Fan clutch help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-14-2019, 11:23 AM Thread Starter
teddycandy's Avatar
Date registered: Oct 2017
Vehicle: 1998 S320L W140
Quoted: 8 Post(s)
Fan clutch help
Car runs a little hotter on traffic and culprit is the fan clutch.
In my area the only fan clutch I could find is swag fan clutch.
Has anyone tried swag fan clutch or should I stay away?
teddycandy is offline
post #2 of 7 (permalink) Old 06-14-2019, 11:34 AM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
We don't carry the SWAG, but we have other brands: https://www.autohausaz.com/catalog/c...tch?s=d&page=1
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #3 of 7 (permalink) Old 06-14-2019, 11:38 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
Hi, sorry forgot to mention Im from manila, Philippines.
Swag is the only fan clutch that i could find here. Has anyone tried swag fan clutch or stay away from it?
post #4 of 7 (permalink) Old 06-15-2019, 02:55 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 146 Post(s)
You have to use whatever you can .No bad stories about Swag. Do you have a pick and pull yard . May be you can pick up a good used one .Or go the full hog and go electric fan install these come up in the pick and pull yarde as they are fitted to other models of your Mercedes . Just mount it on the radiator put feed wires to it via a switch and a fuse.
This is a retro ride .
plinker17722 is offline
post #5 of 7 (permalink) Old 06-15-2019, 07:00 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
No, we don't have a pick and pull here but i can get a used oem but i think it would be better if i go new. Ill try swag. Thank you
post #6 of 7 (permalink) Old 06-15-2019, 06:37 PM
Date registered: Apr 2016
Vehicle: '95 S600
Quoted: 71 Post(s)
SWAG typically are lower tier quality wise, never used their clutches but seen issue with other parts.
Just import a Behr one, they cheap enough shipped.
NZJay is offline
post #7 of 7 (permalink) Old 06-16-2019, 04:49 AM Thread Starter
teddycandy's Avatar
Quoted: 8 Post(s)
Thank you for the info. Will try ebay for behr
