35mm lowering springs and shims ??? - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 04-25-2019, 07:44 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 270 Post(s)
Originally Posted by Snipersking View Post
S320 1997 Conventional
You may have a broken spring coil(s). That increases the spring rate. And when you jack the car, the spring ends can sometimes lock together temporarily, depending on the break.
Did they replace the shocks with OE parts? Are there any rattles or bangs going over bumps? Has the ride always been rough, or something that just happened?
Snipersking likes this.
jal1224 is offline
post #12 of 19 (permalink) Old 04-25-2019, 10:22 AM
Snipersking's Avatar
Date registered: Sep 2011
Vehicle: W140 1998 S320
Quoted: 31 Post(s)
I donít believe so the suspension has been inspected several times nothing is broken and no rattling or whatsoever, the Shocks are OE and this roughness started gradually.
Sent from my iPad using Tapatalk
Snipersking is offline
post #13 of 19 (permalink) Old 04-25-2019, 01:47 PM
Quoted: 270 Post(s)
You sure you don't have SLS? Sure sounds like accumulators going bad.
jal1224 is offline
post #14 of 19 (permalink) Old 04-25-2019, 01:49 PM
Quoted: 31 Post(s)
I am sure no SLS
post #15 of 19 (permalink) Old 04-26-2019, 01:33 PM
Quoted: 270 Post(s)
I am sure no SLS
Have you checked the front and rear subframe to body mounts? If they've collapsed, you will get a lot of harshness transferred to the body.
jal1224 is offline
post #16 of 19 (permalink) Old 04-26-2019, 03:45 PM
Quoted: 31 Post(s)
I thought that one first, but the are fine, they are not hard even, tomorrow am going to replace the shimes and I will post the result.
Wish me luck
post #17 of 19 (permalink) Old 04-28-2019, 05:41 AM
Quoted: 31 Post(s)
Yesterday I installed the new shimes but with little improvement, I wonder why the hell front suspension is still stiff !!!
post #18 of 19 (permalink) Old 04-28-2019, 07:33 AM
Quoted: 270 Post(s)
Inspect the lower front wishbone inner bushings, front and rear. If they appear to be off center, bulging, or lopsided, replace them. The rear ones are fluid filled, and can rupture if old, or improperly installed. Both front and rear bushings must also be installed in the control arms with a particular orientation. New replacement arms have been known to have the bushings improperly oriented. There are instructions in the DIY section.
Disconnect the upper control arm from the spindle. You should be able to move it up and down by hand against the resistance of the bushings. If it or the upper ball joints are frozen, replace the arms. If the upper ball joints are split, but the joints are still good, you can replace just the boots with ones from a Porsche 928. Do a search here for a pictorial on how to do it. While the upper control arm is disconnected, make sure you can move the spindle assembly pivoting on the lower ball joint. If the lower ball joint is frozen or extremely difficult to move fore and aft or in and out, replace it.
Make sure the sway bar body mount bushings are good. They should be considered a wear item and periodically replaced. They can wear so badly as to create metal to metal contact.
jal1224 is offline
post #19 of 19 (permalink) Old 04-28-2019, 12:14 PM
Quoted: 31 Post(s)
Bro believe it or not all the components you have mentioned were replaced but I think the mechanic did something wrong
