cruise problem - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 04-21-2011, 09:21 PM Thread Starter
Date registered: Apr 2011
Vehicle: 1992 300SD
cruise problem
lately the cruise hasnt been working in my 300SD. is anyone aware of any problems the w140's cruise? can anyone shed some light on this?
1992 300SD
bmwsucks is offline
post #2 of 22 (permalink) Old 04-21-2011, 11:13 PM
glenlloyd's Avatar
Date registered: Apr 2005
Vehicle: 92 W140 300SD 97 VW Jetta TDI 89 VW Fox diesel
Your car is a twin to mine, smoked silver over muscle grey outside. I can't tell what interior you have although I would speculate that it's parchment / champignon but I could be wrong, it looks darker.
I'm not real familiar with the cruise system on these but I'll have a look at Alldata to see what can be done. Off hand my first suggestion would be to look at the brake disengage switch under the dash, but that's just an off-hand guess.
As a side note, I see your car is badged "Turbo" on the right rear decklid, did you put that on? From what I've found none of the US W140 diesel cars were labeled as such, the 94/95 cars were badged "Turbodiesel" on the right side.
97 VW Jetta TDI
90 Passat wagon TDI conversion
92 W140 300SD
glenlloyd is offline
post #3 of 22 (permalink) Old 04-21-2011, 11:46 PM
nhzruthless818's Avatar
Date registered: Jun 2008
Vehicle: 1997 S500V, 1999 S500 grand edition, 2006 s65 amg
Quoted: 131 Post(s)
those are the wheels you have on it ? because when you put aftermarket wheels it could stop working. mine sometimes doesn't work because of the brake light switch and the wheels don't help it either. but try this sometime when you do accelerate instead of resume it will work(thats what mine does anyways)
nhzruthless818 is offline
post #4 of 22 (permalink) Old 04-22-2011, 05:05 AM
~BANNED~
Date registered: Jan 2011
Vehicle: 2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
Quoted: 25 Post(s)
Is your ABS light on the instrument cluster on?
I have the same problem, with an almost identical vehicle. (1993 / 94 S320)..
My front right speed sensor need to be replaced, this I was told is what is causing my Cruize control to not be working..
Once I have replaced it next week, I will let you know if it fixed the prob..
MafiaDON is offline
post #5 of 22 (permalink) Old 04-23-2011, 08:27 PM Thread Starter
Vehicle: 1992 300SD
my in interior is black. i just purchased the car 10 days ago, and i havent had a lot of time to research it. however the turbo badge looks original, but it is a canadian car. maybe they were different.
1992 300SD
bmwsucks is offline
post #6 of 22 (permalink) Old 04-23-2011, 08:36 PM Thread Starter
Vehicle: 1992 300SD
i didnt know the wheels were after market, but my tires rub when i turn sharp. this is all starting to make sense...
1992 300SD
bmwsucks is offline
post #7 of 22 (permalink) Old 04-23-2011, 08:51 PM Thread Starter
Vehicle: 1992 300SD
wow, its like you read my mind... as a matter of fact, the light is on.
please keep me posted on what you find out. i wonder if the sensor is something i can replace myself.
1992 300SD
bmwsucks is offline
post #8 of 22 (permalink) Old 04-23-2011, 09:15 PM
glenlloyd's Avatar
Those are not aftermarket wheels, they're standard W140 alloys, so they wouldn't likely be the cause of any cruise difficulty. I haven't been to alldata yet but I'll get there shortly. I'm not sure it will provide a diagnosis but we'll see.
Interesting that you have a black interior, something I really wanted, but since you don't have a choice with a used car I had to accept what I got. Black would have been a better contrast with the exterior color though, changing the whole interior is a big chore.
Have you confirmed yet that the engine either doesn't consume oil or it has a replacement engine?
Nice car...I'm envious of your black interior. More pictures (interior included) would be great when you have time.
Steve A
97 VW Jetta TDI
92 W140 300SD
post #9 of 22 (permalink) Old 04-23-2011, 09:37 PM
Quoted: 131 Post(s)
i was asking if the ones in the picture were on the car or did you have something else on it. the ones in the picture are stock.
post #10 of 22 (permalink) Old 04-23-2011, 09:46 PM
glenlloyd's Avatar
I checked alldatadiy and there is a test procedure but you'll need a reader to pull the codes from the system. There are inexpensive ones out there that you can buy or I've also seen instructions for making one.
At any rate, there is a TSB for all W140's that concerns tire size, MB says all tires must be identical maker / size otherwise cruise will disengage at road speed but may operate at lower speed levels.
Send me an email and I'll forward you the test procedure.
Steve A
97 VW Jetta TDI
92 W140 300SD
cruise control problem qtstorm W124 E,CE,D,TD Class 1 09-05-2005 07:11 PM
Cruise control problem dlbehrns C208/A208 CLK-Class 0 08-18-2005 08:40 PM
Cruise Control Problem erc22 W201 190-Class 5 11-04-2004 03:01 PM
Cruise Control Problem DUTCH G-Class 20 08-02-2004 05:45 PM
help cruise control problem HeirKranz Audio & Telematics Forum 0 07-01-2004 10:42 PM
