S600 camshaft sensor error after changing timing chain - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-23-2013, 12:44 AM Thread Starter
Date registered: Apr 2012
Vehicle: 1995 S600
Hi,
I changed my timing chain on my 95 S600. Now I started the engine a few times, but the engine shakes. I connected a diagnosis software and this shows up a failure on both camshaft sensors. I already changed the sensors with another pair, but the error ist still there. I double checked the chain position with the pins on each camshaft during the reassembly.
Could there a possible slip of the chain by one tooth due to the chain tensioner on the first start? Is there a way to check this without remove everything from the top of the engine to see the camshaft again
Thanks, Kerrman
kerrman is offline
post #2 of 5 (permalink) Old 11-23-2013, 06:28 AM
Date registered: Jan 2013
Vehicle: 96 S500, 98 Celsior
Quoted: 29 Post(s)
I knew a guy who were saying something similar. He was insisting that he did the job properly. Yes, he did very well for the timing chain but he made a mistake inserting the spark plug cables to the distributor properly.
I hope you are not like him.
Yamae is offline
post #3 of 5 (permalink) Old 11-23-2013, 06:47 AM Thread Starter
Vehicle: 1995 S600
Originally Posted by Yamae View Post
Yes, he did very well for the timing chain but he made a mistake inserting the spark plug cable to the distributor properly.
He had also a L5/3 camshaft sensor error? Only because of a missing spark?
That sounds interesting. But I can't explain why a "cylinder misfire" should occur a camshaft sensor error.
kerrman is offline
post #4 of 5 (permalink) Old 11-24-2013, 01:45 AM
Quoted: 29 Post(s)
I never wrote misfire. I should have written spark plug cables.
Wrong firing order caused the problem.
Yamae is offline
post #5 of 5 (permalink) Old 11-24-2013, 03:06 AM Thread Starter
Vehicle: 1995 S600
Thanks for your response. I misread your sentence.
kerrman is offline
