no reverse after 15 mile test run - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-26-2019, 05:12 PM Thread Starter
Date registered: Jun 2019
Vehicle: 1992 400se
new to me 92 400se. has been sitting in a garage for 10 yrs
got my fuel issues sorted out. started and did a few mini trips. couple miles each. ran better each time. car seemed to be running well so I took it on a 15 mile round trip drive. pulled into driveway and no reverse. drive is fine but in park and neutral it makes a whining sound and no reverse. any suggestions? thanks guys
neversinksmith is offline
post #2 of 11 (permalink) Old 06-26-2019, 05:49 PM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 37 Post(s)
you have a 722.3 transmission. What's most likely happening is the B3 reverse apply piston loses its seal after the transmission warms up.
permanent fix: rebuild (around where I live they run about $2700 that's already with rnr they dont have to rebuild the torque converter so thats why its quite reasonable)
temporary fix: I heard of a guy who had the same problem and he replaced 1 or 2 quarts of transmission fluid with thick engine oil and that will obviously thicken up the fluid and make the piston seal better but I dont know the long term effects of that
you can also try off the shelf transmission fix fluids also did you change your fluid and filter?
christuna is offline
post #3 of 11 (permalink) Old 06-26-2019, 07:04 PM Thread Starter
Vehicle: 1992 400se
have not changed atf and filter. does my tranny have the conductor plate? so cant I just replace the B3 reverse apply piston seal you spoke of?
post #4 of 11 (permalink) Old 06-26-2019, 07:32 PM
Vehicle: 1990 300SE
Quoted: 37 Post(s)
no your transmission doesn't have a conductor plate. It's a hydraulically controlled transmission without torque converter lockup. simple trans.
you can just replace the seal to do that you have to remove the transmission, remove the the front pump and then you can get to the piston and the seal. but if you're gonna go through all the trouble of doing that you might as well rebuild it.
change the atf and most importantly the filter it can help sometimes.
post #5 of 11 (permalink) Old 06-26-2019, 07:34 PM Thread Starter
Vehicle: 1992 400se
regular atf is ok?
post #6 of 11 (permalink) Old 06-26-2019, 07:39 PM
Vehicle: 1990 300SE
Quoted: 37 Post(s)
these transmissions take dexron 3 which is no longer available. DEX/MERC is a replacement for dex3. I use it and haven't had any problems
post #7 of 11 (permalink) Old 06-27-2019, 04:38 AM
Motivational Poster
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Quoted: 332 Post(s)
This is a common issue with the 722.3, its achilles heel. Rebuilding it is the only permanent solution.
2005 S430 4Matic 'Morton' W220.183 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #8 of 11 (permalink) Old 06-27-2019, 04:43 AM Thread Starter
Vehicle: 1992 400se
went out this morning after the tranny cooled down. still doing the same thing. what is the whining noise im hearing? is there some sort of hydrolic actuator that shifts the tranny? whines in park and neutral only.
post #9 of 11 (permalink) Old Yesterday, 11:50 AM
inventor's Avatar
Date registered: Mar 2011
Vehicle: 1987 300D turbo 237.000, 1994 S420 80.000K
I drove mine for 9 months I had to remember to park up hill so I can roll back.....eek
inventor is online now
post #10 of 11 (permalink) Old Today, 09:10 AM
Date registered: Jan 2015
Vehicle: 2001 E 430; 1995 S500
Quoted: 127 Post(s)
I don't know where you live, but I am in Dallas, Texas, and when my '95 S550 transmission started to fail (the usual Reverse thing), I took it to a small-shop place (guy had worked many years for Park Place Mercedes in Dallas, then opened his small shop a few years ago). He replaced my tr with a different one he had in the shop and it has worked PERFECTLY for almost two years. Cost me $800.00.
You might see if that would be a possibility where you live. Of course there's always a risk in that approach, but $800 is a whole lot less than two grand or more. Just suggesting . . .
James
james sharp is offline
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
quakercity
