Wheel Alighnment with Self-Leveling System - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-24-2019, 09:16 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation Wheel Alighnment with Self-Leveling System
I have a 1997 S500 Coupe, and i plan to do a wheel alignment. Does the wheel alignment need to be performed with the engine running, as this keeps the Self-Leveling System active ? When the engine is off, i assume the rear lowers itself, and only when the engine is turned on the rear raises itself to the pre-set height. Also, i have just recently replaced the rear actuators and the rear struts, and have noticed that the rear is a bit higher than it used to be. What could be the cause ?
NewYorkS600 is offline
post #2 of 9 (permalink) Old 02-24-2019, 09:37 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 276 Post(s)
Unless your system is leaking, the height shouldn't change between engine running or not.
Assuming the self leveling valve was disconnected to bleed the system per factory procedures, it might not have been adjusted to where it was before. Whoever did it should have carefully marked the original position. Measure between the four rubber jack pads on the belly pan and the ground. If all four are equal, the height is set correctly. If the rear pads are more than maybe 3/16" higher or lower than the front, you need to adjust the self leveling valve accordingly. Check on level ground and bounce the front and rear up and down several times before measuring.
There is a factory procedure to check the ride height, but it requires special tools no one has, and is pretty esoteric to boot. It doesn't directly measure anything. Setting the jack pads equal takes care of the situation is the best we can do.
Watch the YouTube playlist that mercedessource did on the SLS. Ours is not identical, but it is close.
https://www.youtube.com/playlist?lis...68r59O9aIsWyGg
Jon
jal1224 is offline
post #3 of 9 (permalink) Old 02-24-2019, 09:49 AM Thread Starter
Quoted: 134 Post(s)
Jon
How would i know if the system is leaking ? Both rear SLS Struts and Accumulators are new. The original position of the self leveling valve was marked in red from the factory, and it was re-tightened in the same position.
post #4 of 9 (permalink) Old 02-24-2019, 10:02 AM
Quoted: 276 Post(s)
Does the height change after you shut off the engine? Are there any fluid leaks?
jal1224 is offline
post #5 of 9 (permalink) Old 02-24-2019, 10:17 AM Thread Starter
Quoted: 134 Post(s)
I will check when i turn off the engine. I do not see any Hydrolic Fluid on the floor, so i assume there is no leak, unless there is a leak and i do not see it.
post #6 of 9 (permalink) Old 02-24-2019, 04:08 PM Thread Starter
Quoted: 134 Post(s)
Exclamation
Here are a few pictures of both my rear tires. It looks to me a bit high. My question is if i do the wheel alignment first, and i adjust later the height of the SLS, will it affect the wheel alignment, such as camber and toe ?
ID:	2491782   Click image for larger version
post #7 of 9 (permalink) Old 02-24-2019, 05:29 PM
Quoted: 276 Post(s)
You need to measure at the rubber jack points. Coupes naturally set a little tail high with the rubber jack points at equal height.
Yes, ride height will affect the rear wheel alignment.
jal1224 is offline
post #8 of 9 (permalink) Old 02-24-2019, 05:44 PM Thread Starter
Quoted: 134 Post(s)
So you think i should lower first a bit the rear SLS, and the get the wheel adjustment ?
post #9 of 9 (permalink) Old 02-24-2019, 05:47 PM
Quoted: 276 Post(s)
For the third time, do the measurements, and ONLY adjust if they are off. That is the only thing that will tell you the correct information. You can't tell anything from the wheel wells.
jal1224 is offline
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Mercedes Intelligent Navigation System carweapon For Sale/Wanted/Trade/Giveaway 0 08-31-2012 05:42 PM
Code Help! jporrata W202 C-Class 10 07-31-2009 08:02 PM
ML63 introduced at 2005 Frankfurt Auto Show GregW / Oregon W164 M-Class 8 09-16-2005 09:11 AM
