Power Steering Rack Leaking - not the hose! - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 12-16-2014, 10:06 AM
Date registered: Mar 2009
Vehicle: 2000 ML320
THANKS bustamanty for the quick and helpful response. Did you remove the front axle to replace the rack. You are one of very few people with this experience - Thanks again!
JDC-SoCal is offline
post #22 of 25 (permalink) Old 12-17-2014, 03:40 AM
bustamanty's Avatar
Date registered: Nov 2013
Vehicle: 1999 ml320
Quoted: 10 Post(s)
Power steering rock
Yes I changed mine but if you are not michanically inclined I wouldn't advise you to do it on your own, if you search this forum you will find every thing you need to do the job, let me tell you this forum is a blessing I saved up to $15,000 because of this forum ,THANH YOU,THANK YOU . If you cant find it on this forum go to YOUTUBE you will find it there .
bustamanty is offline
post #23 of 25 (permalink) Old 12-17-2014, 04:06 AM
bustamanty's Avatar
Vehicle: 1999 ml320
Quoted: 10 Post(s)
Sorry 43 just getting back to you, I jacked the front up rear wheel still on ground and I had to remove the front differential and axle .
post #24 of 25 (permalink) Old 12-17-2014, 04:41 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1548 Post(s)
I see that you are typing which means you didn't lose any fingers doing that job on your back.
43sqd is offline
post #25 of 25 (permalink) Old 03-21-2019, 07:41 PM
Date registered: Mar 2004
Vehicle: Amethyst 2001 C320
Quoted: 5 Post(s)
Originally Posted by 4benzes View Post
I had the same problem. I just had to tighten a torx fitting on the rack. I never had another problem form it. The dealer tried to replace my entire rack also.
Originally Posted by JDC-SoCal View Post
Which Torx fitting did you tighten 4benzes?
I noticed this same problem this morning on my 2001 C230 W203 chassis. The Torx fitting on the steering rack is easily accessible from the front under the engine after you remove the plastic engine cover underneath held on by 6 8mm bolts, and you don't need to jack the car up.
The fitting is a Torx E18, but you won't be able to fit the socket in there while it is connected to a socket wrench because the front stabilizer bar gets in the way, so instead you can slip the closed end of a 9/16 wrench around it and tighten it by hand.
You can see from the photo that prior to tightening it was dripping about once every 2 seconds, so it was a really bad leak. As soon as I tightened the bolt, the leak stopped. I topped off the fluid and have driven it about 100 miles and it isn't leaking anymore.
n0alpha is offline
