Gearbox problem :( - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-31-2008, 11:38 PM Thread Starter
Date registered: Feb 2008
Exclamation Gearbox problem :(
Hi guys
I have S 320 1998 , the problem is in the gearbox
sometime wehn i drive it the gearbox never make changing and the RPM goes to more 50-60 without any changing BUT when I stoped the car then I tried again it never changing for 1st it still stops or move too much slowly
but when I turn off the engine and restart it again everything come OK
I didnt hear any sound in gearbox
Just the problem of changing and I could't imagine WHY when I turned off then on everything will be fine ?????
please let me know where is the problem
salem01 is offline
post #2 of 7 (permalink) Old 04-01-2008, 03:52 AM
W140 Moderator
Merc-S600's Avatar
Date registered: Aug 2007
Vehicle: "CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Quoted: 522 Post(s)
Re Gearbox Problems
Hi
Is the car cold when it does the changing like u mention ?
Merc-S600 is online now
post #3 of 7 (permalink) Old 04-01-2008, 08:46 AM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 324 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
what engine and year is your car? this sounds like something the 722.6 would do, becuase the tranny is going in limp home mode (safe mode)
get the codes pulled for the tranny and see what broken mechnical part is causing the limp home mode.
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X166 GL CLass GL63 (///AMG)
Ducati 999 with Termignoni and CF
Former Mercs:
W164 GL class GL450 (sold) - R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (passed on) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is offline
post #4 of 7 (permalink) Old 04-04-2008, 09:46 AM Thread Starter
mmmmmm i don't know actually but it hapens till now 4 times
its 1998 s 320 class
is that natural if the is cold ???
or has a problem need to be fixed ??
Thank you
salem01 is offline
post #5 of 7 (permalink) Old 04-04-2008, 11:18 AM
Haku's Avatar
Date registered: Nov 2006
Vehicle: 1996 S320 (Kuro) 1998 S600 (Weiss)
Quoted: 7 Post(s)
Send a message via MSN to Haku
Thank you
Yes the car will do this when it is cold - if this is happening ONLY when it's cold.
Haku is offline
post #6 of 7 (permalink) Old 04-04-2008, 11:26 AM
bayhas's Avatar
Quoted: 324 Post(s)
from what you are describing, sounds like your tranny is not shifting up or down. check your fluid level and condition, is your tranny leaking?
you indeed have an electronically controlled 722.6, have the codes pulled from your car, and see what is damaged in your car. a bad valve body will cause that, broken primary pump would, low tranny pressure would... etc etc
check your fluid, if its normal, i am almost certain you will have some code in your PCM, so have it scanned.
Garage:
Former Mercs:
bayhas is offline
post #7 of 7 (permalink) Old 04-04-2008, 11:30 AM
bayhas's Avatar
Quoted: 324 Post(s)
Haku, what Salem is describing sounds a hair too severe than the shift delay to me...
Garage:
Former Mercs:
bayhas is offline
gearbox problem Qzyn W163 M-Class 3 12-02-2007 04:40 AM
need help with my sl gearbox problem BANANA General Mercedes-Benz 3 01-22-2004 11:55 AM
need help with my sl gearbox problem BANANA R129 SL-Class 0 01-21-2004 07:03 AM
Gearbox problem nav_bhandher R/C107 SL/SLC Class 1 11-09-2003 07:07 AM
gearbox problem Göran G-Class 2 09-19-2001 02:43 PM
