ASR and ABS Lights stays on?!? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-15-2006, 12:15 PM Thread Starter
Morpheus's Avatar
Date registered: Jul 2005
Vehicle: 78s 240D&300D (w123s)
Quoted: 5 Post(s)
Send a message via AIM to Morpheus
Exclamation ASR and ABS Lights stays on?!?
Hello! My step dad has a 1993 300SE. He has a problem because the ABS and ASR light comes on out of no where while driving or starting the car and it just stays on. He wants to know what the problem is and how to solve the problem. Thank You.
Morpheus is offline
post #2 of 5 (permalink) Old 06-15-2006, 01:09 PM
mbnz230's Avatar
Date registered: Jun 2004
Vehicle: 2004 clk500
check out the brake lamp switch, that could cause the lights to come up. depress the brake peddel all the way while starting the car, if the lights didnt come on thats most likely the switch. if you let go it will come back on. i just had the same problem awhile back. 17.98 for the part. easy fix.
mbnz230 is offline
post #3 of 5 (permalink) Old 06-15-2006, 01:31 PM Thread Starter
Morpheus's Avatar
Quoted: 5 Post(s)
I apply the brakes first then I turned on the car while holding the brakes down, and both lights stayed on, with the engine running!?!
BTW: Where is the brake switch located in the car?
Morpheus is offline
post #4 of 5 (permalink) Old 06-15-2006, 05:45 PM
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
do the lights come on without the car moving at all??
I would be inclined to check all the fuses, including the ones in the coffin box,
Torque isn't cheap
Merc600sec is offline
post #5 of 5 (permalink) Old 06-15-2006, 09:36 PM
Date registered: Dec 2004
Vehicle: 1996 S600 (Sebastian), 1999 SLK230 Kompressor (Tie Fighter)
Cool
For some time i've had my abs/esp/ads lights all come on at the same time until recently when someone suggested starting the auto, then turn the steering wheel all the way to the left and then all the way to the right and the back to center....i did....all of the lights immediately went out and haven't come back on for several days!
but....he also suggested that if this continues to happen, then it very well may be the steering angle sensor and may need to be replaced. i'm sure it's not an expensive sensor.
good luck!
My Stable:
* 1996 S600 "Sebastian"
* 1999 SLK230 Kompressor "Darth's Tie Fighter Toy"
* 1996 C280 (retired)
* 2011 Audi A6 (wife's ride)
* 2008 VW EOS Turbo Hard Top Convertible (retired)
* 2003 Denali (Big Dog)
* 2003 Envoy (totalled!)
* 2000 Saab 93 Turbo (retired)
aristotled is offline
