1997 S500 Difficult Starting (video!) - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 07-08-2017, 08:35 AM Thread Starter
Date registered: Jul 2007
Vehicle: 2002 CL500, 2001 S500, 1997 S500, 1999 S320, 2005 ML500, 2005 CLK320, 2009 BMW 535xi, & 1975 Midget
Quoted: 28 Post(s)
ave a tough time starting her. It sounds like the starter is stuck. I'll crank it a few times and she'll eventually start, but runs really rough. I get error codes indicating misfires on a few coils on the left side of the engine.
If I turn her off, and wait a second before restarting her... she runs like new! No issues and no strange sounds.
I thought with a '97, I'd be free from the biodegradable wire insulation issues, but I'm probably wrong. I'm guessing my starting issue and rough running might be a grounding issue.
Thoughts? I'd really appreciate any help!!
Snipersking likes this.
MercedesMikeNAtlanta is offline
post #2 of 23 (permalink) Old 07-08-2017, 09:02 AM Thread Starter
Quoted: 28 Post(s)
Here's the video. It wouldn't let me drag it into the above post.
post #3 of 23 (permalink) Old 07-09-2017, 09:09 PM Thread Starter
Quoted: 28 Post(s)
Really could use some guidance on this one.
Anyone??
post #4 of 23 (permalink) Old 07-09-2017, 09:32 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1255 Post(s)
Anyone??
Your video says Private
Martin
MAVA is offline
post #5 of 23 (permalink) Old 07-10-2017, 04:37 AM
rikana's Avatar
Date registered: Feb 2011
Vehicle: W140 S320 1998
Quoted: 9 Post(s)
yup....nothing to be seen there
rikana is offline
post #6 of 23 (permalink) Old 07-10-2017, 12:16 PM Thread Starter
Quoted: 28 Post(s)
So Sorry. Somehow it was set to private.
It should now work. Please take a look and let me know what you think!!!!
Thanks!
post #7 of 23 (permalink) Old 07-11-2017, 07:46 AM
Joe-V12's Avatar
Date registered: Jan 2014
Vehicle: MY96 S500 & MY96 S600
Quoted: 551 Post(s)
If only misfire codes then fuel pressure/fuel pump?
Seems to crank faster than my S420 or S500 but hard to tell over a video.
Previous: MY97 CL600, MY92 600SEL, MY98 S420, MY96 S280 x2
Joe-V12 is offline
post #8 of 23 (permalink) Old 07-11-2017, 08:07 AM
Joe-V12's Avatar
Quoted: 551 Post(s)
BTW the KS wiring and CAS wiring is suspect on the late model cars, but it will show up as a respective error code.
Joe-V12 is offline
post #9 of 23 (permalink) Old 07-11-2017, 01:05 PM Thread Starter
Quoted: 28 Post(s)
KS and CAN wiring? Can you please elaborate?
Thanks!
COuld this be a weak battery that's not powerful enough to keep the starter moving??
post #10 of 23 (permalink) Old 07-11-2017, 01:13 PM
~BANNED~
Date registered: Jan 2016
Vehicle: n/a
Quoted: 349 Post(s)
Joe is very versed with these cars. He forgets that other members are not so good with the acronyms.
KS = knock sensor
CAS = crankshaft angle sensor, aka, CPS = crankshaft position sensor.
Unlikely to be your problem.
Steve
PS Checking battery voltage is easy. You need well over 12 V with no load. When the starter motor is energized, huge load is placed, but the voltage should not dip below 10V. I went through a starter ordeal myself not too long ago:
https://www.benzworld.org/forums/w140...ont-turn.html?
Steve_B is offline
