clunking noise in rear- differential? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 12-15-2007, 10:58 PM Thread Starter
ml3addict's Avatar
Date registered: Jan 2007
Vehicle: 05 ml 350 SE
i have noticed the last couple of days, when i am stopped and accelerate from a stop, there is a clunking noise coming from the rear wheels of my car...im pretty sure its not motor mounts, and have a feeling that its my differential slowly going...what are some symptoms of problems to look out for?
could it be something else?
ml3addict is offline
post #2 of 16 (permalink) Old 12-15-2007, 11:18 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1489 Post(s)
FAR888 had a similar problem with his left rear wheel and it turned out to be the RIGHT side motor mount./ Maybe this could also be your problem. You should have them all checked out.
https://www.benzworld.org/forums/w163...eft+rear+wheel
You might also want to look at the torsion bars, as they have plastic inserts between the metal, which do crack.
43sqd is offline
post #3 of 16 (permalink) Old 12-16-2007, 01:31 AM
FAR888's Avatar
Date registered: Mar 2007
Vehicle: 2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
Quoted: 4 Post(s)
That's correct ml3addict - I could have sworn it was coming from the rear wheels and it turned out to be my motor mounts - Have them checked out.
Best of luck!
FAR888 is offline
post #4 of 16 (permalink) Old 02-11-2009, 09:53 AM
Date registered: Dec 2007
its the rear diffrential problem
ckohli is offline
post #5 of 16 (permalink) Old 02-11-2009, 10:25 AM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Do you have some proof to back this up? Not trying to be a dick but, clarify please. Just give something more than what you think - what causes you to think this? Don't get me wrong...you could be right - even a blind squirrel trips over a nut in the woods sometimes.
BTW, welcome to the forum!
I'm thinking these guys are right OP...check the mounts and torsion bars. WORST case scenario...ckohli is right...diff could be going (lets hope not).
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #6 of 16 (permalink) Old 02-11-2009, 12:21 PM
wvcaudill's Avatar
Vehicle: 79 450 SL, 2014 GL63 AMG, 2016 E400 Cabriolet
Quoted: 14 Post(s)
I am interested in this discussion also. My 98 ML320 with 190,000+ miles just started doing the same thing. There are no codes and it only happens when I accelerate hard from a dead stop. It sounds like the rear differential is slipping. It is pretty loud and something I want to get addressed. Sounds like a job for an indy? Thanks.
Ted
2016 E400 Cabriolet
2014 GL63 AMG
1979 450SL
wvcaudill is offline
post #7 of 16 (permalink) Old 02-11-2009, 05:54 PM
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Keep in mind a loud rattling could be the cat heat sheild...also, if your ball joints are bad...another thing it could be. Just my .02
(\__/)
(o.O )
2000 ML320
post #8 of 16 (permalink) Old 02-11-2009, 06:09 PM
gwml55's Avatar
Date registered: Aug 2007
Vehicle: 03 ml55
Have someone rev the engine while in park, and see if the engine moves to one side or the other. If the mount is bad, the engine will move quite a bit when you rev. I had the same problem, a thunk when I accelerated from a standstill. It felt like someone was kicking the seat. I think the right (driver side) mount is the one that goes first in a lot of ML's.
gwml55 is offline
post #9 of 16 (permalink) Old 02-12-2009, 05:24 AM
Date registered: Nov 2008
Vehicle: '99 ML 320
Hi guys, this link might be useful for you
https://www.benzworld.org/forums/w163...id-change.html
My ML had a similar noise, i thought it was the rear axle, but it was the transfer case.
Good Luck
Da80 is offline
post #10 of 16 (permalink) Old 02-12-2009, 06:40 AM
FAR888's Avatar
Quoted: 4 Post(s)
It's certainly the one that 'went' first in mine!
FAR888 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
rear axle drive side clunking noise ???? amg guy W210 E-Class 1 09-26-2005 07:58 PM
Extremely Loud Clunking noise in rear once warmed up. Ideas? 240-John W123 E,CE,D,CD,TD,TE Class 2 09-27-2004 04:08 PM
rear differential noise kourosh W126 S,SE,SEC,SEL,SD,SDL Class 2 02-17-2003 09:31 PM
rear differential noise kourosh W126 S,SE,SEC,SEL,SD,SDL Class 0 01-27-2003 09:16 PM
Anyone found a fix for the loose rear seat 'clunking' noise ? timf W163 M-Class 3 08-19-2002 07:15 PM
