W140 Wheels/Rims & Tires Fitment - Mercedes-Benz Forum
post #1 of 929 (permalink) Old 01-25-2010, 02:01 PM Thread Starter
z168's Avatar
Date registered: Oct 2005
Vehicle: M20
Quoted: 142 Post(s)
Arrow W140 Wheels/Rims & Tires Fitment
Since there are a lot of questions regarding wheel and tire fitment, lets start a thread. Please put in your own experience of have at least seen it done through someone you know. Do not post speculative info. Please only put info you are sure will fit
Please post:
1. Wheel Specs - size, width, offset
2. Tire Specs - (e.g. 245/40R19 front, 275/35R19 rear)
3. other pertinent info (e.g. car was dropped, spacers were used, lugboltsmodified LCAs, etc)
and more importantly
4. Pics - doesnt have to your car, could be someone else's
Please keep personal discussions to a minimum. This will help other people get to the info they need faster. We can make this a sticky later on. But for now its in the knowledge base (see 1st post)
Added:
Wheel and Tire calculator - Thanks to Joe-Trojan
Deutsche Tourenwagen Meisterschaft
z168 is online now
post #2 of 929 (permalink) Old 01-25-2010, 02:05 PM Thread Starter
z168's Avatar
Vehicle: M20
Quoted: 142 Post(s)
AMG Monoblock Aero2
Front: 19x8.5 ET46 255/40R19 - Continental
Rear: 19x9.5 ET46 285/35R19 - Continental
No spacers, stock suspension. No issues
AMG Monoblock Aero2
Front: 19x8.5 ET46 w/ 245/45R19 - Michelin Primacy
Rear: 19x9.5 ET46 w/ 275/40R19 - Michelin Primacy
Carlsson Evo1/6
Front: 19x8.5 w/ 245/40R19 - Michelin
Rear: 19x10 w/ 285/35R19 - Michelin
No spacers, had plastic hubcentric rings and shorter lugs. No rubbing
unavita likes this.
z168 is online now
post #3 of 929 (permalink) Old 01-25-2010, 05:52 PM
Date registered: Oct 2007
Vehicle: 1997 s420 (pearl black opal), 2005 c230k (obsidian black)
AMG monoblock
19x9.5 et 46 Pirelli Pzero rosso 285/35/19
19x8.5 et 44 Pirelli Pzero rosso 255/40/19 *Best summer tires,ever!
all stock/ minimal rubbing front and rear under fully loaded car ONLY when there is a big dip in the road
AutoCouture Supreme
20x9.5 et 38 Bridgestone 255/35/20
20x8.5 et 36 Bridgestone 285/30/20
AMG monoblock
18x8.5 et 44 Yokohama 255/45/18
slight rubbing in the front left under the same conditions as above
**Your car might not rub in the front like mine, i think mine has a slightly out of place wheel well plastic, and rubbing is minimal and on the outer shoulder of the tire.
ID:	287033   Click image for larger version
ID:	287034   Click image for larger version
xhino87 is offline
post #4 of 929 (permalink) Old 01-25-2010, 07:58 PM
The andrew's Avatar
Date registered: May 2008
Vehicle: 1993 W140 500SEL Black/Black, 12014 Ford Fiesta ST Blk/Blk
For those of us who may have aftermarket wheels, ahem, and require shorter lugs in order not tear out the parking brake or stick out of the wheels, would you provide sources/vendors, where shorter shank lugs may be purchased.
14mmX1.5 and _____ MM length.
My wheels have less flange thickness due to design and offset so.... thanks!
Also Tires sizes for 18x8 and 18x9.
"However, not the the aesthetic masterpiece you might have expected for a billion dollars, but all of them, and this one in particular, justifies it's price through sheer attention to detail." -Jeremy Clarkson
Over 184K and it's sweet!
It MUST have been that leather wrapped dash that got 'er going, what else do you have to offer?
The andrew is offline
post #5 of 929 (permalink) Old 01-25-2010, 10:33 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 213 Post(s)
Originally Posted by z168 View Post
Carlsson Evo1/6
No spacers, had plastic hubcentric rings. No rubbing
These are the best photos I have of your Carlssons
z168, Abu Ali and unavita like this.
MBeige is offline
post #6 of 929 (permalink) Old 03-10-2010, 08:42 AM
Vehicle: W124 Masterpiece E260 Limousine
I would like to know, can i use 235/70/16 tyre to my W140? 70 height is suitable or problematic for w140.
Now: W124 E260 Limousine
Sold: W126 560SE Saloon
jamaldn is offline
post #7 of 929 (permalink) Old 03-12-2010, 12:09 AM Thread Starter
z168's Avatar
Vehicle: M20
Quoted: 142 Post(s)
thats too tall. it might fit, but it will mess up with your speedo and odo and possibly your ABS
z168 is online now
post #8 of 929 (permalink) Old 03-12-2010, 12:32 AM
TasmanianDevil's Avatar
Date registered: Jul 2008
Vehicle: 1994 Benz S320 SWB / 1986 Porsche 911 Targa / 1998 Benz CL 500
Quoted: 4 Post(s)
1994 S320 SWB
Factory Original 8 Hole Alloy
SIZE: 16 x 7.5
BOLT PATTERN: 5 X 112
OFFSET: 51 mm
Front: Michelin Pilot 235 60 16 100W ( Factory Original Should Be 225 60 16 )
Rear: Michelin Pilot 235 60 16 100W ( Factory Original Should Be 225 60 16 )
Suspension ( Front / Rear ) : Stock
No Spacer, No Additional Fitment. No Problems.
TasmanianDevil is offline
post #9 of 929 (permalink) Old 03-28-2010, 05:35 AM
FerasGTI's Avatar
Date registered: Oct 2009
Vehicle: W140 SEL500 5.0 1993
Original Wheels from Factory.
16" x 7.5"
OFFSET: 51 mm
Tyres:
Front: Michelin Pilot 225 60 16 98Z
Rear: 1Michelin Pilot 225 60 16 98Z, and 1Firestone 225 60 16 W100
Picture looking same as above:
looking for gunmetal AMG wheels probably 2(18" X 8.5") and 2(18"X9.5") with Bridgstone or Prilli Tyre.
unavita likes this.
FerasGTI is offline
post #10 of 929 (permalink) Old 04-17-2010, 04:28 PM
DJ_Boo's Avatar
Date registered: Jan 2009
Vehicle: 92' 300 SEL
Quoted: 4 Post(s)
Can someone please tell me, i've got 18 inch rims 8" wide. And the et35.. Which tyres should i get? I was thinking about 255/45/18 for front and something between 275 and 295 for rear wheels. Will it be ok?
DJ_Boo is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
I have read the wheel fitment thread :) - Larger wheels for 1985 300SD fattfreddie W126 S,SE,SEC,SEL,SD,SDL Class 6 09-13-2012 07:01 PM
Fitment Question 2001 E55 Winter Wheels/Tires Smokin' 420 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 01-27-2009 11:09 AM
just bought rims and tires - used, will i have any problem with fitment? karamountzos General Mercedes-Benz 1 08-20-2007 08:27 PM
Stock Wheels and Tires thread! alroumi R171 SLK-Class 3 04-28-2006 06:47 PM
Any 20" wheels/rims or wheels/rims+tires for Sale? Elite W211 E55 AMG, E63 AMG 0 04-27-2006 08:49 AM
