Rough idle when cold - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-11-2019, 09:56 AM Thread Starter
Date registered: Apr 2019
Vehicle: 1992 300SE
Send a message via Skype™ to Gene Reyzin
Looking for Advice, 1992 300SE,
The issue is rough idle, it used to be worse but after replacing spark plugs and cleaning MAF runs a little better, however when the car is cold, it starts fine but the RPM drop to almost stalling and then rev up to about 2K, this keeps happening for a few minutes. After the car warms up the idle is Okay but not prefect, still feels a little rough.
Thank in advance for your input
Gene Reyzin is online now
post #2 of 7 (permalink) Old 06-11-2019, 12:56 PM
Date registered: Sep 2013
Vehicle: 1992 500SL, 1993 300SE, 1997 S320L, 2000 C230K, 2003 E500, 2005 Smart ForFour, 2008 Smart ForTwo
Quoted: 79 Post(s)
Brittle breather hoses, distributor cap would be worth looking at
BenzWillMakeHerDance is offline
post #3 of 7 (permalink) Old 07-08-2019, 09:23 AM Thread Starter
Vehicle: 1992 300SE
Update: Changed the distributor cap and rotor, replaced a breather hose. Idle is better, however on start the RPMs are still unstable, the car almost stalls then RPMs increase after 30 seconds engine stabilizes. Once warmed up all good. Looking for advice. Thank you
post #4 of 7 (permalink) Old 07-08-2019, 09:40 PM
Date registered: Aug 2014
Vehicle: 1994 S500 and S320 W140
Quoted: 27 Post(s)
I'm having a similar with the idle. I've been chasing this thing for 6 months. It has (tremors) after some spirted driving or long road trips. I have changed:
fuel injectors
fuel pressure regulator
fuel filter
fuel pumps were done less then 10k ago
plugs
still have the same problem. I was told today at a shop that my friends swears by that I probably need coils. I'll up date you when I do unless someone here has another suggestion?
PC S class is offline
post #5 of 7 (permalink) Old 07-09-2019, 08:58 AM
Premium Member
anziani's Avatar
Date registered: May 2008
Vehicle: '97 CL600
Quoted: 566 Post(s)
Premium Member
Any one try the fuel pressure regulator? That solved one of my problems.
Anziani
anziani is offline
post #6 of 7 (permalink) Old 07-10-2019, 02:07 PM
absorb's Avatar
Date registered: Mar 2016
Vehicle: 1992 300se
Quoted: 6 Post(s)
It could be the ignition control module maybe. I had a similar problem, car would drop way down in rpms at stoplights and seem like it wanted to die for a sec.
absorb is offline
post #7 of 7 (permalink) Old Today, 12:03 PM Thread Starter
Vehicle: 1992 300SE
Got a OBD code reader and this what I came up with:
Socket 7 Code 2 3 and 5
2 - Cruise control/idle speed control module
3 - Cruise control/speed control actuator
5 - and stop lamp switch
I am thinking this where the problem lies.
Any suggestions?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
