Winshield Wiper Fluid Light - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 12-30-2018, 04:31 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation Winshield Wiper Fluid Light
The windshield wiper fluid light is on , and even when i refill the reservoir with fluid, it still does not go off. What could be the issue ?
NewYorkS600 is online now
post #2 of 13 (permalink) Old 12-30-2018, 04:47 PM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 276 Post(s)
Asked and answered many times over. Use search.
jal1224 is offline
post #3 of 13 (permalink) Old 12-31-2018, 06:07 PM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
Quoted: 478 Post(s)
Are you sure the fluid is not leaking on the floor?
It could be a faulty sensor too.
hamada128 is offline
post #4 of 13 (permalink) Old 12-31-2018, 06:14 PM
quakercity's Avatar
Date registered: Dec 2007
Vehicle: 1999 S600 & 1999 S500
Quoted: 119 Post(s)
The level sensor is bad. About $25-$30 from Autohauz or Pelican. Do a search of the forum for how to change it. You have to remove the headlight wiper and the headlight. Plan on about 1-3 hours with stops to refer back to the forum thread. Print it so you can refer to it outside. Look at the headlight rubber molding. If it needs to be replaced get it from some of the online MB dealers for about $50. Replace it while you are in there. If you wait long enough the radiator level sensor light will also come on. They are on the same circuit.
I am about to change mine for the second time. This time I will change the headlight moulding. If it bothers you, put electrical tape over the light until you change it.
1999 S600 - 4 place
1999 S500 Grand Edition-Sold to good home!
1999 S500 - Deceased
quakercity is offline
post #5 of 13 (permalink) Old 12-31-2018, 09:40 PM Thread Starter
Quoted: 134 Post(s)
Could it be that just the connection got loose and it just needs to be reattached ?
post #6 of 13 (permalink) Old 01-01-2019, 03:32 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1088 Post(s)
Take a look.
Sent from my XT1710-02 using Tapatalk
Jayare is offline
post #7 of 13 (permalink) Old 01-01-2019, 07:47 AM
Date registered: Mar 2017
Vehicle: 97 S600 Coupe. Former 83 300D, 97 C230, 93 400E, 92 500SL, a few others
Quoted: 84 Post(s)
Yep!
Coolant light was on a couple months ago, level fine, bought the sensor, no luck, figured out they are on the same circuit. Washer level sensor next. Is this in a sticky? Should be, replace both at same time.
2 97 600s with the same intricate issue in the same 3 month span. Parts life-cycle age as a constant, anyone? This is a good lesson for anyone who believes that mileage is more important than age in estimating pre-purchase potential repaiss - age is equally important, if not more so!
How many miles on yours, NY? Are you the one I sold my old wheels to?
will_c140 is offline
post #8 of 13 (permalink) Old 01-01-2019, 09:08 AM Thread Starter
Quoted: 134 Post(s)
I have about 75000 on my 1997 S600. I do not believe that i have bought any wheels from you. I have the AMG Aeros on my sedan.
On my car the coolant light is not on and functions properly; it's just the windshield wiper fluid light which is on.
post #9 of 13 (permalink) Old 01-01-2019, 02:45 PM
quakercity's Avatar
Quoted: 119 Post(s)
It could be loose, but you still have to remove the headlight to get to it and check the connection. You are looking at 1-3 hours. You may as well change it while you are in there.
1999 S600 - 4 place
post #10 of 13 (permalink) Old 01-01-2019, 05:41 PM
Quoted: 84 Post(s)
So I've got 184k, you've got 75k, and both ours failed within 3 months of each others. I was just making a general point about how age is every bit a factor as mileage, people pay up for low-mile cars but the reality is most of these components fail with age. 21 year lifespan! Wow. But yeah, case closed, replace both sensors because they're cheap and you're gonna be in there anyway.
