Photo DIY- M119 Engine Compression Check - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 01-25-2012, 09:03 AM
The andrew's Avatar
Date registered: May 2008
Vehicle: 1993 W140 500SEL Black/Black, 12014 Ford Fiesta ST Blk/Blk
Originally Posted by G-AMG View Post
Ja. That is great! 12 Bar for you! That is AFTER your overhaul?
I haven't done anything but set the timing and replace the guides...
Regular oil changes, premium fuel, driven gently.
"However, not the the aesthetic masterpiece you might have expected for a billion dollars, but all of them, and this one in particular, justifies it's price through sheer attention to detail." -Jeremy Clarkson
Over 184K and it's sweet!
It MUST have been that leather wrapped dash that got 'er going, what else do you have to offer?
The andrew is offline
post #12 of 14 (permalink) Old 01-26-2012, 12:51 PM
Date registered: Jul 2006
Vehicle: 1997 E420
Dude!
Not exhausting anything!
Yes, Electrode Gap. You need a Metric Gaping tool. Only a few bucks.
Sorry, in the first pic on https://www.benzworld.org/forums/g-cl...ange-m113.html
shows the tool. It is merely a L-Shaped calibrated wire you run through the gap and adjust the gap until there is slight resistance on the wire.
And your second question: No there is no torque value required on the M119 Coil pack. All the fastener does on the M119 is hold the "Spring" Retaining device down... the "Spring" is what is actually compressing the Pack.
Now, the M112/M113 is a different design. The bolt actually TRAVERSES the center of the coil pack..... thus, too much torque, you could "crush" the coil pack.
Hope this helps.
G
Thanks a lot for your help, G.
MH
HirschMandarin24 is offline
post #13 of 14 (permalink) Old 06-20-2019, 05:34 AM
Date registered: Mar 2010
Vehicle: 2007 E220CDI, 1990 300E-24V, 1987 W124 3.6 AMG build 1993 E500 W124, 94 320CE, 1997 W140 S280
Quoted: 208 Post(s)
very nice DIY thankyou for posting!
I am interested in doing a leakdown test on a m119 engine. The results of a compression test can be quite limited. Has anyone else carried out a leakdown test on a m119 motor and if so - what % cylinder air loss did you see?
JC220 is online now
post #14 of 14 (permalink) Old 06-20-2019, 08:34 PM Thread Starter
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320 2011 E350 2016 GLA250
Quoted: 154 Post(s)
i havenít performed on a M119, but here it is for a M272:
https://www.benzworld.org/forums/w21...n-testing.html
G-AMG is offline
PHOTO DIY-ENGINE MOUNT REPLACEMENTS G-AMG W210 E-Class 125 07-09-2018 02:12 PM
Photo DIY- Rear Engine/Transmission Mount Replacement G-AMG W140 S-Class 9 01-16-2016 12:57 PM
Photo DIY- Engine Mount Replacements G-AMG W140 S-Class 21 11-28-2008 07:13 PM
Photo DIY- Engine Oil Change G-AMG G-Class 1 05-25-2008 02:06 PM
Engine Compression questions - running high compression nav_bhandher W126 S,SE,SEC,SEL,SD,SDL Class 0 06-21-2007 08:34 AM
