Trunk lock cylinder replacement help! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-24-2011, 02:36 PM Thread Starter
Date registered: Mar 2010
Vehicle: 1995 Mercedes-Benz S420 (W140), 1997 BMW 740iL (E38), 2011 C300 Luxury (W204)
Quoted: 2 Post(s)
Does anyone know how or whether or not replacing the trunk lock cylinder is possible? I know you can do it with door lock cylinders, ignition and even glovebox/sunglasses compartment but what about the trunk lock cylinder?
Here is the issue. My original trunk lock mechanism is broken, I found a replacement which works but my current key does not work in the replacement trunk lock (obviously). So I need to take the trunk lock cylinder out of the old trunk lock and put it into the new trunk lock so that my key works in the new part.
Any help or diagrams greatly appreciated!
People at the very top, Presidents not only of International companies-but of whole countries, travel S Class. -Jeremy Clarkson
Sinned420 is offline
post #2 of 4 (permalink) Old 08-24-2011, 07:25 PM
Date registered: Aug 2011
Vehicle: Mercedes Benz E320
I believe you can Replace it. My Trunk has been locked for 8 months and I just got it opened today with the help of a Locksmith. Everyone kept telling me to go to the dealer and I finally had a locksmith that wasn't afraid to touch it. I own a 99 E320 and the key would not work in neither would the cylinder when I pushed it in to loosen the latch to open the trunk. Also the Trunk Latch inside the car did not work. So the LOCKSMITH buy put these two blood pressure cuff looking things under the bottom of the trunk and pumped them up and my trunk popped right open after 8 months. He then inspected my locks and said I need to replace the cylinder and Trunk Lock. It looks like when I pushed the cylinder it to open the trunk like normally it was not connecting to the internal latch to release the trunk. Anyway good luck!!!!
soyicasweet99 is offline
post #3 of 4 (permalink) Old 08-24-2011, 09:28 PM Thread Starter
Quoted: 2 Post(s)
Yeah I know if something goes wrong I won't be able to mechanically open the latch and that'll be bad news. I'm not too confident in the locksmiths around here either. The thing you said the locksmith had sounds like it inflates and pushes all the pins up in the lock cylinder therefore simulating the original key.
Anyways, I hope I can figure out how to remove/replace the lock cylinder. I was hoping someone on the boards have a WIS that shows how or something, as Alldatadiy doesn't show anything. I understand how the mechanism works, how the trunk latch can fail etc after hours of studying the damn thing.
Anyways, if I can't swap my lock cylinder, my options are either 1) Rig the setup so that no matter how the latch is locked, the latch will release when you push it in. This will allow anyone access to the trunk, the alarm will go off but trunk still opens. 2) Buy new from dealer that is made to go with my key. 3) Put old latch in, rig the microswitch from working latch to fool the car thinking my old one works. I will lose functionality of unlocking/locking via key in trunk hole, however the remote lock/unlocking will work.
post #4 of 4 (permalink) Old 08-25-2011, 05:46 PM
Date registered: Feb 2003
Vehicle: 600SEL
Quoted: 85 Post(s)
https://www.benzworld.org/forums/w140...ml#post4860743
last file on page 3 shows how to separate housing from the lock cylinder
myarmar is offline
How do I unlock my doors from the trunk lock cylinder 95BenzC220 W202 C-Class 2 05-12-2011 08:57 AM
where to buy trunk lock cylinder? keys locked in trunk tferrari W221 S-Class 3 08-25-2010 10:39 PM
Key won't lock / unlock car - cylinder replacement? Goldenvoice W123 E,CE,D,CD,TD,TE Class 3 03-10-2007 07:09 PM
replacement lock cylinder LGF W124 E,CE,D,TD Class 1 01-03-2007 08:38 AM
W T B Trunk Lock Cylinder guage For Sale/Wanted/Trade/Giveaway 2 05-06-2005 01:25 PM
