blown head gasket - Mercedes-Benz Forum
post #1 of 36 (permalink) Old 09-14-2009, 04:12 PM Thread Starter
gargo11's Avatar
Date registered: Sep 2009
Vehicle: 1995 s500 v8
Send a message via Yahoo to gargo11
blown head gasket
does anyone have a step by step manual on headgasket repair on 1995 s500 sedan?
gargo11 is offline
post #2 of 36 (permalink) Old 09-14-2009, 05:44 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
there is some info about the M104, but not the M119 (yours)
how much experience do you have? setting the timing for M119 is not exactly easy...
All data will probably help you...
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #3 of 36 (permalink) Old 09-14-2009, 08:19 PM
Mercedes Mechanix's Avatar
Date registered: Sep 2007
Vehicle: 1914 Mercedes 28/95 hp, 83' 300SD, 93' S420, (three) 94' S420's, 95' S500 & 96' S600
Post 119 engine (V8) Head Gasket: removal and replacement procedure(s)
If you decide to go through this yourself.... on your personal vehicle
drop an email to [email protected] and I will be glad to walk you trough this effort step by step. But, please be aware... this will require patience, and time.
I would appreciate, that you would document with description(s) and digital images to assist others in the future of your work! If you agree, we will assist via communication(s) as possible. As far as timing the 119... it simply requires following steps and instruction as we describe. Will provide images that also will assist with clarification as required... promise. It is NOT Brain-Surgery..... As for a short description: you will pull the intake manifold (upper and lower) as a unit with ETA/ MAF intact, also will remove the appropriate head or head(s) as you desire. Note: new Head Bolts will be necessary, new Gaskets for your Intake, Head(s) and T-Chain Tensioner will also be required. Nine quarts of 20w50 lubricant (your choice of Mfg), one-MB oil filter, two gallon's of 50/50 mix coolant (aluminum friendly), Another item that incorporates Dutch's trade-secret: you will need a small can of "spray copper-kote"!
Will communicate of other tool(s) when/ if you decide to undertake this challenge. Perhaps even borrow a small inch torque wrench and foot pound torque wrench.
You can accomplish this gasket replacement and we will be glad to help as you request.
As an over-view.... The following paragrahs provide full overview of this challenge.
Removal and Replacement
Images for this instructional information follow below:
Preceding work:
Coolant: drained. See: Cooling System
Cylinder head covers: removed. See: Valve Cover\Service and Repair
Procedure :
NOTE : Every step below applies regardless of which side you are removing, unless stated otherwise within a specific step.
Remove intake manifold.
Remove front cover at top at cylinder head to be removed . See: Timing Cover\Service and Repair
Remove guide rail of cylinder head at cylinder head to be removed . See: Timing Chain Guide\Service and Repair
Remove camshaft adjuster at cylinder head to be removed . See: Variable Valve Timing Actuator\Service and Repair
Left cylinder head : Unscrew bolts (1). (1a) and (2). Tighten to: (21 Nm).
Place retaining plate to the side with power steering pump (11) and oil lines connected.
Installation Note : Coat bolt (2) with sealant 002 989 47 20 10.
Engine 119.97x: install bolt (1a) with retaining bracket (4) of wiring harness.
Right cylinder head : Unbolt engine oil dipstick tube (22).
Remove guide rail (23) for ignition cables.
Right cylinder head: Unbolt transmission oil dipstick tube (12) (Automatic Transmission ).
Unbolt front exhaust system at exhaust manifold. See: Exhaust System
Right Cylinder Head
Left Cylinder Head
Right-hand cylinder head: Unscrew fitted collar bolts or bolts + washers (a) and (b) to timing case cover. Tighten to: (25 Nm).
NOTE: When performing repairs, install fit collar bolts or the bolts + washers depending on the bolts used previously.
Left-hand cylinder head: Unscrew bolts (d) and (e) to timing case cover. Tighten to: (25 Nm).
Loosen cylinder head bolts when engine is cold with screwdriver bit in stages in reverse order of tightening diagram shown in images above, beginning with 10. Remove bolts. Use special tool 119 589 00 10 00.
NOTE:
Models 124, 140: cylinder head bolt 10 cannot be removed with cylinder head installed; for this reason, raise and secure.
Model 210: cylinder head bolts 9 and 10 of both cylinder heads cannot be removed with cylinder head installed; for this reason, raise and secure.
On "closed-deck" crankcases, the cylinder head bolts installed have different length, refer to bolt diagram.
Loosen first and fourth camshaft bearing caps (18) of inlet camshaft.
Bolt bracket (17) on with bearing cap bolts and dowel sleeves (18a) instead of first and fourth camshaft bearing caps (18). Use special tool 119 589 0140 00.
Attach engine hoist to bracket (17).
Raise and remove cylinder heads (13) and (14).
Examine cylinder head contact surface. See: Procedures\Checking/Refacing Cylinder Head Contact Surface
Clean tapped holes of cylinder head bolts.
CAUTION: Ensure holes are free of oil and water.
Replace cylinder head gaskets (19) and (20).
CAUTION: The cylinder head gasket is not watertight until the engine has reached normal operating temperature, in other words until a swelling process has taken place. For this reason, the cooling system must not be pressure-tested until after the engine has reached normal operating temperature.
Install cylinder heads (13) and (14).
Note dowel sleeves (f) or roll pins (c).
Examine cylinder head bolts (15).
NOTE: The cylinder head bolts (15) are subjected to a certain permanent stretch each time they are tightened. If the maximum length is exceeded (see table below), the bolts should be replaced with new ones.
Oil cylinder head bolts (15) at thread and at contact surface of bolt head.
Insert cylinder head bolts (15) with washers (15a).
Tighten cylinder head bolts in stages, in sequence of tightening diagram, beginning with 1. Tightening torques see table below.
Complete assembly in reverse of removal procedure. Observe all tightening specifications within this article and all installation notes.
Cylinder Head Bolt Tables
Cylinder Head Bolt (12-pt Socket with "Closed-Deck")
Thread Diameter "D" 12 mm
Stretch Shank Diameter "d":
When New 10.75 ±0.05 mm
Thread Length "a" 135 mm
Bolt Length "L":
When New 160 ±0.8 mm
Maximum Bolt Length 162.70 mm
Cylinder Head Bolt (12-pt Socket with "Open-Deck")
Thread Length "a":
Short Bolt 135 mm
Long Bolt 190 mm
Bolt Length "L":
When New:
Short Bolt 160 ±0.8 mm
Long Bolt 218 ±0.9 mm
Maximum Bolt Length:
Short Bolt 162.70 mm
Long Bolt 221.60 mm
Tightening Torques And Tightening Angle Table
Cylinder head bolts, engine cold*
1st stage: 55 Nm
2nd stage: 90°tightening angle
3rd stage: 90°tightening angle
Bolts of camshaft bearing caps M7: 15 Nm
Bolts of cylinder head timing case cover M8: 25 Nm
* Moisten washers and thread and contact surface of bolts with oil before installing.
Bolt Diagram
"Closed-Deck" Cylinder Head Bolts Numbers 1 to 10 = M12 x 160 mm
"Open-Deck" Cylinder Head Bolts:
Numbers: 1, 3 and 5 = M12 x 218 mm
Numbers: 2, 4, 6, 7, 8, 9, 10 = M12 x 160 mm
NOTE: Cylinder head bolts : Cylinder head bolts match with washers. "Closed-Deck" cylinder head bolts are phosphatized, washers chrome-plated. "Open-Deck" cylinder head bolts are chrome plated, washers are phosphatized.
No "HELI-COIL inserts are installed in crankcase of "open-deck version. HELI-COIL inserts may be used when performing repairs.
Robert
ID:	260044   Click image for larger version
retired 32+ years: Mercedes Benz Technician
Sinndelfingen Facility
Ein gut aufrechterhaltener Mercedes wird ebenso ruhig laufen wie eine Nähmaschine viele Jahre lang!
Mercedes Mechanix is offline
post #4 of 36 (permalink) Old 09-14-2009, 08:22 PM
bayhas's Avatar
Quoted: 324 Post(s)
drop me an email to [email protected] and I will be glad to walk you trough this step by step. But will require patience, and a bit of time.
gargo11, you're in good hands, these guys ^^^ are my "god fathers" in the W140 world...
Garage:
Former Mercs:
bayhas is offline
post #5 of 36 (permalink) Old 09-15-2009, 08:28 AM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 24 Post(s)
Send a message via AIM to jhodg5ck
M119 head gaskets = not what I would call your basic DIY project;-)
Jonathan
Enthusiast Service, Restoration & Tuning.
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
87 Hammer Coupe 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #6 of 36 (permalink) Old 09-15-2009, 09:57 AM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 17 Post(s)
So your mechanic diagnosed a blown head gasket?
Brett
Brett San Diego is offline
post #7 of 36 (permalink) Old 09-15-2009, 10:02 AM Thread Starter
gargo11's Avatar
Brett
yes he did and it looks like whoever had this car did not use the proper fluids for the cooling system, taking the head to a machine shop today but will post pics of the gasket and i would like to get your opinion on it.
gargo11 is offline
post #8 of 36 (permalink) Old 09-15-2009, 10:09 AM Thread Starter
gargo11's Avatar
Preceding work:
Cylinder head covers: removed. See: Valve CoverService and Repair
Procedure :
Remove front cover at top at cylinder head to be removed . See: Timing CoverService and Repair
Remove guide rail of cylinder head at cylinder head to be removed . See: Timing Chain GuideService and Repair
Remove camshaft adjuster at cylinder head to be removed . See: Variable Valve Timing ActuatorService and Repair
Right Cylinder Head
Left Cylinder Head
NOTE:
Examine cylinder head contact surface. See: ProceduresChecking/Refacing Cylinder Head Contact Surface
Bolt Length "L":
Thread Length "a":
Short Bolt 135 mm
Long Bolt 190 mm
Bolt Length "L":
When New:
Long Bolt 221.60 mm
1st stage: 55 Nm
Bolt Diagram
Robert
do you recommend that i have both sides done.
gargo11 is offline
post #9 of 36 (permalink) Old 09-15-2009, 10:11 AM Thread Starter
gargo11's Avatar
will do and thanks for the support
gargo11 is offline
post #10 of 36 (permalink) Old 09-15-2009, 05:10 PM Thread Starter
gargo11's Avatar
Preceding work:
Procedure :
Right Cylinder Head
Left Cylinder Head
NOTE:
Bolt Length "L":
Thread Length "a":
Short Bolt 135 mm
Long Bolt 190 mm
Bolt Length "L":
When New:
Long Bolt 221.60 mm
1st stage: 55 Nm
Bolt Diagram
Robert
heres a look a the right side blok has 2 crack 4innches apart
gargo11 is offline
Blown Head Gasket! Mercedes Ron W163 M-Class 2 07-27-2009 11:29 PM
Blown Head Gasket - Help mister_canon W202 C-Class 9 05-06-2009 05:37 PM
head gasket blown? iaha General Mercedes-Benz 6 05-22-2008 12:23 AM
Head gasket blown? gregdeklerk W201 190-Class 5 09-29-2006 03:04 PM
BLOWN HEAD GASKET Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 01-28-2002 10:11 AM
