The definitive W140 suspension thread? - Mercedes-Benz Forum
post #1 of 48 (permalink) Old 12-24-2015, 12:38 PM Thread Starter
ch.1953's Avatar
Date registered: Jul 2009
Vehicle: M120, M119, W126*2 + Silver Avantgarde wagon
Quoted: 221 Post(s)
Having owned a few 140's now, one common problem is always setting up the rear suspension to ride as soft and well as we know W140's actually can...
This is a non trivial issue as in many ways when you consider the W140 ride, when correct, is better than anything else out there, as it was designed to literally insulate the passenger compartment from road imperfections. By comparison, many modern cars want you to feel the road. (?) On a Ferrari this is fine, but in a true Mercedes S class car do you really want to "feel" the concrete road. The W140 personifies (or should personify) wafting above it all...
So perhaps we can create a W140 suspension thread and have all of you experts contribute your expertise to help us solve this issue once and for all.
Thanks to MAVA and others we have the transmissions pretty much down...
Everyone initially says accumulators, but while that is necessary, in my experience it never completely fixes it on W140's over 100,000 miles, and often on cras with less miles than that. As you will see from the links below it is much more complex than that, especially on ADS systems.
The M120's have the ADS system. Which years have ADS I and which years have ADS II?
So I am endeavouring to put some links here and share a few experiences:-
1. - If you don't change the accumulators quick enough that can trash your shocks (expensive consequential failure)
2. - If the car is old, you may need to check / replace the sub frame bushings as well as all the normal bushings and suspension parts...
3. - through a forum member I found a W140 specialist in Canada who advised me that the 140 suspension actually has, in his view, many many small adjustments and he walked his talk and as a result my 1999 coupe then suddenly rode sublimely. It was an astonishing difference over how it was before. The dealer had replaced almost all the rear suspension and it still rode crap and this lovely man did nothing but spend a couple of hours tweaking the settings...
We should have him do a fly / road trip down to see us guys...
4. - Here is one of the best quotes I ever found from an ADS expert (see the link below):- "I was not satisfied with the ride quality of my car. It should have been much softer than it was. It always felt too firm. I also could not feel a difference between the Sport and Comfort modes, which pointed to a problem. To test your car, start it up, and select Sport mode. Push down on each corner as if testing the shocks. There should be give, but it should feel pretty stiff. With the car still running, select the Comfort mode. Again, push down on each corner of the car. You should feel much more bounce now. If you don't, you have a problem."..."My saga to understand this system began last year. There is surprisingly very little information on the web about the details of this system, and a wealth of downright inaccurate info out there as well. This page [see links below] attempts to describe the ADS system, how I diagnosed my vehicle's system, and what I ended up doing."
Also I have now been to many independents and several dealers and so far no one can fix it the way he did... most in fact tell me there is nothing wrong, especially at the dealers - which is absolute nonsense. I have driven the 140 set up right and it is astonishingly good. Although to be fair most of their more recent techs know very little about the details of 140's. And of course few 140's come in to them.
So I hope the following helps us all:-
I personally now suspect the pump not being perfect or the 1 (or is it 3?) valves on the rear ADS suspension not being right can be factor. And I repeat with every W140 I have had replacing the accumulators, while necessary, is nowhere near enough to get that amazing ride they had when they first came out of the showroom.
I think these are some of the key links - but they no seems to longer work? - Arrgh!
v12uberalles.com
v12uberalles.com
Does anyone have the print off of these they can share? WOULD BE GOLD!!
Ah ha - I found one link to some of it that works - EUREKA!!!
V12 Uber Alles, Repairing a Broken Self-leveling Valve Linkage in a W140 Mercedes Benz
Whoppee - YAY - there's more:-
V12 Uber Alles, Repair Help for Mercedes Benz S600 V12 W140
V12 Uber Alles, Diagnosing the Adaptive Damping System (ADS) in a Mercedes Benz S600
V12 Uber Alles, Changing the Rear Struts in a W140 Mercedes Benz
V12 Uber Alles, Replacing Accumulators (aka Spring Actuators, Nitrogen Spheres) in a W140 Mercedes Benz
V12 Uber Alles, Articles and Info Page
How good are those finds ^ - WOW!!!
Have also found this :-
ADS Tech
ADS Tech Main
http://www.qclt.com/train/w202/w202/...ntrol/ads2.htm
ADS I
http://www.qclt.com/train/w202/w202/...ersysfunct.htm
http://www.qclt.com/train/w202/w202/...l/driveads.htm
http://www.qclt.com/train/w202/w202/...l/tandpump.htm
http://www.qclt.com/train/w202/w202/...ol/hydcomp.htm
http://www.qclt.com/train/w202/w202/...trol/vunit.htm
http://www.qclt.com/train/w202/w202/.../levvalves.htm
http://www.qclt.com/train/w202/w202/...ol/suselem.htm
http://www.qclt.com/train/w202/w202/...dampvunits.htm
http://www.qclt.com/train/w202/w202/.../electcomp.htm
http://www.qclt.com/train/w202/w202/...estrepproc.htm
ADS II
http://www.qclt.com/train/w202/w202/...s2_modcomp.htm
http://www.qclt.com/train/w202/w202/...ads2_funct.htm
http://www.qclt.com/train/w202/w202/.../ads2_comp.htm
http://www.qclt.com/train/w202/w202/...s2_taskben.htm
http://www.qclt.com/train/w202/w202/...2_drivinfo.htm
http://www.qclt.com/train/w202/w202/...2_features.htm
http://www.qclt.com/train/w202/w202/..._functsurv.htm
http://www.qclt.com/train/w202/w202/...s2_testrep.htm
So here are, as an example, 11 pages of our Benz World brothers trying to understand the ADS, but without the benefit of all of the above links:-
https://www.benzworld.org/forums/w140...-any-more.html
and also, here:-
http://www.mbclub.co.uk/forums/merce...ts-around.html
And more folks worried about harsh ride:-
https://www.benzworld.org/forums/w140...ds-600sel.html
https://www.benzworld.org/forums/w140...ion-stiff.html
https://www.benzworld.org/forums/w140...too-harsh.html
https://www.benzworld.org/forums/w140...n-stiff-2.html
And please enjoy what these fantastic cars should be able to do:- NO HARSHNESS HERE:-
Anyone who can master these W140 and C140 suspensions is truly valuable to our Mercedes enthusiast community.
I hope the above links are helpful to many, if not all of us.
To smoother motoring, the way the 140s were intended...
kevinpuri, MAVA, Merc-S600 and 2 others like this.
ch.1953 is offline
post #2 of 48 (permalink) Old 12-24-2015, 03:30 PM
Rupununipete's Avatar
Date registered: Sep 2011
Vehicle: 1992 600 SEL x 3, 1998 E430, 2002 E320T 4matic, 1971 300SEL 3.5 project plus 4 more W108, etc
Quoted: 94 Post(s)
Nice Christmas present Rich. I will open it boxing day when I hope to have time to soak it in.
Have a good one!
Pete
ch.1953 likes this.
Rupununipete is offline
post #3 of 48 (permalink) Old 12-24-2015, 03:46 PM
4liter's Avatar
Date registered: Apr 2006
Vehicle: 1994 S420
Quoted: 96 Post(s)
Send a message via Skype™ to 4liter
Thanks for the helpfulness :sunglasses:
ch.1953 likes this.
4liter is offline
post #4 of 48 (permalink) Old 12-24-2015, 06:06 PM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1225 Post(s)
Ricardo,
You have gone nuts....
It would have taken me three hours to type that as all I do is Peck-At-The-Keyboard. I have dyslexia to try to learn to type...
I just live with the hard suspension. Maybe wee need to leave some air in your SLS.
Martin
anziani and ch.1953 like this.
MAVA is offline
post #5 of 48 (permalink) Old 12-25-2015, 02:29 AM Thread Starter
ch.1953's Avatar
Quoted: 221 Post(s)
Thanks gents, yes I am excited about this information...
In my view one of the most special things about the 140 is the very, very unique suspension, so this should help us. I can't wait for you Pete and everyone to dig in and see how much help there is in here ^.
This is only reinforced by the fact there is no longer a purely financial business case for MB to train techs to be complete experts in this matter.
Certainly my 140 suspension experience at the MB dealer supports that their (MB) business analysis matches mine.
MB Classic Center perhaps...
ch.1953 is offline
post #6 of 48 (permalink) Old 12-25-2015, 08:10 AM
Premium Member
anziani's Avatar
Date registered: May 2008
Vehicle: '97 CL600
Quoted: 563 Post(s)
Premium Member
Rich,
I've turned this info over to Ruben, my mechanic and told him there would be a 3 hour written test on January 6.
Anziani
quakercity, ch.1953 and JLCampbell like this.
anziani is offline
post #7 of 48 (permalink) Old 12-25-2015, 10:25 AM Thread Starter
ch.1953's Avatar
Quoted: 221 Post(s)
Originally Posted by anziani View Post
Rich,
Anziani
Well, it is probably no understatement to say who ever passes the test with 90% - 95% of information accurately understood will get a great deal of business...
For now that I have (only once) ridden in a decent 140 suspension I know why so many people raved about...
Please give my regards to Ruben!
ch.1953 is offline
post #8 of 48 (permalink) Old 12-26-2015, 09:46 AM Thread Starter
ch.1953's Avatar
Quoted: 221 Post(s)
On my next trip north ;-) I'm going to go visit again or call the MB Classic car center and see when they could do a diagnosis of my ADS now that 140's are registered classics with them.
Would be great if they actually have the necessary expertise to in say an hour or two check the whole system and say definitively this, this and that is what you need.
HAPPY XMAS!
ch.1953 is offline
post #9 of 48 (permalink) Old 12-26-2015, 07:11 PM Thread Starter
ch.1953's Avatar
Quoted: 221 Post(s)
This is thanks to Anziani - a great gentleman!
Thank you Anziani
MAVA likes this.
ch.1953 is offline
post #10 of 48 (permalink) Old 12-26-2015, 07:31 PM
MAVA's Avatar
Need to soak this stuff Ricardo...
Great post! This last document is excellent!!
Martin
ch.1953 likes this.
MAVA is offline
