Vent issue - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-13-2019, 08:49 PM Thread Starter
afldmgr's Avatar
Date registered: Jul 2009
Vent issue
Recently my 97 S320 intermittently started to not switch to defroster/dash vents/floor when selected. The ac and heat work, blower works, all functions on the display work, it just won't switch.
afldmgr is offline
post #2 of 4 (permalink) Old 08-14-2019, 04:43 AM
Thom_7's Avatar
Date registered: Sep 2012
Vehicle: 1995 Mercedes S420, 2000 Land Rover Discovery II, 1985 Lotus Turbo Esprit
Quoted: 223 Post(s)
Is your PSE pump working?
The flapper doors that control the vents all operate on the PSE vacuum system, and if that pump goes bad it can cause problems with vent selection and airflow.
Thom_7 is offline
post #3 of 4 (permalink) Old 08-14-2019, 06:28 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 278 Post(s)
There is also a vacuum line from the engine that goes to a distribution block behind the passenger side kick panel. From there, a line goes to the vacuum control block for the HVAC system behind the glove box liner. That control block has control valving to send vacuum to the various actuators that open and close the vent damper doors. If there is a leak anywhere in the system, it can cause the issues you describe.
You can find a description of the system and a trouble shooting guide at http://manual.startekinfo.com/manual..._6/content.jsp
Thom_7 likes this.
jal1224 is online now
post #4 of 4 (permalink) Old Today, 04:25 AM
samosali's Avatar
Date registered: Nov 2007
Vehicle: W140 Mercedes 500 SE, 1992, European, 410.000 km
Quoted: 280 Post(s)
most probably (not necessarily) the culprit is leaking distribution block at the passenger foot well (behind the carpet and metal plate).
samosali is online now
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
samosali
