spark plug BOSCH F8DC4 vs F8DC0 - Page 16 - Mercedes-Benz Forum
post #151 of 171 (permalink) Old 02-14-2018, 11:12 AM
Nate D. Rector's Avatar
Date registered: Aug 2016
Vehicle: 99 s320 member since 2009 fastest time 14.6 1/4 mile nitrous.
Quoted: 108 Post(s)
something I read,looking in europe for sparkplugs,I find they run a colder spark plug there.Must be for the autobahnn. I might try them instead of my champion 12ycc,and go for c11ycc
Nate D. Rector is offline
post #152 of 171 (permalink) Old 02-14-2018, 11:22 AM
gsxr's Avatar
Vehicle: Buncha W124's
Quoted: 118 Post(s)
That is correct. For street use in USA, don't use colder plugs. If you are running NOS, or entering the Mojave Mile, then a colder plug would be a good idea.
anziani likes this.
gsxr is offline
post #153 of 171 (permalink) Old 02-15-2018, 09:44 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 2 95 320TE's, 02 S500
Quoted: 1090 Post(s)
Originally Posted by Zamanumer View Post
15 pages later, I am still confused if its okay to install R plugs.
I guess id find non R ones :P
No reason to install resistor plugs. The correct Bosch plugs are less than $2 ea.
Sent from my XT1080 using Tapatalk
gsxr likes this.
Jayare is offline
post #154 of 171 (permalink) Old 02-16-2018, 07:02 AM
Date registered: Oct 2017
Vehicle: 2006 cdi, 1993 500e
Quoted: 45 Post(s)
Arm Strong
I didn't realize anyone made a resistor-free iridium plug?
I like the cheap copper cores- I pull them to inspect and they are cheap enough to replace. Probably last up towards 60,000 miles, but I ussually toss new ones in @ 30,000 and the old ones look good.
Michael
Legodude is offline
post #155 of 171 (permalink) Old 02-16-2018, 07:14 AM
gsxr's Avatar
Quoted: 118 Post(s)
These do not exist (at least not for M119 applications, if at all).
Exactly correct!!
gsxr is offline
post #156 of 171 (permalink) Old 02-16-2018, 07:24 AM
thisisntchris87's Avatar
Date registered: Sep 2014
Vehicle: 1994 S500 Coupe
Quoted: 122 Post(s)
If I may add something to the great spark plug debate:
I'm using genuine Mercedes plugs, specifically part number 003-159-68-03. My coupe is running splendidly with them. They're French made with the proper flat base, had 14F-8DU4 printed on them which seems to mean they're Beru.
thisisntchris87 is online now
post #157 of 171 (permalink) Old 02-17-2018, 03:51 AM
Quoted: 108 Post(s)
Some plugs unscrew so that you can make a resistor free plug.Seen it on youtube.You unscrew it,dump out resistor material,then replace with copper part same size.
post #158 of 171 (permalink) Old 02-17-2018, 03:21 PM
gsxr's Avatar
Quoted: 118 Post(s)
Those are the current plugs sold by MB dealers, since the OE Bosch with the Star logo went NLA in late summer 2017. And yes, they are Beru plugs. Also available on eBay.
Jayare likes this.
gsxr is offline
post #159 of 171 (permalink) Old 03-19-2018, 02:28 AM
Zamanumer's Avatar
Date registered: Jan 2014
Vehicle: 1983 W126 280S, 1988 W124 300CE, 1991 W124 E300, 1995 W124 E200
Quoted: 42 Post(s)
BOSCH - H7DC0
they arrived and installed
ID:	2399194   Click image for larger version
ID:	2399202   Click image for larger version
ID:	2399210   Click image for larger version
ID:	2399218   Click image for larger version
gsxr likes this.
If the doors of perception are cleansed, everything will appear to man as it is. Infinite.
Zamanumer is offline
post #160 of 171 (permalink) Old 03-22-2018, 09:01 PM
Arm Strong's Avatar
Date registered: Nov 2016
Vehicle: 1991 r129.066 500SL, 1968 W108.014 280SE
@Zamanumer .
All you have to do now is to get the same fuel they sold back in the 90'! This spark plugs will not run good on the fuel they sell now, did you know that?
Zamanumer likes this.
Arm Strong is offline
Bosch changed spark plug heat range imon_2nd W124 E,CE,D,TD Class 2 01-06-2007 10:33 PM
Bosch spark plug question benzwag W126 S,SE,SEC,SEL,SD,SDL Class 31 12-14-2006 10:20 AM
replacement spark plug wires sets - Bosch or Karlyn? andrew TD W140 S-Class 2 01-26-2006 01:51 PM
Bosch Spark Plug wires daveward General Mercedes-Benz 3 01-03-2006 12:10 AM
I am looking Bosch Platinum +4 spark plug for my 98 slk230, anyone can show the porduct # ondiet R170 SLK-Class 3 04-19-2002 11:34 PM
