Steering wheel shake - Mercedes-Benz Forum
LinkBack Thread Tools
Old 02-11-2018, 08:16 PM Thread Starter
nhzruthless818's Avatar
Date registered: Jun 2008
Vehicle: 1997 S500V, 1999 S500 grand edition, 2006 s65 amg
Quoted: 131 Post(s)
Alright guys. How is everyone doing? On my new w140 98 s500 (120k miles) i have horrible steering shake from 30-70mph but the shake is only in the steering wheel. Lower ball joints and tierods new oem. Shocks are new. Tires balanced. Suspension feels tight. No movement in the suspension. Rear shock mounts are shot (shocks are good, accumaltors are new system is bleed and everything in the rear is new) engine mounts and tranny mount are shot aswell.
nhzruthless818 is offline
Old 02-12-2018, 01:19 AM
samosali's Avatar
Date registered: Nov 2007
Vehicle: W140 Mercedes 500 SE, 1992, European, 410.000 km
Quoted: 269 Post(s)
upper control arm(s) !!!! especially if vibrations are induced when you hit a hole or something on a road.
All I wish for Christmas is a smooth idle.
samosali is online now
Old 02-12-2018, 07:01 AM
Date registered: Mar 2017
Vehicle: 97 S600 Coupe. Former 83 300D, 97 C230, 93 400E, 92 500SL, a few others
Quoted: 84 Post(s)
Fighting a slightly different yet similar issue; have you seen my thread?
https://www.benzworld.org/forums/w140...t-go-away.html
will_c140 is offline
Old 02-12-2018, 09:10 AM
Premium Member
anziani's Avatar
Date registered: May 2008
Vehicle: '97 CL600
Quoted: 566 Post(s)
Premium Member
Thought I would throw this into the mix: I had a vibration at about 45MPH. Since I had my car at the transmission shop for a new conductor plate, I mentioned it to the shop foreman. He came back with a "torque converter" problem. Sure enough, we pulled codes (P0809) and got a "torque converter" code. I was doubtful because the transmission in my car is so smooth it is hard to tell when it shifts or what gear I'm in. Went to America's Tire to have the front balance checked and found two worn front tires. Changed them out and rebalanced but still have an almost imperceptible wobble at 45MPH. Have not had time to reset the code to see if it returns.
Anziani
Nate D. Rector likes this.
anziani is offline
Old 02-12-2018, 09:37 AM
Nate D. Rector's Avatar
Date registered: Aug 2016
Vehicle: 99 s320 member since 2009 fastest time 14.6 1/4 mile nitrous.
Quoted: 108 Post(s)
stock 16" wheels bend easy
Nate D. Rector is offline
Old 02-12-2018, 03:39 PM Thread Starter
Quoted: 131 Post(s)
I have 16 18 and 19 they all shake lol. But you do not feel the shake on the chassis. You only feel the steering wheel going shaking. Transmission is good no faults. I have new upper control arms in my trunk lol
Old 02-12-2018, 11:21 PM
samosali's Avatar
Quoted: 269 Post(s)
so open the trunk ...
Old 02-12-2018, 11:53 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1095 Post(s)
What?
Sent from my XT1080 using Tapatalk
Jayare is online now
Old 04-04-2018, 01:33 PM
Date registered: Apr 2018
Vehicle: 1995 S420
Could a steering dampener be a culprit? The reason I'm asking is because I get vibration around 65MPH in steering wheel, but it is manageable.
Joe-V12 likes this.
doctorcheetos is offline
Old 04-04-2018, 02:57 PM
Quoted: 84 Post(s)
Been replaced. Got word today but rear bushings on the front lower control arms are split. Ill have it back Friday. Ask me then if It improves
Sent from my BBB100-1 using Tapatalk
