Stereo Amplifier - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 08-11-2019, 04:03 PM Thread Starter
Stutz's Avatar
Date registered: Oct 2009
Vehicle: 1999 500SL, 1988 SEC
Quoted: 257 Post(s)
Stereo Amplifier
My 126 has a newer Alpine unit in it which also has blue tooth capabilities. I changed all the speakers over to a set of focal's in the doors, and a set in the back as well as some new tweeters in the dash. I also ran all new 18 gauge wire throughout. For now I am simply using the Alpine units amplifier. However, whomever had my R129 (which is just let my sister take back to Denver) has a similar system but with to 750 watt amplifiers. Needless to say the one with the amplifier is much more crisp and clear. So are there any good ideas for amps, where to put them (don't be smart) where they will not be noticed? Remember I have a pretty stock car that I do go to shows with (on Thursday taking it to Mercedes financial at their request) so it has to be somewhat circumspect. I was thinking of mounting it behind the rear seat or something like that. Any suggestions about product or placement welcome (No I don't listen to rap!) I also know the farther I go from the head unit the more wire I have to run. Two amps are double the wire so........
Stutz is online now
post #2 of 15 (permalink) Old 08-11-2019, 04:10 PM
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 569 Post(s)
if u just have 4 speakers one 4 by whatever would suffice. JL makes nice amps, im sure focal does too. There are so many brands out there. Placement just attaching it to rear back of trunk works. I have 2 on my sel . Or upside down under rear deck is an option
vdubpower is offline
post #3 of 15 (permalink) Old 08-11-2019, 05:03 PM Thread Starter
Stutz's Avatar
Quoted: 257 Post(s)
Have six speakers, with a crossover. Two in the rear, two in the doors and two tweeters in the dash.
Stutz is online now
post #4 of 15 (permalink) Old 08-11-2019, 05:33 PM
vdubpower's Avatar
Quoted: 569 Post(s)
your lucky to have door options my 85 hasnt
post #5 of 15 (permalink) Old 08-11-2019, 06:17 PM
Gregs500sel's Avatar
Date registered: Jun 2019
Vehicle: 85 500SEL
Quoted: 7 Post(s)
I've been wondering if anyone has done something about that, speakers in the 85 are tiny and could use some help.
Gregs500sel is offline
post #6 of 15 (permalink) Old 08-12-2019, 04:07 PM
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
Quoted: 53 Post(s)
Amplifier placement
If the amplifiers you are considering are of normal size, the only real option is to place them somewhere in the trunk.
Fortunately, the cable conduits in our cars are really good and it's easy to thread power, signal and speaker wire without too much trouble.
I've tried a few different placements of amps in my vehicle.
I'm currently running the amps in my spare wheel well.
Name:	DSC_2556 Low Rez.JPG
ID:	2534028   Click image for larger version
Name:	DSC_2723 Low Rez.JPG
ID:	2534030   Click image for larger version
ID:	2534032   Click image for larger version
ID:	2534034   Click image for larger version
Name:	DSC_7082 - Low Rez.jpg
Name:	Cables, Driver's Side.jpg
ID:	2534038   Click image for larger version
Name:	Cables, Passenger Side.jpg
ID:	2534040   Click image for larger version
ID:	2534042   Click image for larger version
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline
post #7 of 15 (permalink) Old 08-12-2019, 06:12 PM Thread Starter
Stutz's Avatar
Quoted: 257 Post(s)
Excellant advice. Winter will be the time to take things aprt and research the issue. Since I already have the speakers and they are wired it will be somewhat easier. Too bad the battery is not on the trunk. That would make the monster wires easier.
Stutz is online now
post #8 of 15 (permalink) Old 08-12-2019, 08:13 PM
AxelWulff's Avatar
Vehicle: 1990 SEC
Quoted: 53 Post(s)
That would have been nice, but fortunately there is a hole in the firewall right next to the battery. Perfect for a power cable to the trunk.
Name:	DSC_1736 Low Rez.jpg
ID:	2534128   Click image for larger version
Name:	DSC_7106 Low Rez.JPG
Regards,
Axel
post #9 of 15 (permalink) Old 08-12-2019, 11:06 PM
vdubpower's Avatar
Quoted: 569 Post(s)
thats a lot of amps
whats the rest of your system look like
post #10 of 15 (permalink) Old Yesterday, 05:44 AM
John350's Avatar
Date registered: Nov 2014
Vehicle: 1990 350SDL, "Grandpa's Roadster" Project Car
Quoted: 823 Post(s)
thats a lot of amps
Ha! You made a pun!
John350 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Colin Spencer
