What love did you give to your 140 today? - Page 201 - Mercedes-Benz Forum
post #2001 of 2022 (permalink) Old 05-29-2019, 03:44 AM
Date registered: Apr 2016
Vehicle: '95 S600
Quoted: 71 Post(s)
I thought pulling the manifold was quite easy, all the fasteners are easy to reach but its just time consuming due to 12 cylinders. I just worked in prone position on the manifold with feet resting on a bench for most of it, no strain on the back etc.
NZJay is offline
post #2002 of 2022 (permalink) Old 05-29-2019, 06:21 AM
LogicalPosition's Avatar
Date registered: Nov 2013
Vehicle: '99 S420 111K
Quoted: 325 Post(s)
Send a message via AIM to LogicalPosition
I Got My Baby Back!
My '99 S420 developed a miss in the engine last week.
O'Reilly's kindly put the OBDII reader on and it was #1 cylinder, located on the front passenger side of the engine. O'Reilly's wanted $90 plus freight for a coil, I got it online for $54 free shipping from German Auto Parts in Tennessee.
The replacement took all of 30 min, pop the engine covers, 3 bolts for the coil/spark plug cover, two bolts for the coil bracket, pop off the wiring harness fitting, pull the bad coil, put the new one on, and replace the covers. Almost as easy as changing a light bulb.
I pulled the spark plug while I was in there, it was gorgeous despite the misfire for the last 5 miles of service.
I now have my loved one back on the road and I'm thrilled!
She'll get washed today, and I'll be at the Hooters Cruise-In Saturday night livin' the life.
"You are what you drive!" Big Al
There is perception, and then there is reality.
'99 W140 S420 111K, '94 W124 E320 124K (sold! Repurchased 10/3/16, sold 11/17)
'14 BMW X3 XDrive 38K,
'13 BMW X1 28K (Traded). '11 BMW 328i XDrive 19K(Traded)
'08 Subaru Outback Limited Wagon 56k (Traded)
'83 BMW 320is "Sport" (48k, sold! converted to EV!)
'87 190E W201 (sold!) '85 Audi 5000 (sold!)
'76 250 W114 (sold!) '72 280 W114 (sold!)
'67 200D W110 (bartered) '62 220 W111 (buried)
LogicalPosition is offline
post #2003 of 2022 (permalink) Old 05-29-2019, 06:39 AM
Quoted: 325 Post(s)
Soft Close Door And Trunk Issue
I had an "Aw Sh8t" moment with my '99 S420 recently. About 6 months ago the driver's door stopped soft closing. Then last month the trunk stopped working properly.
After some labored research, and thanks to this forum I found a quick fix.
There is a fuse panel in the trunk, passenger side, behind a 8"X 8" cover.
Pull #9 fuse, start the vehicle, turn it off, replace the fuse.
This resets the pump under the back seat that controls the soft close features.
Apparently when the pump senses 2 failures at a door or the trunk, it turns off the feed to that door or trunk. The reset seems to work so far(2 weeks), but just last evening the front passenger door failed. So I'll try the reset trick today, and hopefully all will be well again.
post #2004 of 2022 (permalink) Old 05-29-2019, 07:01 AM
Date registered: Aug 2016
Vehicle: 1994 S600 Coupe
Quoted: 276 Post(s)
If you keep doing that, eventually you will burn out the pump. The fix is to adjust the shut off pressure of the pump, so that the pump doesn't run as long. Running long is what triggers the diabling. The adjustment procedure is on page 5 of the attachment. Not hard to do.CloseAssistRepair.pdf
burgca and LogicalPosition like this.
jal1224 is offline
post #2005 of 2022 (permalink) Old 05-29-2019, 07:04 AM
Quoted: 276 Post(s)
Try again for the attachment.CloseAssistRepair.pdf
jal1224 is offline
post #2006 of 2022 (permalink) Old 05-29-2019, 07:50 AM
Quoted: 325 Post(s)
A Dangerous Procedure
Originally Posted by jal1224 View Post
If you keep doing that, eventually you will burn out the pump. The fix is to adjust the shut off pressure of the pump, so that the pump doesn't run as long. Running long is what triggers the diabling. The adjustment procedure is on page 5 of the attachment. Not hard to do.Attachment 2516658
I appreciate your response, I'm certain you are correct about the pump running too long and disabling the soft close.
I read about this problem extensively, and I concluded that the pump adjustment was just too dangerous to attempt. If you booger up those nipples on the pump, it's new pump time. I carefully looked at those hoses and nipples and decided there is no SAFE way to remove those hoses to get to the cover to make the adjustment. At some point in the future I may perform this adjustment, we'll see.
I suspect my problem possibly arises from the intense HEAT we experience here in Florida. I cannot garage my vehicle, so it bakes in the sun.
post #2007 of 2022 (permalink) Old 05-29-2019, 08:06 AM
Quoted: 276 Post(s)
I've removed and replaced both the PSE and soft close pumps, and never broken a nipple. Both cars I've got are southern, so there seen plenty of heat. The key is to get a thin end wrench between the fitting and the pump body, so as to force the fitting straight up, and not bend it and the nipple. You will be out a lot of money if you burn up the motor in the soft close pump, unless you find a good used one.
jal1224 is offline
post #2008 of 2022 (permalink) Old 05-29-2019, 11:20 AM
Quoted: 325 Post(s)
Time Is Always A Factor
At the time I investigated this pump issue, I was somewhat panicked about the trunk not completely closing. I wanted a quick solution. When I looked at the pump and what it would require to remove the hoses I didn't want to possibly make matters worse. I had read about the hazards, old plastic, broken nipples, $400 pump... the fuse thing seemed like the best solution at the moment.
If I find this to be a recurring issue, I definitely will try the screw adjustment, I just didn't want to attempt it that day given my circumstance.
Thank you for your excellent advice and 14 pages of info about this pump and it's functions. I posted this info to hopefully save others some time researching this issue when they are in a panic as I was. You offered the true repair advise and I thank you. I spent at least 2 hours reading up on this before I made my decision.
Now if you can fix my wonky rear view mirror, the driver's seat belt retractor, the cupholder in the armrest, the slight thunking from the right rear suspension at low speed, freshen the paint on the lower cladding, R&R the antenna mast, install my metal oil caps for the camshafts with new valve cover gaskets(while yer in there R&R the timing chain guides), and restore all 4 wheels for me, I'll be even happier. I don't have too long a list of to-do's but it's enough to keep me busy.
post #2009 of 2022 (permalink) Old 05-29-2019, 11:33 AM
Quoted: 276 Post(s)
If your driver's seatbelt doesn't retract properly, clean the seatbelt. I pulled mine out to it's full length, put a clip at the top to keep it from retracting, filled a bowl full of full strength Purple Power, and soaked the belt in it for a couple of hours, agitating occasionally. You wouldn't believe the crap that came out of it. I then used bowls full of clean water to rinse it several times, then squeezed as much water out as I could, and let it dry. Did both front belts. Both are now much more flexible, and retract completely, where neither did before.
The other option if you have a pressure washer, is to stretch the belt outside the car, shut the door on it, and blast both sides. Generally, you can see the belt change color as you wash junk out.
25 years of dirt and body oils build up and stiffen the belts. I was amazed at the difference.
jal1224 is offline
post #2010 of 2022 (permalink) Old 05-29-2019, 03:24 PM
quakercity's Avatar
Date registered: Dec 2007
Vehicle: 1999 S600 & 1999 S500
Quoted: 119 Post(s)
Buy a set of the interior plastic pry bars from Harbor Freight. They are yellow. There is one that looks like a slanted two teeth pry bar. Pops those hoses off easily. Just be gentle.
LogicalPosition likes this.
1999 S600 - 4 place
1999 S500 Grand Edition-Sold to good home!
1999 S500 - Deceased
quakercity is offline
I spent 92.00 today to fill up my 140 vvee12 W140 S-Class 34 04-03-2016 07:50 AM
Drew, would you give up your 126 for a 140 with 100k for less than three grand? Digmenow Off-Topic 27 07-31-2014 12:23 PM
It seems Emily will give you some Kinky Love, her sister will not do it a long time Jakarta Expat Off-Topic 19 02-11-2008 12:43 PM
If you had to give up your W210 today? acarter53 W210 E-Class 24 03-04-2007 05:15 AM
Its VALENTINE's DAY: what special treatment are you planning to give to your ML today? S4toML W163 M-Class 6 02-14-2003 12:49 PM
