brake light is on and car beeps - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 06-12-2007, 03:24 PM Thread Starter
ml3addict's Avatar
Date registered: Jan 2007
Vehicle: 05 ml 350 SE
this problem started yesturday after my car has been sitting in the driveway for over a week without use...the parking break is not on but the light says its on and the car beeps...anybody know what it might be?
keep in mind its the parking brake light not the breakpad light
ml3addict is offline
post #2 of 18 (permalink) Old 06-12-2007, 07:01 PM
Purple Imposter
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Quoted: 337 Post(s)
Depress and release your parking brake several times and see if that corrects it. The sensor/switch that controls the parking brake may have stuck.
2005 S430 4Matic 'Morton' W220.183 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 18 (permalink) Old 06-13-2007, 03:23 AM
Date registered: Apr 2006
Vehicle: 2004 CL55
or maybe the brake shoe is not getting released. did you try to drive the car to see if it moves easily?
Alex L is offline
post #4 of 18 (permalink) Old 06-14-2007, 10:31 PM Thread Starter
ml3addict's Avatar
no i found out what the problem is...the little button that engages the light in the dash got disconnected from wherever it connects down by the e-brake...i gotta take it to the dealership to fix since i have no idea where it goes
post #5 of 18 (permalink) Old 06-15-2007, 03:45 PM
Date registered: Sep 2004
Vehicle: 2004 ML350
Hi,
The switch clips into the stationary part under the dash and is actuated by the parking brake. It's easy to snap back in place once you see how it works. You may want to check under there with a flashlight.
Joe
2bmj is offline
post #6 of 18 (permalink) Old 06-03-2019, 05:18 PM
Date registered: Nov 2014
Vehicle: 2000 E 320 Wagon + 2002 ML 500 SUV
Quoted: 168 Post(s)
Question Ressurection of 12 year old thread...here it comes again
Originally Posted by 2bmj View Post
Hi,
Joe
43sq, and all:
I am dusting this 12 year old thread as it pretty much spells out what I think my issue is.
I have the 'Mysterious Intemittent Beeping and Illuminated Brake warning light on dash' It comes on randomly while driving. Not when pressing brake pedal.
I have already replaced the Brake Fluid Level Sensor, thinking it was bad. Probably it was ok.
The brake pads, rotors & sensors were all new in the last 12 months.
I'm thinking it could ONLY be the Emergency Brake Sensor, either faulty or popped out of place.
Is this E Brake Sensor behind left drivers kick panel or up under dash ?
According to the chart I will attach if Brake Fluid level is full & Sensor Cap new, it could ONLY be the E Brake Sensor, nothing else, correct ?
Thanks for the help !
2000 E 320 White Wagon is offline
post #7 of 18 (permalink) Old 06-03-2019, 06:17 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 916 Post(s)
This is you third post on same issue. In first two I have offered some advice. You have ignored it. This time I am going to pass.
43sqd and reetp like this.
Witek_M is offline
post #8 of 18 (permalink) Old 06-04-2019, 06:10 PM
Quoted: 168 Post(s)
I haven't had access to computer to pull codes as of yet.
Trying to solve it analog.
It could be wheel pad sensor though all are less than a year old.
And it doesnt match that blurb from MB Star, that says Brake sensor issue only manifests upon pedal press occuring, this can start without pressing brake & continues until key is cycled.
Maybe sensor Intermittently shorting out ?
Sorry to bother you Witek.
Is something troubling you these days ?
You were harsh to a newbie just earlier this week.
I've got thick skin, others maybe not so much.
Cheers - David
post #9 of 18 (permalink) Old 06-05-2019, 05:21 PM
Quoted: 168 Post(s)
Exclamation Ok, got some codes....
Ok was able to use Carsoft for MB to check for codes:
From ESP module:
C 1102 LR Wheel speed sensor
C 1103 RR Wheel speed sensor
C 1200 Stop Lamp Switch
B 1210 ??
Nothing else would seem to possibly relate to the issue at hand.
So I cleared the codes and will see when / how / if this recurrs.
For now I'm not using E Brake and see if that has any effect.
First drive after clearing them, perfect nothing no beeping.
Will update this & hope you're having a great summer and NO ISSUES !
Cheers - David in East Texas
post #10 of 18 (permalink) Old 08-07-2019, 07:37 PM
Quoted: 168 Post(s)
Ok an update:
I pulled the 4 abs wheel sensors. 3 of them had pretty nasty crud built up in the hole & at sensor tip, enough to block signal, perhaps ?
Also the bolt & hole surround makes ground contact - so I thoroughly cleaned the hole, sensor tip & contacts.
A funny thing happened yesterday while driving. It beeped at me (yet again) I pulled over & cycled the engine, went on.
(Same thing has happened most days sometimes 2-3 times a day.)
Later while driving it beeped once, flickered the light and stopped itself.
Did this again, a beep, light flicker & off.
Today, no beeping nothing at all.
Can anyone say if it sounds like the ECU just did a module reset of this issue ?
I'd sure be blessed if this resolves it !
Thx - David
15 Loud Beeps when turn car on - what can I do!!?? lbh2315 R171 SLK-Class 5 05-16-2007 12:13 PM
Replacing brake light in back of car debbibaron W124 E,CE,D,TD Class 2 03-13-2007 06:30 AM
Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 07:10 PM
99 c280 Brake light is on and it beeps when I drive the car HELP! paul88 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 02-04-2005 01:14 PM
86' 300E Car idles rough when antilock brake light is on Guest (MBNZ) W124 E,CE,D,TD Class 2 07-22-2002 01:35 PM
