M120 Suppressor Engine Star / Chrome - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 03-22-2019, 09:08 PM Thread Starter
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: "CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Quoted: 510 Post(s)
I have given up the Search for this Star in Chrome ,1st time ever i abandoned a search for a W140 part .
All M120's have this Star on the Suppressor Cover that covers the Power Steering fluid reservoir in Black Plastic. I rang MB everywhere & they don't even have a part # for the 65mm Star .
E'bay & Goggle show some but they are not the Chromed Star,looks silver painted .
At local MB wreckers which are all my friends (partially) ,we searched a lot of engines that i told them could have this Star on it , these where M104/M103 ,SLK/CL's some R129's , the M104's have it but it is Stamped only so it cant be used or removed,maybe the early M104's .
Here is what i did , looks better then the original as well , everyone i asked which one would you take ,they all choose my new invention (lol) .
Here Goes
1: Find a Black MB 75mm hubcap ,easy found at wreckers for free ( i did) ,if not free then make sure you have lots of big pockets .
2: Cut of on the underside the clips , this way the Chromed Star will just fall out with enough Clip on it for later welding .Remove the STAR .
3: Remove the metal circle holder that reinforces the hubcap & cut the holders where it was in .
4: Get a wide File & file that Hub to Zero up to the last clip ,when all is nice & flush with the Bottom ,stop filing ,make sure it's nice & straight .
5: Now Clean the Star ,Polish it if you like to also clean the black Hubcap part that will be facing or even spray paint it (Use High Heat Paint) .
On the back side of the Chromed Star you still have a few MM of the Clips ,don't cut them of .
6: Once you're happy with the new CHROMED Star appearance & the Black Round Background , re-insert the Star into it's position by adding just a touch of glue onto the clips ,let it dry a few minutes ,then of to Welding .
7: Now you need a Soldiering Iron , Melt the clips on the backside flush ,this will prevent the Star from falling out .
8: Black Epoxy Glue all around the Base of the Star & even inside it ,i used high heat epoxy glue and Glue that whole MB Chromed Star to the Suppressor Cover .
Voila ,a New look to your Engine & the SEARCH for this dam 65mm Star is over for EVER ,Black plastic or chrome ,simply not available anywhere, the black one can be purchased for $30/50 for the whole cover but not the Chromed one .
8 or more Steps sounds a lot but it isn't really ,actually more fun then anything.
On other parts of Benzworld what other owners did is ,they used a fine mesh behind the Star but only because they have a large hole there .
ID:	2498434   Click image for larger version
ID:	2498436   Click image for larger version
ID:	2498438   Click image for larger version
ID:	2498440   Click image for larger version
ID:	2498444   Click image for larger version
ID:	2498446   Click image for larger version
ID:	2498448   Click image for larger version
ID:	2498450   Click image for larger version
MAVA and 400 SE or S420 ? like this.
*My-600SEL-V12*
"VENI-VIDI-VICI"
"I came-I saw-I conquered".
Driving a W140 & everything else feels like is standing still .
Everything you like to know about the W140's
Merc-S600 is offline
post #2 of 21 (permalink) Old 03-22-2019, 09:09 PM Thread Starter
W140 Moderator
Merc-S600's Avatar
Quoted: 510 Post(s)
Take Note that the Right side pictured Star has been Painted silver by me previously ,i didn't like it .
Next is the V12 Chromed Emblem which is coming from Bulgaria & that Engine is done .
Added two extra pictures ,last two down the bottom, how the engine looked when i 1st received the car & one just before i decided to paint it and Yes ,i also painted the Writing MERCEDES-BENZ on the injection cover ,to paint that use a small corner roller & use a toilet paper tube with some fine cloth around it then spray the paint directly onto the roller & slowly paint it , doing it like this prevents paint dropping into the letters & looks MB did it by factory.
The Engine runs & sounds 100% ,no faults or oil leaks .
While i was on the phone with MB parts ,i asked them for Engine Mounts for the M120, Price was $1300 plus gst .
LOVE TO KNOW WHY MANY PICTURES UPLOAD SIDEWAYS.
ID:	2498472   Click image for larger version
ID:	2498474   Click image for larger version
ID:	2498476   Click image for larger version
ID:	2498478   Click image for larger version
ID:	2498482   Click image for larger version
ID:	2498484   Click image for larger version
z168, MAVA, quakercity and 1 others like this.
*My-600SEL-V12*
"VENI-VIDI-VICI"
post #3 of 21 (permalink) Old 03-22-2019, 10:36 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1215 Post(s)
Nice thread. I saved it to my favorites..
Martin
Merc-S600 and quakercity like this.
MAVA is offline
post #4 of 21 (permalink) Old 03-22-2019, 10:50 PM Thread Starter
W140 Moderator
Merc-S600's Avatar
Quoted: 510 Post(s)
Martin
Thanks Martin . I still need to post this on the other forum sections ,they probably need this as well , you can do it if you feel like it ,i have to go now .
Some M120 owners are ripping there hair out because they cant find a 65mm Star ,i have to many hair & would take to long to rip out ,this is just a shortcut ,lol.
MAVA likes this.
*My-600SEL-V12*
"VENI-VIDI-VICI"
post #5 of 21 (permalink) Old 03-23-2019, 05:35 AM
Date registered: Jan 2015
Vehicle: 2001 E 430; 1995 S500
Quoted: 122 Post(s)
Ripping their hair out? Really?
James
james sharp is online now
post #6 of 21 (permalink) Old 03-23-2019, 07:08 AM
MAVA's Avatar
James
James,
Yea, they are ripping their hair. I run into 600 owners with the WHOLE piece missing.
It is just the "icing on the cake" kinda thing..
Martin
Merc-S600 likes this.
MAVA is offline
post #7 of 21 (permalink) Old 03-23-2019, 03:53 PM Thread Starter
W140 Moderator
Merc-S600's Avatar
Quoted: 510 Post(s)
James
Sorry if the Term i used annoys you a little .
After an extensive 1 week or more search for this Star , i have come across many websites were owners just don't care anymore about this Star problem for how to resolve it .
Well ,above is the Solution how to keep there hair .
If you like i can either remove the whole Thread or Term to make you happy .
If you take note on the 2nd picture ,i already filed back the whole cap to zero as i didn't intend to create a new Thread anywhere but then i said to my self ,Let's Help/Hint out other MB owners with this maybe they find some info useful.
Hopefully it's all good.
*My-600SEL-V12*
"VENI-VIDI-VICI"
post #8 of 21 (permalink) Old 03-23-2019, 05:52 PM
quakercity's Avatar
Date registered: Dec 2007
Vehicle: 1999 S600 & 1999 S500
Quoted: 104 Post(s)
Good thread!! Some people I guess do not have enough hair to lose! It is a common expression "pulling out your hair", due to frustration. I had a boss who pulled at his mustache hair, so it was always thin or missing in places. I like your idea for the added touch. I will pop the hood and look at mine in the AM when I take the cover off.
1999 S600 - 4 place
1999 S500 Grand Edition-Sold to good home!
1999 S500 - Deceased
quakercity is online now
post #9 of 21 (permalink) Old 03-23-2019, 09:16 PM Thread Starter
W140 Moderator
Merc-S600's Avatar
Quoted: 510 Post(s)
Well spoken Quakercity.
Only the Enthusiastic M120 Owners will find this Thread interesting enough . For the not so caring M120 owner or W140 owners that dont have a M120 powered W140, the black plastic Star is more then enough or even without the whole cover over the Power Steering reservoir ,there are many .
As for my own ,it has to be perfect with that extra touch .
Take for example the edge of the left & right engine covers over the Fenders , in between the Edge of the inner lower fender & the black plastic covering edge (looking at the engine sides) ,there is a small gap that shows something is missing like a weather strip or something ,yet there is nothing missing ,it's just ugly to look at ,i believe all W140's have this ugly space there.
I even covered that with something that looks better then factory to the eye & doesn't obstruct rain water flow or while washing the car .
I take a picture next time i have the hood up.
Here is that Space picture.
*My-600SEL-V12*
"VENI-VIDI-VICI"
post #10 of 21 (permalink) Old 03-24-2019, 08:59 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 233 Post(s)
My 94 coupe came with the chrome star, but the cover it was attached to was broken. I got a new cover with the black star, and transferred the chrome star to it.
Did any 600 come with the Mercedes Benz lettering in silver? Or was it added by owners.
jal1224 is online now
FS: MB Chrome Star Center Caps lynns For Sale/Wanted/Trade/Giveaway 2 07-01-2013 10:27 PM
Adsitco Chrome 5 star wheel opinions... 2mtrucks W123 E,CE,D,CD,TD,TE Class 10 01-13-2013 09:12 AM
FS: Chrome Star Airbag E-Class, C-Class, S-Class E-Klasse For Sale/Wanted/Trade/Giveaway 13 02-01-2008 11:57 AM
Where to get steering wheel chrome star insert? Carcus 98 ML W163 M-Class 14 02-07-2003 10:00 AM
