Loud Engine knocking noise !!! - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-24-2019, 04:15 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation Loud Engine knocking noise !!!
I haven't driven one of my cars for about 5 weeks, it's a 1997 S420, and when i started the engine, it started right up, but it made a very loud knocking noise for a while, and later it went away. Now when i start it up it does not make that knocking noise anymore, but when i open the hood, i can hear the engine being a bit louder than usual....like a light knocking noise. The car drives otherwise very good as always. What could be the issue with this knocking sound ?
NewYorkS600 is online now
post #2 of 7 (permalink) Old 02-24-2019, 08:35 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1233 Post(s)
Here is my theory of your problems.
Since it is cold in your area, you might have a summer blend of oil, so you might have popped the flat covers of your plastic CAM oilers. I would go in for a inspection, and for that you need to remove the valve covers, and look at each oiler for a missing cover. See this for a blown-oilier:
https://www.k6jrf.com/MB_lifter.html
While the valve covers are off, I would check the timing of the engine. Here is a thread :
https://www.benzworld.org/forums/r12...-end-work.html
If you find you have a really stretched chain, one does not need to pull the timing cover. You can get to the chronic chain guides except for one which is on the slack side which is the right. If you want to get to that one chain guide, you will need to remove the timing cover. Lift the engine as the upper oil pan needs to come out. A bigger mess to deal with...
https://www.benzworld.org/forums/w14...engine-v8.html
Hope this helps,
Martin
anziani likes this.
MAVA is offline
post #3 of 7 (permalink) Old 02-24-2019, 09:08 PM Thread Starter
Quoted: 134 Post(s)
Hope this helps,
Martin
Thank you Martin,
But i have replaced all the plastic cam oilers with the metal ones about 10,000 miles ago, and i have been using CastrolSyntec 10W-40 oil all the time. Chain guide has also been replaced at that time.
What do you think ?
post #4 of 7 (permalink) Old 02-24-2019, 10:19 PM
MAVA's Avatar
And the timing chain? Have you checked the timing? Was checked in the past?
It can be it is just too cold in your area.
I had a little knock for a M119 that has not been started in like 2 years, but lasted for a handful of minutes
Martin
MAVA is offline
post #5 of 7 (permalink) Old 02-25-2019, 06:26 AM Thread Starter
Quoted: 134 Post(s)
Martin
How do i check the timing chain ?
post #6 of 7 (permalink) Old 02-25-2019, 09:54 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 276 Post(s)
Try reading Martin's first post in this thread and the links he provided.
jal1224 is offline
post #7 of 7 (permalink) Old 02-25-2019, 04:18 PM
MAVA's Avatar
MAVA is offline
E 320,straight 6, versus V6 engine Viriato W210 E-Class 24 03-04-2018 06:19 PM
1968-93 North American MBZ Models MercedesFan1981 General Mercedes-Benz 2 05-24-2012 10:10 PM
Replacing your 404 engine with a new crate engine! Tips! Monstermog1964 Unimog 3 08-21-2009 08:47 PM
loud noise from right front of 1995 s320 engine sbk1s320 W140 S-Class 4 11-27-2008 11:04 AM
Long sucess history Zé Bocaina G-Class 3 05-27-2005 01:19 PM
