the evil that lurks under the hood... is really the devil himself - Mercedes-Benz Forum
post #1 of 249 (permalink) Old 05-22-2007, 04:14 PM Thread Starter
Date registered: Dec 2003
Vehicle: 1996 S500 coupe
Quoted: 22 Post(s)
this post is inspired by ackvig and goatman ( https://www.benzworld.org/forums/w140...highlight=evil )
it seriously is the devil himself, waiting to destroy your precious 140's engine
following the footsteps of our friend here who first posted about the unfortunate incident where the little T fitting at the back of the engine broke and necessitated a whole new engine, I went to the dealer today and bought that little bugger (its a dual T fitting.. I will post the pics and DYI guide shortly)
mine did not leak and looked brand new just by looking at it
anyway.. it has 2 big clamps and 2 little ones.. once I undid all the clamps and attempted to take it out, the 2 bigger pipes slid out rather easily and to my complete surprise and disbelief... one of the little pipes (the same one that's known to break), just came loose in my hand... it had cracked/broken previously and it was barely holding on. All this time, the damn pipe wasnt even leaking so if I didnt read about our friend's experience here, I would have never known until it busted on me in the middle of nowhere!!!
This should be a regular maintenance item... should be replaced once every few yrs and if you have a 140 where this item has not been attended to, you need to do this NOW
on a v8, it's very easy to change it.. all you need is a 6mm socket and an extension. Took me approx 15 min to change. If you remove the air cleaner assy., it's a quick job
I will post pics soon .. in the meantime, buy the part tomorrow and replace it
my dealer had it in stock and said they sell them a lot because they break a lot on the 140s
the damn part needs to be made out of Aluminium, or some kind of metal... not plastic.
snik is offline
post #2 of 249 (permalink) Old 05-22-2007, 05:21 PM
Vehicle: 1993 300SEL (Sold) 2007 X5
Quoted: 8 Post(s)
How much is the part and any idea of where it is on the I6 engine? Thanks.
NZ Benz is offline
post #3 of 249 (permalink) Old 05-22-2007, 06:19 PM Thread Starter
Quoted: 22 Post(s)
I paid about $50 cdn from the dealer
stand beside the car.. driver's side (passenger side in your case since your car is RHD)
look at the firewall... right in front of it, you will see a coolant line going into the firewall... follow that line and right in front of it, you will see the TT fitting
I will post pix soon
snik is offline
post #4 of 249 (permalink) Old 05-22-2007, 07:49 PM
Date registered: Dec 2004
Vehicle: 1996 S600 (Sebastian), 1999 SLK230 Kompressor (Tie Fighter)
snik, post them NOW! my Sebastian is in the shop as i type this and my indie needs to do this before he releases my prescious baby back to me! THANKS you are truly a class act!
My Stable:
* 1996 S600 "Sebastian"
* 1999 SLK230 Kompressor "Darth's Tie Fighter Toy"
* 1996 C280 (retired)
* 2011 Audi A6 (wife's ride)
* 2008 VW EOS Turbo Hard Top Convertible (retired)
* 2003 Denali (Big Dog)
* 2003 Envoy (totalled!)
* 2000 Saab 93 Turbo (retired)
aristotled is offline
post #5 of 249 (permalink) Old 05-22-2007, 07:53 PM
Quoted: 8 Post(s)
50 bucks for a bit of plastic connector.....it's alomost enough to make it worth having one made up.
NZ Benz is offline
post #6 of 249 (permalink) Old 05-22-2007, 08:05 PM Thread Starter
Quoted: 22 Post(s)
yes sir.. here are the pics:
Here I am standing in front of the car, and pointing to the part. To the right of my hand, you will see the left spark plug cover (this is on the V8 engine with the air cleaner removed)
This is a pic of the old part while on the car - it's dusty so it looks whitish
I am just holding the new part (the way it would go on) to show you the orientation of the part, so you can visually get an understanding of how it fits:
old broken part and the new one (can you spot the old part )
The little piece came off as soon as I loosened the clamp and pulled on the rubber line just a tiny bit
I have to emphasize.. while this was on the car, it did not leak, and you could not tell that it was broken but it was. When I gave it a gentle pull it came off... it wasnt because I was rough or anything.. I gave it a very gentle pull... it was already broken inside, waiting to pop
go and get this done now... and do it every couple of yrs
on a V8, it took me 15 min. I would imagine it would be considerably longer on a V12. On a straight 6, it should be quick as well as there is a lotta room
snik is offline
post #7 of 249 (permalink) Old 05-22-2007, 09:00 PM
Quoted: 8 Post(s)
Can you please post the parts number as I can't quite read it from the photo I assume it's the same for all cars.
Sorry got it: for those who can't be bothered to read upside down it's: 1408326615
NZ Benz is offline
post #8 of 249 (permalink) Old 05-22-2007, 10:14 PM
miloking's Avatar
Date registered: Jun 2006
Vehicle: Current 1992 - 500SEL, W124 - 1989 230E (sold)
i wonder if it could be fabricated from aluminum or something, i realy dont want to replace it and keep worrying about it again in few years....and as NZBENZ says fro $50 you could have it made for sure its just bit of pipe thats all....
miloking is offline
post #9 of 249 (permalink) Old 05-23-2007, 01:05 AM
Benzkid27's Avatar
Date registered: Jan 2007
Vehicle: 1994 S500
I'm gonna have to look into this and see if im up for a new one.I was able to make out the part number.I have the ability to read things up side down
Benzkid27 is offline
post #10 of 249 (permalink) Old 05-23-2007, 11:53 AM
Date registered: Feb 2003
Vehicle: 600SEL
Quoted: 85 Post(s)
My car 92 600sel (91 production) has aluminum TT there.
myarmar is offline
EGR = the devil P4olom W123 E,CE,D,CD,TD,TE Class 12 03-29-2007 07:28 PM
The greatest trick the Devil ever pulled... Naomilla2.0 Off-Topic 28 01-25-2006 12:05 AM
Better the Devil you Know???? BathSLK R171 SLK-Class 9 08-18-2005 08:30 AM
My Red Devil is almost out from the paint shop! MONDAY! Jason R170 SLK-Class 4 02-17-2002 09:35 AM
Is "Jason's Red Devil" here? question for you.. Dave Schmidt R170 SLK-Class 4 01-22-2002 02:57 PM
