Camshaft Oilers Question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-11-2019, 06:23 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation Camshaft Oilers Question
My 1997 S/CL500 has the plastic Camshaft Oilers ( I assume, as i have not opened the Valve Cover Gasket to check). My question is, when is it recommended to replace them ? I would obviously replace them with the Aluminum Oilers.
NewYorkS600 is offline
post #2 of 4 (permalink) Old 03-12-2019, 08:12 AM
syljua's Avatar
Date registered: Sep 2004
Vehicle: 1998, C140, CL500
Quoted: 67 Post(s)
I would replace them, only if the lifters tick, as a sign of popped end.
I replaced mine with newer plastic parts 8 years ago. Still good (granted, in Norway we do not get the same high operating temperatures as elsewhere).
br,
syljua
C140 CL500 1998
W123 230E 1984
syljua is offline
post #3 of 4 (permalink) Old 03-12-2019, 08:31 AM
Premium Member
anziani's Avatar
Date registered: May 2008
Vehicle: '97 CL600
Quoted: 566 Post(s)
Premium Member
My original oilers on an E420 lasted 160K, then only 2 of them were bad. If you can find metal ones, OK but I don't fear the plastic ones at all.
Anziani
anziani is offline
post #4 of 4 (permalink) Old 03-12-2019, 03:55 PM
Date registered: Aug 2014
Vehicle: 1994 S500 and S320 W140
Quoted: 27 Post(s)
To answer your question. If they're ticking replace them. If you have to do anything involving removing the valve covers replace them. Keep in mind when you start removing parts that have gaskets you are going to get into the "Might As Well Zone" MAWZ.
You have this open so you might as well replace this, you have that off so you might as well replace that ect……..Not too expensive if you are DIY but it can become and obsession LOL
PC S class is offline
Camshaft position sensor solenoid magnet DIY atmsmshr W221 S-Class 19 06-27-2019 03:36 PM
Has anyone ever had to replace their balance shaft? Achped W203 C-Class 531 01-06-2016 04:41 PM
M117 Euro Camshaft Question jrogosich W126 S,SE,SEC,SEL,SD,SDL Class 3 08-20-2012 03:33 PM
President Bush authorized the leak MBZ300CD Off-Topic 79 04-10-2006 08:48 PM
