oil in coolant help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-14-2019, 09:55 PM Thread Starter
teddycandy's Avatar
Date registered: Oct 2017
Vehicle: 1998 S320L W140
Quoted: 8 Post(s)
oil in coolant help
My 1998 s320 has oil in coolant. I replaced the oil cooler and still has it. Checked transmission atf and level was good and is clean. Flush the cooling system and radiator 3x still has oil.
Engine does not overheat even in heavy traffic and runs great.
Cooling system does not over pressure too.
Bought a headgasket tester and the chemical remained blue and did not turn yellow.
Pls. Help. Thank you
teddycandy is offline
post #2 of 7 (permalink) Old 06-15-2019, 02:32 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 142 Post(s)
Dont understand if the tester never changed yellow then its not oil that you have in the system is it ?
This is a retro ride .
plinker17722 is offline
post #3 of 7 (permalink) Old 06-15-2019, 04:34 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
if the tester turns yellow it means exhaust gas is entering the cooling system and has a blown head gasket.
post #4 of 7 (permalink) Old 06-15-2019, 05:41 AM
Date registered: Jul 2018
Vehicle: 1990 300SE
Quoted: 37 Post(s)
M104 engines (your s320 has it) are known for head gasket failures and oil in coolant is the usual symptom together with oil leaking out.
When a head gasket fails it doesn't need to have exhaust in coolant. there are many ways a head gasket can fail.
Hirnbeiss and plinker17722 like this.
christuna is offline
post #5 of 7 (permalink) Old 06-15-2019, 07:03 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
Crap.. i was afraid of this. Thank you for the info. My kidney now is for sale. Haha
post #6 of 7 (permalink) Old 06-16-2019, 03:14 AM
Quoted: 142 Post(s)
oil
Yes i know all about that,,
post #7 of 7 (permalink) Old 06-16-2019, 04:47 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
It was oil.. 😞
