Photo DI'M'- P/S Pump Overhaul IN SITU Method a la llast993 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-15-2012, 01:57 PM Thread Starter
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Quoted: 154 Post(s)
I owe a Huge thank you and shout-out to SDHOW, for so aptly pointing out my tiny "Oooops" on my original Powersteering Pump overhaul. I had placed the Impeller Base in UPSIDE DOWN, so there was a "Beveled" edge up against the Circlip, rather than the FLAT edge.
Actually, it was a blessing in disguise.... the Previous Overhaul set (non-OEM), was already showing some signs of rubber break-down, so I am very thankful I purchased a OEM M-B Overhaul set.
This post is dedicated to llast993, who so cleverly "invented" this Non-WIS version of Pump Overhaul.
As always, this is "For Entertainment Value ONLY", and is not intended to be used a repair guide.
G
ID:	438218   Click image for larger version
ID:	438219   Click image for larger version
ID:	438220   Click image for larger version
ID:	438221   Click image for larger version
ID:	438223   Click image for larger version
ID:	438224   Click image for larger version
ID:	438225   Click image for larger version
ID:	438226   Click image for larger version
G-AMG is offline
post #2 of 3 (permalink) Old 04-15-2012, 02:00 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
part 2
ID:	438228   Click image for larger version
ID:	438229   Click image for larger version
ID:	438230   Click image for larger version
ID:	438231   Click image for larger version
ID:	438233   Click image for larger version
G-AMG is offline
post #3 of 3 (permalink) Old 06-15-2019, 04:10 PM
Date registered: Jun 2017
Vehicle: 98 S420 & 12 S5504M
Power steering pump seals - additional items FYI
Just did my old '98 S420 - THANKS to all for the info, really appreciate it! First, an important add. It says, urgently, right after your repairs to turn the steering wheel all the way left then all the way right 30 times (!) BEFORE starting the engine to avoid air bubbles into the rack & system. I did, no issues. Secondly, I broke the circlip getting it off and any spare part of this DOES NOT EXIST. For W140's you will have to find 90's MB's or BMW's with (in my case) ZF pumps and get the circlip out of one of those (I did, at a junkyard). It's a shame to disassemble a pump just for this clip, but it is non-stock clip size. Otherwise, you'll have to buy a reman'd unit. Finally, I bent the circlip getting that one off, I think you need to use 3 small screwdrivers to first get it in the back across from the gap, then work it both sides forward from that. Trying to pull it off the back opens it up too much coming off the shaft.
I searched EVERYWHERE for a circlip, it MAY be available in a BMW rebuild kit in which they include the circlip with the new seals. I ordered it but it hasn't come in and I'll not accept it now, but maybe I'll go look just to verify it exists that way ($40-50 for their kit!). Thank you.
Name:	power steering circlip.jpg
TOLW221 is offline
Photo DIY- Steering Pump Overhaul G-AMG W140 S-Class 55 05-08-2017 12:37 AM
Photo DIY- Coolant Service- a la Vacuum Method G-AMG W140 S-Class 22 01-10-2017 09:45 PM
Photo DI'M'- A/C Clutch Coil R/R G-AMG W140 S-Class 5 04-15-2012 04:05 PM
Photo DIY- Motor Oil Change via EXTRACTION METHOD G-AMG W202 C-Class 20 02-09-2010 09:02 AM
Self levelling pump overhaul talbir W126 S,SE,SEC,SEL,SD,SDL Class 0 11-02-2006 11:29 AM
