Head gasket or not ???? - Page 3 - Mercedes-Benz Forum
post #21 of 29 (permalink) Old 05-16-2018, 11:07 AM
Date registered: Jan 2009
Vehicle: 1996 Mercedes-Benz S320L
Quoted: 25 Post(s)
UPDATE
I bypassed the oil cooler, flushed the cooling system and drove for like a 1000 kilometers. Unfortunately the oil returned to the coolant reservoir so it's definitely the head gasket. I took the car to a trusty Mercedes mechanic and he removed the head, and we can tell that the head gasket has never been replaced before.
Name:	Head gasket 2.jpg
ID:	2427499   Click image for larger version
Name:	Head gasket 3.jpg
MAVA and Joe-V12 like this.
1992 Mercedes-Benz W140 300SEL 285XXX Km.(SOLD)
1996 Mercedes-Benz W140 S320L 192XXX Km.
1995 Mercedes-Benz W140 S500 110XXX Km.
mike300sel is offline
post #22 of 29 (permalink) Old 05-16-2018, 11:11 AM Thread Starter
Snipersking's Avatar
Date registered: Sep 2011
Vehicle: W140 1998 S320
Quoted: 31 Post(s)
Originally Posted by mike300sel View Post
UPDATE
The head looks good though I hope itís just this no further issues.
MAVA and mike300sel like this.
Snipersking is offline
post #23 of 29 (permalink) Old 05-16-2018, 11:22 AM
Quoted: 25 Post(s)
Originally Posted by Snipersking View Post
The head looks good though I hope it’s just this no further issues.
I was a little surprised of how clean the engine looks even after doing nearly 200k kilometers (125000 miles). The pistons have just a small amount of carbon deposits and the valves looks clean too. I guess it has to do with how clean the petrol is in Germany and Denmark, since these are the 2 countries where the car has spent its life.
Let's hope that the head checks out to be fine when the machine shop is done with pressure testing and resurfacing. To bad we have to wait until the end of this month because they are closed for a holiday, and my mechanic would not deal with other shops because he only trust these guys.
MAVA and Snipersking like this.
post #24 of 29 (permalink) Old 05-16-2018, 11:27 AM Thread Starter
Quoted: 31 Post(s)
Great to hear that, looking forward to see the engine running ok with no milkshake.
MAVA likes this.
post #25 of 29 (permalink) Old 05-16-2018, 07:54 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1225 Post(s)
MAVA is offline
post #26 of 29 (permalink) Old 05-16-2018, 11:46 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
The engine will look clean because the coolant was cleaning it. That's the only good thing that happens when you have a bad head gasket.
Joe-V12 likes this.
illstplaya is offline
post #27 of 29 (permalink) Old 05-17-2018, 09:00 AM
Quoted: 25 Post(s)
@MAVA
Thank you for the links. I don't believe it's that hard to replace the head gasket on the M104. Infact, I was going to do it by myself, but I live in an apartment, so I would have to do it on the street, and my neighbors are already fed up with me and my brother working on our cars in the parking lot . Besides, I might need some tools that I can't have access to since I would be working on the street, like an air compressor etc.
@illstplaya
That's true, but my car was not smoking so there is no coolant in the combustion chamber, nor in oil. The car was driving fine with no problems whatsoever (no coolant loss, misfires or overheating). I even discovered it by coincidence when I was checking the oil and coolant level as I always do every 2-3 weeks.
MAVA likes this.
post #28 of 29 (permalink) Old 05-17-2018, 04:04 PM
Date registered: Oct 2011
Vehicle: 1998 S320LWB
Quoted: 54 Post(s)
It is my understanding that the head of an M104 should not be resurfaced. if overheated head likely needs to be replaced. If not just new head gasket should fix it up. That is what a senior MB tech told me many years ago.
Seth
Snipersking likes this.
shimshon is offline
post #29 of 29 (permalink) Old 07-02-2018, 06:45 PM
Quoted: 25 Post(s)
Update:
I got the car a while back and it has been driving fine with no more mixing. The mechanic did clean the cooling system, but there are still some traces of oil. I will be removing the radiator and the coolant reservoir to give them a thorough cleaning. Will probably change the hoses too. But before I do all of this I want to flush the system, and upon some search, I found out that using some engine degreaser with the coolant would dissolve all of the oil emulsion, but I don't want to risk damaging the new head gasket, cylinder head, water pump and radiator etc. Anybody knows if this would be harsh on engine and cooling system?
Using washing detergent is out of the question because I already tried it before the head gasket replacement and my water pump started leaking after a while, and the radiator started leaking too, but those where original 20 year old parts that probably needed to be changed, but who knows if the detergent had anything to do with it or not..
