Front wheel well lining issue - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-24-2019, 09:48 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation Front wheel well lining issue
I have just changed the standard wheels in my 1997 CL500 with original 18 inch AMG Monoblock wheels with 255-45-18 tires. The issue which i have is that when i turn the steering wheel all the way to the right side, the front right wheel touches in the inside the plastic wheel well lining. It seems that the lining has buckled a bit. I see that there are some screws in the lining, do they need to be re-tightened, so that the lining does not interfere with the tire ? Please advise.
NewYorkS600 is offline
post #2 of 6 (permalink) Old 03-25-2019, 07:08 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 275 Post(s)
Are you sure 255 tires originally came with the car in the front? Typically around this period of time, when Mercedes used 18 inch wheels, they would use 245 in front and 275 or 265 in the rear.
illstplaya is offline
post #3 of 6 (permalink) Old 03-25-2019, 07:28 PM Thread Starter
Quoted: 134 Post(s)
The standard for 18 inch AMG Monoblock wheels was always 255-45-18 all around for the W140 series Sedan and Coupe.
post #4 of 6 (permalink) Old 03-25-2019, 10:53 PM
Thom_7's Avatar
Date registered: Sep 2012
Vehicle: 1995 Mercedes S420, 2000 Land Rover Discovery II, 1985 Lotus Turbo Esprit
Quoted: 218 Post(s)
I just went through this with my front wheel well liner also. I have stock wheels, but the liner buckled somehow and the wheel was rubbing on one of the bolts when I made turns. I tried to knock it back in with a rubber mallet but that didn't help much. Ended up having to replace the liner.
Thom_7 is offline
post #5 of 6 (permalink) Old 03-26-2019, 09:03 AM Thread Starter
Quoted: 134 Post(s)
Where did you get the new liner from ? Is this a dealer item only ? Do you have the part number by any chance ?
post #6 of 6 (permalink) Old 03-26-2019, 09:57 AM
Thom_7's Avatar
Quoted: 218 Post(s)
My mechanic cannibalized one from a parts car, although I do remember seeing them on Amazon at one point oddly enough. They were very inexpensive too. I don't have a part number but I'll check later today and see if I can find it again.
Thom_7 is offline
Massive issue with rock chips on front bumper...Advice? iconoclast12 W204 C-Class 4 05-23-2018 06:38 PM
W208 Front Wheel Bearing Replacement DIY StigHelmer C208/A208 CLK-Class 34 09-28-2015 05:50 AM
Model summary Table eurospec380se W126 S,SE,SEC,SEL,SD,SDL Class 0 01-22-2011 02:22 PM
Front wheel rubbing on tie rod end. falling angel W123 E,CE,D,CD,TD,TE Class 9 06-01-2010 07:14 PM
FS: 2001 Silver/Black S500 81k miles 20" AMG wheels Warranty New Tires - $16500 chriscobal For Sale/Wanted/Trade/Giveaway 5 02-25-2009 07:14 AM
