spark plug BOSCH F8DC4 vs F8DC0 - Page 2 - Mercedes-Benz Forum
post #11 of 171 (permalink) Old 02-21-2016, 07:04 PM
LogicalPosition's Avatar
Date registered: Nov 2013
Vehicle: '99 S420 111K
Quoted: 325 Post(s)
Send a message via AIM to LogicalPosition
Could It Be
Originally Posted by abataineh View Post
I ordered plugs from MB dealer for my W210 and they were Champion plugs
Something about NJ? Ha, ha, ha...just kidding.
W210 and W201? <<scratching head>>
Decades ago(admittedly) I saw several instances where Champions, A/C Delco, and Autolite suffered from broken insulation. Apparently installers were cracking the insulation and as it got hot it broke?
Also, Bosch offered the removable copper/aluminum tops exposing the threads on the top of the plug which was the industry standard for the German wire/plug configuration.
LogicalPosition is offline
post #12 of 171 (permalink) Old 02-21-2016, 07:40 PM
Quoted: 325 Post(s)
Yttrium
Ok, you fellas got me looking up this spark plug stuff.
Bosch F9DOC is the plug recommended for my 99 S420, M119.
It's a Yttrium plug.
There are Beru and Champions listed also. I'd didn't look them up for the Yttrium application.
https://en.wikipedia.org/wiki/Yttrium
"You are what you drive!" Big Al
There is perception, and then there is reality.
'99 W140 S420 111K, '94 W124 E320 124K (sold! Repurchased 10/3/16, sold 11/17)
'14 BMW X3 XDrive 38K,
'13 BMW X1 28K (Traded). '11 BMW 328i XDrive 19K(Traded)
'08 Subaru Outback Limited Wagon 56k (Traded)
'83 BMW 320is "Sport" (48k, sold! converted to EV!)
'87 190E W201 (sold!) '85 Audi 5000 (sold!)
'76 250 W114 (sold!) '72 280 W114 (sold!)
'67 200D W110 (bartered) '62 220 W111 (buried)
post #13 of 171 (permalink) Old 02-21-2016, 08:41 PM
Date registered: Jun 2015
Vehicle: 1999 S500; W140.051
Quoted: 173 Post(s)
I was wrong about the plug change in '98 for M119. Change was to laser welded platinum electrode. Design principle was same as with iridium ... reduce electrode area for arc ignition while retaining longevity. It doesn't seem like Bosch grabbed on to iridium for consumer vehicle application, but they have a line of industrial engine plugs using iridium on both electrode & ground.
Interestingly enough iridium has melting point 1200 deg F higher than platinum. NGK was issued a patent for the basic idea of the iridium tipped electrode and/or ground electrode in 1988. I think the really dark art to the use of this matl is in the method of joining metals with widely differing melting temps.
LogicalPosition likes this.
daidnik is online now
post #14 of 171 (permalink) Old 02-22-2016, 04:17 AM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
Quoted: 478 Post(s)
@LogicalPosition , The dealer didn't give me options to choose from. I told them i want to order plugs for my W201 and they gave me the plugs inside Mercedes logo box which had Champion plugs in it.
For my W140 S320 I ordered some plugs from Clark and it was Bosch plugs inside the MB packaging.
benzitch and LogicalPosition like this.
hamada128 is offline
post #15 of 171 (permalink) Old 02-27-2016, 04:17 PM
Date registered: Dec 2015
Vehicle: W140 1994 S500 USDM base model, before facelift
Quoted: 74 Post(s)
As long as all ignition specialists are already on this topic...
I'd like to pick you brain a little:
I just replaced rorors and distributor caps and all spark plugs. Specified bosch plugs no resistors, as recommended. old plugs were ok, but a bit darker then they should be, looks like they were changed once over 60k. 2 plugs were not tight for some reason. I had slight hesitation on idle before and i still have it now
So, any ideas what may cause it? Engine is running fine on any rpm but idle, if ac is on hestitation is not there. It is very minor, you can hear slight miss every 30-40 sec.
Bosch spark plug wires are purchased and going in next... But still is it going to fix it? And if not what a hell is it? Engine sounds perfect pulls hard, no any other issues.
I did not check the gaps on spark plugs, but they come preset usually. At the time i did not know about increasing a gap to 1.0, is it worth trying?
Ah also, i drive and then stop, hesitation will not be there, as well as if i race the engine it will give me couple minutes of clean idle. If it sits ide for some time, then i can feell it, again very slight.
Alter is offline
post #16 of 171 (permalink) Old 03-01-2016, 10:20 AM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 118 Post(s)
Originally Posted by LogicalPosition View Post
Ok, you fellas got me looking up this spark plug stuff. Bosch F9DOC is the plug recommended for my 99 S420, M119. It's a Yttrium plug. There are Beru and Champions listed also. I'd didn't look them up for the Yttrium application.
Where are you looking this up? In the Mercedes/dealer EPC, or in Bosch catalog?
Mercedes offers factory plugs from several different manufacturers, typically Bosch, Champion, and Beru. There are different part numbers for each but are all interchangeable. Depending on price and availability, you may receive any of the 3, unless you ask for a specific brand / part number.
Yes. This is easy and free. See if there is any improvement with the gap at 1.0-1.1 mm.
It is very unlikely that new wires will fix it. However, you can measure the resistance of your old plug wire ends/boots. Spec is ~2000 ohms and if they are within about 20% of spec they are ok. If you find any that are very high (say, 5k-10k ohms, or higer) that could be part of your problem. Assuming your new M119 wire set is the type with orange plastic plug boots and light gray wire, be VERY careful laying the wires into the plastic X-tray. The gray insulation is fragile and tears easily. This won't affect performance if it tears, but you'll feel better if you don't damage them in the first place. The X-tray has numbers on the bottom which tell you how to route the wires, they should all fit neatly in place. But the aftermarket wire lengths probably won't match OE, so you'll need to get creative to make everything fit nicely...
Dave M.
Boise, ID
1997 E420 - 159kmi (
1994 E420 - 150mi (
1994 E500 - 115kmi (
1992 500E - 179kmi (
gsxr is online now
post #17 of 171 (permalink) Old 03-01-2016, 11:44 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1088 Post(s)
Nice and neat Dave
Jayare is online now
post #18 of 171 (permalink) Old 03-01-2016, 11:48 AM
abataineh's Avatar
Date registered: Jun 2012
Vehicle: 2001 E320 Brilliant Silver/Charcoal 2002 E320 Special Edition
Quoted: 5 Post(s)
Beautiful! !!
abataineh is offline
post #19 of 171 (permalink) Old 03-01-2016, 02:38 PM
Quoted: 74 Post(s)
Thank you for the suggestion and pictures!
Is there anything else which can cause the hesitation?
Alter is offline
post #20 of 171 (permalink) Old 03-02-2016, 07:27 AM
gsxr's Avatar
Quoted: 118 Post(s)
Do you have a hesitation under load, while accelerating? Or just the intermittent idle hiccup when warm, every 30 seconds or so? One other thing is the engine mounts... if they are not recent, they are probably toast.
gsxr is online now
Bosch changed spark plug heat range imon_2nd W124 E,CE,D,TD Class 2 01-06-2007 10:33 PM
Bosch spark plug question benzwag W126 S,SE,SEC,SEL,SD,SDL Class 31 12-14-2006 10:20 AM
replacement spark plug wires sets - Bosch or Karlyn? andrew TD W140 S-Class 2 01-26-2006 01:51 PM
Bosch Spark Plug wires daveward General Mercedes-Benz 3 01-03-2006 12:10 AM
I am looking Bosch Platinum +4 spark plug for my 98 slk230, anyone can show the porduct # ondiet R170 SLK-Class 3 04-19-2002 11:34 PM
