Push Button start mod - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-24-2019, 09:51 AM Thread Starter
Date registered: May 2019
Vehicle: 95 W140 S600 M120 V12
Hello all,
I'm looking to do a push button start on a 95 W140 S600. Is there anyone who has tried this with success?
The ultimate would be a hidden switch to turn off alarm to allow for a push button start without a key fob.
The offset would be an additional switch to kill fuel after starting as an antitheft, or one switch/relay that does both. Allowing average driver/owner to use keys and keeping the integrity of the alarm intact.
Thanks in advance with any help on this.
TD
AMDINARDOM is offline
post #2 of 7 (permalink) Old 05-24-2019, 02:55 PM
Moderately subtle
edfreeman's Avatar
Date registered: Dec 2003
Vehicle: 94 E500, 97 500SL
Quoted: 175 Post(s)
Send a message via AIM to edfreeman
Moved to correct forum
edfreeman is offline
post #3 of 7 (permalink) Old 05-24-2019, 04:18 PM
z168's Avatar
Date registered: Oct 2005
Vehicle: M20
Quoted: 137 Post(s)
Why?
Deutsche Tourenwagen Meisterschaft
z168 is offline
post #4 of 7 (permalink) Old 05-24-2019, 04:38 PM Thread Starter
In case of lost keys far from home. Definitely going to need a fob on the outside. Any issues with ignition, antitheft system, shall I go on.
post #5 of 7 (permalink) Old 05-25-2019, 09:27 AM
Date registered: Jan 2016
Vehicle: 1991 S600 Japanese market
Quoted: 107 Post(s)
I did this last week. Very simple. My ignition switch decided not to crank the engine.
Ran a two wire cable from the starter thru a hole in the passenger floor. Across the console, out by right side of the drivers seat. Piece of cake.
AMDINARDOM likes this.
scottpeterd is offline
post #6 of 7 (permalink) Old 05-25-2019, 06:00 PM Thread Starter
Thank you for the reply, are you able to start it without the key in the ignition? Without key is what I'm looking for!
post #7 of 7 (permalink) Old 05-25-2019, 07:14 PM
Quoted: 107 Post(s)
No, This mod wont allow that. I did it because for some unknown reason, while my ignition switch turned on the electrics, it wouldnt allow it to crank.
Of course, as soon as I wired around the swith, it decided to cooperate
