Transfer case motor, control module or ?? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-11-2007, 02:28 PM Thread Starter
Date registered: Apr 2005
Vehicle: 1999, ML430
I have 1999 ML 430 with 133, 000 miles. Early this morning I was turning relatively slowly turning into a parking when I heard a bang...thought I ran over something. Got out (too early for any traffic around) looked around and under and saw nothing. As I rolled forward to park, I heard what sounded like gears clicking/grinding - clicks/grinds faster as speed increase. It was so loud the few people in the parking lot turned to see who was making all that noise! I feared the worst, presuming drive shaft, differential, transfer case or transmission.
My mind immediately raced through the work I've done over the last 2 weeks. Oil change...that can't be it unless it's all drained out because I forgot the plug. But that was 100 miles ago. One new O2 sensor. That's not it unless I left a tool. Drive shaft center support bearing replaced 300 miles ago along with transfer case fluid (Castrol Dexron III) change. No leaks at either transfer case fill or drain plug.
What could it be? I didn't want to drive it any further fearing a noise that loud is an indicator of major $$ problem. Put car in park, turned off the engine. Looked for my motor club card. Surveyed the parking lot for a spot to park that would be easy for a flatbed towtruck to haul the car to the dealer (and avoid further embarassment in the parking lot). By now someone had pulled in behind me so I had to drive forward. Started the car, put it into drive and the noise was still there. Based on a 5 second analysis of hanging out the vehicle while it was rolling forward, it sounded like it was coming from DIRECTLY below the open door...not from the front or rear of the truck but somewhere more in the middle but it was a pretty quick, unsophisticated analysis. Found a parking spot on a single row that would be easy access for the flatbed. As I backed into the spot, I heard a thud when I put the car in reverse. Backed into the spot. Then decided to move forward a few feet just to see what sounds occurred. The grinding/clicking was GONE!
Drove around the parking lot with no issues and decided to try to make one more shopping stop and then head home...about 10 miles in total. It did not act up again but I am so fearful that the noises are a warning of a big problem/issue so I'm reluctant to drive it until I get some expert advise. Two other bits of information: transmission was serviced at 100,000 miles (replaced leaking transmission cooling lines...so much for sealed transmission) new MB fluid, filter, magnet. Yesterday, I engaged the LOW range for the FIRST time in a couple years for about a 10 seconds to get up a steep, dirt hill with some firewood. Truck was driven at least 50 miles after that.
Any thoughts about what would have caused this? Transfer case motor? Control module? Will this have thrown any transmission diagnostic codes? My OBDII/Can reader doesn't show any codes so can only the dealer pull transmission/drivetrain codes or can any good shop analyze this?
Thanks in advance for all your inputs, opinions and guidance.
jamesvyu is offline
post #2 of 4 (permalink) Old 11-11-2007, 04:22 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1530 Post(s)
Gee it's tough to say, but I would check that drive shaft and the center support you just had replaced.
43sqd is offline
post #3 of 4 (permalink) Old 11-12-2007, 05:33 AM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
When my drive shaft (on a '98 ML 320) went bad, it made similar noise. However, in your case, the noise seems to be gone.... get under the truck and try to move the drive shafts (trans to transfer case, tr case to front diff, tr case to rear diff) and see if any of them have lot of play... good luck
pcy is offline
post #4 of 4 (permalink) Old 11-19-2007, 01:53 PM Thread Starter
No Issues Found...yet
Indy cannot find any issues with drive shaft support bearing, either diffs, transfer case or driveshafts.
That was 100+ miles ago and still no symptoms. He suspects on of the CV joints got "hung up". Not sure I'm confident of the diagnosis so will have to drive and listen for a new clue.
Will keep your posted.....
jamesvyu is offline
Low Range Transfer Case Motor Replacement da_guitarist W163 M-Class 11 06-16-2007 08:32 PM
Took my G in for a few minor things and they found that the motor in the transfer case is defective. blau G-Class 21 02-06-2006 09:04 PM
transfer case motor? here we go again... Kerr G-Class 9 06-20-2004 12:53 PM
Help! Transfer Case Module/Transmission Module CSlaton G-Class 0 10-06-2003 09:10 AM
03 transfer case control module 03-g500 G-Class 3 08-12-2003 12:01 PM
