Can't Select Lower Gears Past "D4" - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 01-29-2012, 11:36 AM Thread Starter
97S320Jim's Avatar
Date registered: Mar 2010
Vehicle: 1997 Mercedes Benz S320 SWB
Quoted: 2 Post(s)
Hi, Group,
I rarely have a problem with my 97 S320, so I guess it's my turn!
A few days ago, I was decending a hill. I always select "3", or "2" to slow my speed.
This day, and presently, the shifter will not physically move into "D4", 3, 2, etc.
No Check Engine lights. While in the first "D", the normal drive-position, the transmission shifts normally, upshifts through the gears when accellerating, reverse operation is normal. Otherwise, my car behaves normally.
What's going on?
James Combs,
Salt Lake City, Utah
97 S320, 98,300 miles
97S320Jim is offline
post #2 of 16 (permalink) Old 01-29-2012, 01:27 PM
Date registered: Sep 2009
Vehicle: nothing broken. finally!
there is absolutely nothing to prevent it from moving.. the y66 solenoid will not lock that out and is the only lock in there
something broken and stuck in the shifter? idk what
have you tried to bump it harder into 4th?
vw phaeton. when vw copies mercedes, but forces you to service it next to golfs and jettas
gyrate is offline
post #3 of 16 (permalink) Old 01-29-2012, 01:56 PM
aboynton's Avatar
Date registered: Jun 2005
Vehicle: 93 500SEL DOA - PARTING OUT, 08 CLK350 Cab -DOA, '05 CLK500 Cab (hers), '10 Razor Elec Scooter (his)
Location: Northern California's Great Central Valley - Meth Capital of USA
I'd guess something is binding up your shift linkage. It doesn't sound like anything going on inside the transmission, but I may be wrong.
Sent from my Autoguide iPhone app
aboynton is offline
post #4 of 16 (permalink) Old 01-29-2012, 03:58 PM Thread Starter
97S320Jim's Avatar
Quoted: 2 Post(s)
I've "gently" pushed it to the left. It feels like some interlock thing; it's probably not anything that has fallen in the shifter.
I'll start it and try with a little more force. More later.
Jim
post #5 of 16 (permalink) Old 01-29-2012, 04:09 PM Thread Starter
97S320Jim's Avatar
Quoted: 2 Post(s)
Jim
10 minutes later: Backed car out of garage. Put in "D4", AND with MORE force, it now shifts (now with resistance in all gear selection) normally.
This stiff-shifting thing must be that little shift bushing on the underside of my car, right, Gyrate?
The round bushing that gives that detent "feel", right?
Is it okay to drive for a half to a whole day?
Jim
post #6 of 16 (permalink) Old 01-29-2012, 04:25 PM
Jim
nope. it is a metal plate. there is a piston with a spring and a ball that pushes against the shift detent plate to give you the notches.
i apparently have thrown all my old shifters out but i found this plate. you can see the positions on it
it is possible the ball/spring jams. i had a few of these myself. also if it collapses, it does the opposite. the shift bushing will result in slack of the shift rod that you wouldnt feel in the shifter from D downward. PRN is a detent plate in the transmission itself that gives you notches. D4321 is the plate below. weird i know
gyrate is offline
post #7 of 16 (permalink) Old 01-29-2012, 05:13 PM Thread Starter
97S320Jim's Avatar
Quoted: 2 Post(s)
Do you get to this plate and bushing from inside the top of the shifter, or underneath the car, or within the transmission case, Gyrate?
Is it safe to drive? If I leave the shifter in the normal "D" drive-position, I'm I okay to drive it to my independent MB shop, Gyrate?
Nice pics, too.
Jim
post #8 of 16 (permalink) Old 01-29-2012, 09:28 PM
Nice pics, too.
Jim
inside the shifter, from inside the car. whole shifter comes out
you can drive it indefenitely. as long as its not loose in D it wont burn out the selector switch.
gyrate is offline
post #9 of 16 (permalink) Old 01-29-2012, 10:48 PM Thread Starter
97S320Jim's Avatar
Quoted: 2 Post(s)
I was getting the inch to drive it again.
Back out of garage: shifter NOW smooth again, put into "D", smooth, sure feel to the engagement. Drove 30 minutes. Fast, slow, forcing downshifts on steep hills near my neighborhood.
Pulled into garage. The shifter was as smooth as if nothing was wrong.
But, I didn't "force" it back into "D4" or lower...
About how much for this kind of repair, Gyrate?
Does just the black regtangular bezel around the shifter need to be removed for access, or does all of the wood come out (!!!!)?
I never had any kids, Group; my 97 S320 IS my kid! I'm worried like a parent would be.
James Combs,
1997 S320, 98,200 miles
post #10 of 16 (permalink) Old 01-30-2012, 02:29 AM
syljua's Avatar
Date registered: Sep 2004
Vehicle: 1998, C140, CL500
Quoted: 67 Post(s)
Read more about the shifter here;
Center Console Shift
So, if its a problem with the shift disengagement mechanism, or just the
D4-3-2-1 shift detent, it does not have to affect your experience in the
P-R-N-D range, since its a intra-shifter-thing,
and nothing to do with the actual gearbox.
Yes, the wood must come out to get the shifter out (at least my experience)
br,
syljua
sfalkenberg likes this.
C140 CL500 1998
W123 230E 1984
syljua is offline
Have two sets of "Fast Axle" hub gears! Photos!! VON Unimog 28 07-08-2015 04:24 AM
is it normal after entering radio code it says "WAIT" for past 20min????? mers320 W163 M-Class 3 09-21-2010 11:46 AM
re-past my "300SEL" , need advices. tsengpoting W126 S,SE,SEC,SEL,SD,SDL Class 6 07-14-2009 12:23 AM
"Angry White Man: The bigoted past of Ron Paul" Jayhawk Off-Topic 41 01-13-2008 09:21 AM
