 Convenience pkg, DVD Nav, Bose, VES, Sunroof, Tow pkg, Bi-Xenons
S550 2008 4MATIC, LWB, AMG sport pkg, P2, Pano roof, Premium leather, Rear seat pkg, rear/side shades, BT
ML550 2010 4MATIC, AMG Sport pkg, 20" AMG wheels, P2, Lighting pkg, Tow pkg, wood steering wheel
NewsHound is offline
post #2 of 3 (permalink) Old 08-20-2008, 06:01 PM
ML Precision's Avatar
Date registered: Apr 2008
Vehicle: 2006 E55: 1999 ML430; 2002 E430 4matic; 1988 190E 2.3; 1993 XL883
I never removed the surround, but it seems as though you remove the instrument panel.
https://www.benzworld.org/forums/w163...cessories.html
Originally Posted by 43sqd View Post
A few things should be considered before buying from ebay or the dealer. With ebay you would have to find 2 cup holders of the same color and if not you would have to have them painted. From the dealer they come color coded and they list for $78.
But wherever you buy them, remember that the procedure calls for the instrument panel to be removed in order to replace them, because they are bolted from the inside (3 screws on the early models and 1 on the late ones).
ML Precision is offline
post #3 of 3 (permalink) Old 08-21-2008, 06:05 AM
Date registered: Mar 2008
Vehicle: 2003 ML350, Trabant P60, VWJetta, BMWG650GS
in light of what's been said, see if this helps.
sergiu is offline
Cassette Holder to Cup Holder Conversion worrell100 R129 SL-Class 181 05-23-2014 11:58 AM
cup holder or sunglass holder help brianj1999 R170 SLK-Class 5 07-23-2008 06:49 AM
Cup Holder Broken - Where To Buy? vip W163 M-Class 4 03-18-2008 01:18 PM
Cup Holder!!! beno C208/A208 CLK-Class 15 03-31-2007 06:40 PM
cup holder Guest (MBNZ) W210 E-Class 1 08-08-2002 10:22 PM
