M120.980 throttle bodys rewired correctly? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-11-2019, 11:54 PM Thread Starter
Date registered: Apr 2019
Hy everybody,
I just rewired my working throttle bodys because of briddle insulation.
I didn't check before disassembly, but is it normal that if I turn on the ignition both ETA's go to position WOT.
I'm pretty sure that everything is wired up correctly.
The Injector harness isn't installed, just for information.
Would be great if someone could help me.
best regards from Austria
Rene
Grab_389 is offline
post #2 of 6 (permalink) Old 04-12-2019, 12:15 AM Thread Starter
Here's what I've done:
Passanger side: driver side:
Motor+ 4 Motor+ 4
Motor- 11 Motor- 11
k 12 k 12
i 5 i 13
e 9 g 2
b 3 h 6
c 14 l 8
g 7 b 3
c 14
f 10
e 1
Grab_389 is offline
post #3 of 6 (permalink) Old 04-25-2019, 12:52 AM Thread Starter
Doesn't anyone know the solution for my problem?
I checked up my wiring with Star Diagnosis
All values are correct, but it stores my 16/3 ETA (driver side) as faulty.
Resistance closes throttle R2: 4,32 Ohm
Resistance open throttle R2: 0,54 Ohm
Resistance closed throttle R1: 0,52Ohm
Switches at closed throttle:
S2n
S1ff
best regards
Rene
Grab_389 is offline
post #4 of 6 (permalink) Old 04-25-2019, 01:14 AM
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: "CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Quoted: 514 Post(s)
I did this this morning, rewired the way to long MAF wring . After i finished & started the car it started & ran a little weird for a few seconds ,as it heated up it settled perfectly .
I saw it all on my Star scanner with the values changing .
I scanned the car & erased the fault codes several times , as of now ,Not a single fault code has reappeared .
I also did a Reset on the camshaft values bank 1 & bank 2 .
Have you erased the old codes yet ?.
BTW: Wait for more Answers as the World wakes up & Log's on .
*My-600SEL-V12*
"VENI-VIDI-VICI"
"I came-I saw-I conquered".
Driving a W140 & everything else feels like is standing still .
Everything you like to know about the W140's
Merc-S600 is online now
post #5 of 6 (permalink) Old 04-25-2019, 01:26 AM Thread Starter
Sounds good so far :-)
Thanks for your reply!
Yes, I erased all fault codes (the one from the driver side ETA several times)
best Regards
Rene
Merc-S600 likes this.
Grab_389 is offline
post #6 of 6 (permalink) Old 04-27-2019, 03:59 AM Thread Starter
Unfortunatly fault comes again after erasing it.
Here some photos of the values and the fault.
On one photo it's with closed throttle, and one with WOT.
Thanks for help!
best regards
Rene
ID:	2508000   Click image for larger version
ID:	2508002   Click image for larger version
ID:	2508004   Click image for larger version
Grab_389 is offline
E240 Wagon P0221 Code, Not convinced it's Brake light Switch Issue. jltarra W210 E-Class 10 02-21-2016 12:11 AM
How to correctly get to Throttle body after MAF karlranks W210 E-Class 5 06-12-2014 07:16 PM
Notchy Throttle Update _Dennis_ W163 M-Class 30 08-04-2010 04:22 AM
Sprint Booster for W210 E55 AMG? omeyhomey W210 E50 AMG, E55 AMG 11 02-23-2008 08:08 AM
Lubricating the throttle linkage and spring mod Greg450SL R/C107 SL/SLC Class 3 11-14-2005 09:45 PM
