Photo DIY- M119 Engine Compression Check - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-07-2009, 02:27 PM Thread Starter
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Quoted: 154 Post(s)
Greets,
Since it was time for me to change the Spark Plugs, I normally like to do a Compression Check, just to keep a record of the internal "Health" of my engines...
The write-up is from the WIS, which I was Shocked to see there was NO bypassing of any of the fuel relays, like most tutorials. Since my engine had no rear CPS in the location shown in the WIS, I went to the front sensors and unplugged them to keep the engine electrical system off-line.
Please note, DON'T push the Gas Pedal to Full Throttle like most Compression checks.. and place transmission in Neutral while cranking using the CAR KEY, rather than the Hand Starter like my other vehicles....
I hope this encourages someone to also keep up on their car's "Wellness" Check-Up...
Please note, this is for the '99 S420 M119.981 Engine. Of course, at the end, it is the "re-install in reverse order" mumbo-jumbo. Keep the Coil Spring orientation correct.
ID:	242680   Click image for larger version
ID:	242681   Click image for larger version
ID:	242682   Click image for larger version
ID:	242683   Click image for larger version
ID:	242685   Click image for larger version
ID:	242686   Click image for larger version
ID:	242687   Click image for larger version
ID:	242688   Click image for larger version
z168 likes this.
G-AMG is offline
post #2 of 14 (permalink) Old 06-07-2009, 02:28 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
Part II
Part II
ID:	242690   Click image for larger version
ID:	242691   Click image for larger version
ID:	242692   Click image for larger version
ID:	242693   Click image for larger version
ID:	242695   Click image for larger version
z168 likes this.
G-AMG is offline
post #3 of 14 (permalink) Old 06-07-2009, 11:58 PM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 111 Post(s)
What a cool tool that compression tester is! Nice work again G! Nice 6000 series Hazet as well.
dlafever is online now
post #4 of 14 (permalink) Old 06-08-2009, 01:09 AM
Timsecwide's Avatar
Date registered: Jul 2008
Vehicle: 500 sec 32v widebody
You do realise that thats the cam advancer you are pulling of at the front of the engine and wont disable a thing
apart from that well done
Tim
Timsecwide is offline
post #5 of 14 (permalink) Old 06-08-2009, 03:26 AM
~BANNED~
Date registered: Sep 2004
Vehicle: 1996 S600 1991 560SEL 1995 S500 2009 S550
i love your timeless safety precautions. you work like a pro.
cool is offline
post #6 of 14 (permalink) Old 01-21-2012, 01:05 PM
Date registered: Jul 2006
Vehicle: 1997 E420
G-AMG
Sorry to exhaust an old thread. I was looking and found this DIY which is closer to the engine in my E420. I have a copy of the WIS. Both your write-up and the WIS say to check the electrode "gap" to the specified value of 0.8 mm. I was wondering if you could explain what that means.
Also in your other M113 thread, you specified what amount to torque the coil packs. There is no recommended torque value on my WIS for installing the 3 bolts on each cover or the 2 screws on each coil. If there is none listed what do you use? 8 Nm like the M113?
Thanks,
MH
HirschMandarin24 is offline
post #7 of 14 (permalink) Old 01-21-2012, 07:41 PM
aboynton's Avatar
Date registered: Jun 2005
Vehicle: 93 500SEL DOA - PARTING OUT, 08 CLK350 Cab -DOA, '05 CLK500 Cab (hers), '10 Razor Elec Scooter (his)
Location: Northern California's Great Central Valley - Meth Capital of USA
Originally Posted by HirschMandarin24 View Post
G-AMG
Thanks,
MH
Electrode gap is the spark plug gap. You get a little feeler gauge and measure the gap and adjust to appropriate measurement.
Don't fuss too much about torque values on the coil packs. Tighten until snug, then another 1/4 turn or so to tighten. It's not that important. Just don't leave it too loose so it will rattle loose and not too tight to crack the thing.
Sent from my Autoguide iPhone app
aboynton is offline
post #8 of 14 (permalink) Old 01-24-2012, 06:18 PM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
G-AMG
Dude!
Not exhausting anything!
Yes, Electrode Gap. You need a Metric Gaping tool. Only a few bucks.
Sorry, in the first pic on https://www.benzworld.org/forums/g-cl...ange-m113.html
shows the tool. It is merely a L-Shaped calibrated wire you run through the gap and adjust the gap until there is slight resistance on the wire.
And your second question: No there is no torque value required on the M119 Coil pack. All the fastener does on the M119 is hold the "Spring" Retaining device down... the "Spring" is what is actually compressing the Pack.
Now, the M112/M113 is a different design. The bolt actually TRAVERSES the center of the coil pack..... thus, too much torque, you could "crush" the coil pack.
Hope this helps.
G
G-AMG is offline
post #9 of 14 (permalink) Old 01-24-2012, 09:14 PM
The andrew's Avatar
Date registered: May 2008
Vehicle: 1993 W140 500SEL Black/Black, 12014 Ford Fiesta ST Blk/Blk
Great! My compression across all 8 is about 185-190PSI
A healthy engine indeed!
The andrew is offline
post #10 of 14 (permalink) Old 01-25-2012, 08:23 AM Thread Starter
G-AMG's Avatar
Quoted: 154 Post(s)
Ja. That is great! 12 Bar for you! That is AFTER your overhaul?
G-AMG is offline
PHOTO DIY-ENGINE MOUNT REPLACEMENTS G-AMG W210 E-Class 125 07-09-2018 02:12 PM
Photo DIY- Rear Engine/Transmission Mount Replacement G-AMG W140 S-Class 9 01-16-2016 12:57 PM
Photo DIY- Engine Mount Replacements G-AMG W140 S-Class 21 11-28-2008 07:13 PM
Photo DIY- Engine Oil Change G-AMG G-Class 1 05-25-2008 02:06 PM
Engine Compression questions - running high compression nav_bhandher W126 S,SE,SEC,SEL,SD,SDL Class 0 06-21-2007 08:34 AM
