Level control struts NLA - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 08-13-2019, 02:42 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1966 200 1979 300TD 1991 560SEC Metris (1991 300TE-24, 1983 300SD, 2000 C280 in the family)
Quoted: 33 Post(s)
Hello All,
I am planning some suspension work on my 560 SEC and in pricing out parts, I noticed that the rear struts for a W126 with level control are not available new or aftermarket (also, of note to some W123 wagon ones are NLA as well).
My question is, has anybody had any experience refurbishing these? Assuming no abuse, the only part that would experience wear is the strut seal and the ball joint.
Granted, they are very long lived, and don't have many moving parts, but I have had to replace a couple in the past that were leaking. I also suspect the ball joint at the end probably has a finite service life as well.
Any insight appreciated.
Thanks,
John
jrogosich is offline
post #2 of 25 (permalink) Old 08-13-2019, 04:03 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 848 Post(s)
This may fit:
https://www.ebay.com/itm/mercedes-be...IAAOSwVZBdEC1S
There are 3 o-rings inside that if replaced should fix them. There is also a nylon ring but I do not know if that is critical to be replace. The M-100 and W116 forums you can find how to take them apart.
I have not rebuilt them myself yet, but have a couple that I am going to do in the next couple of months. (W116 model)
rumb is offline
post #3 of 25 (permalink) Old 08-13-2019, 08:00 PM
Date registered: Jul 2011
Vehicle: '87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
Quoted: 51 Post(s)
I'm facing the same situation--I have a 133,000mi 560 SEL parts car, and need replacement struts/shocks on my 320,000mi SEC. I'm hoping the SEL struts will fit the SEC; the parts numbers are different.
DrewPT is online now
post #4 of 25 (permalink) Old 08-14-2019, 08:25 AM
alydon's Avatar
Date registered: Mar 2004
Vehicle: 84 500SEL AMG, 90 560SEC AMG, 85 500SEC AMG Widebody
Quoted: 79 Post(s)
All SLS struts for the W126 are the same (SEL or SEC). Have never seen a W126 SLS strut rebuilt. Now that they are NLA, I suppose that may become a trend. Not sure how to open them up. The bottom ball joint was the usual cause for replacement in past - the joints wear out and causes a knocking sound.
alydon is offline
post #5 of 25 (permalink) Old 08-14-2019, 11:01 AM
Date registered: Nov 2018
Vehicle: 1991 560SEL
Quoted: 121 Post(s)
lesguy is offline
post #6 of 25 (permalink) Old Yesterday, 06:32 AM
alydon's Avatar
Quoted: 79 Post(s)
Ok, so there is a process for rebuilding the hydraulic ram, but no solution to failed ball joints on the bottom of the ram. MB used to sell just the ball joint separately many years ago. I am guessing someone like Top Hydraulics may venture into rebuilding SLS rams, but the nagging issue of the lower ball joint may still be an issue.
EDIT - sent a note to Top Hydraulics to ask if they have ever considered rebuilding these rams since they are now NLA
luckymike likes this.
alydon is offline
post #7 of 25 (permalink) Old Yesterday, 11:26 AM
Quoted: 121 Post(s)
general question: Lets assume one has a leaking SLS ram. They take the car into their local Mercedes dealership for repair. What then happens?
lesguy is offline
post #8 of 25 (permalink) Old Yesterday, 12:10 PM
alydon's Avatar
Quoted: 79 Post(s)
They will tell the owner the part is NLA and won't service the car. It is what it is. The only option the dealer could offer is to install conventional shocks, which may require a change in rear springs as well.
alydon is offline
post #9 of 25 (permalink) Old Yesterday, 12:17 PM
alydon's Avatar
Quoted: 79 Post(s)
reply from Top Hydraulics
Name:	Top Hyd Reply.JPG
alydon is offline
post #10 of 25 (permalink) Old Yesterday, 03:15 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 581 Post(s)
Time for one of our knowledgeable members to step forward...
luckymike is online now
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
