235/40/18 ET+35 work on 96 coupe s600? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-25-2014, 11:55 AM Thread Starter
Date registered: Aug 2006
Vehicle: 1996 S600 Coupe
Quoted: 12 Post(s)
Hello Guys I came across a set of mercedes wheels with et+35 235/40/18 tires and was wondering if this et is close to the original? WIll these fit? Thanks in advance Nel
porshapower is offline
post #2 of 8 (permalink) Old 07-25-2014, 02:43 PM
4liter's Avatar
Date registered: Apr 2006
Vehicle: 1994 S420
Quoted: 96 Post(s)
Send a message via Skype™ to 4liter
Yes they'll fit and that's from a stock 44 et 16x8 235.60.16 inch wheel and tire...35 et is the limit...millimeters make a difference...
Sean
In three words I can sum up everything I've learned about life: it goes on.
Robert Frost
4liter is offline
post #3 of 8 (permalink) Old 07-25-2014, 02:45 PM
Outstanding Contributor Always Remembered RIP
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 150 Post(s)
The tires will be too small, they should be 255 x 45 x 18
4liter likes this.
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #4 of 8 (permalink) Old 07-25-2014, 02:52 PM
4liter's Avatar
Vehicle: 1994 S420
Quoted: 96 Post(s)
Yeah they would be small they'll most certainly fit...255.45.18 is what I use for the rear with 35 et...I wouldn't use them on my coupe in the front...still looking for 225 or 235.45.18 to replace the 245.50.18 currently on my car...scrubbing is there...just more due to right side fender liner is buckled...still SMH...oh well
Sean
Robert Frost
4liter is offline
post #5 of 8 (permalink) Old 07-25-2014, 06:46 PM Thread Starter
Quoted: 12 Post(s)
Thank You guys! Couple of questions...when you say you would not use them on your coupe?..why? will they rub? Other question....you said 35 et is max...and 44 is factory. Will the 35 rim sit deeper into the fender well or stick out of the fender well. I dont understand what this et measurement is... Thanks again.
post #6 of 8 (permalink) Old 07-25-2014, 07:11 PM
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: "CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Quoted: 521 Post(s)
On the pic below you see the ET35 ,they will be flush with the rear fender & fronts ,no rubbing at all ,only probs you will have is the small tyre on them ,ad like other have mentioned earlier the 255 /40/18 ,rear 275 /35-40/ 18 .
Read this threat ,most info was added there recently ,page 3 has more pics & info on tyre sizing etc .
https://www.benzworld.org/forums/w140...ook-right.html
4liter likes this.
*My-600SEL-V12*
"VENI-VIDI-VICI"
"I came-I saw-I conquered".
Driving a W140 & everything else feels like is standing still .
Everything you like to know about the W140's
Merc-S600 is offline
post #7 of 8 (permalink) Old 07-25-2014, 07:34 PM Thread Starter
Quoted: 12 Post(s)
Thank you for the reply and the pic. I really like it flush.... Thanks for the link and beautiful car you have love the color! Thanks again.
Merc-S600 likes this.
post #8 of 8 (permalink) Old 03-23-2019, 07:07 PM
Date registered: Aug 2010
Vehicle: 1997 S600 and 1997 CL500
Quoted: 134 Post(s)
Exclamation
My right side fender lining is also buckled a bit, and when i turn the steering wheel all the way to the right, the 255-45-18 tire rubs against it. Is there a way to correct the buckled inner fender lining ?
NewYorkS600 is offline
