420SEL SLS Rear Strut Bushings - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-14-2019, 08:14 PM Thread Starter
Date registered: Sep 2010
Vehicle: 1986 Aust. spec 420SEL, U1700L Unimog ex.ADF
Quoted: 5 Post(s)
Hi there,
I have an Aus-Spec 420SEL which has SLS, I'm struggling to work out what rubber bushings make up the strut tops on the rear suspension (to fix banging in the rear).
The best I have found is a diagram (not my exact model) that shows two different rubber bushings on-top of one another, is this correct?
The p/n's listed are:
115 326 16 68 (lower)
115 326 17 68 (upper)
Are these BOTH meant to be there, or are they just new-versus-old part numbers?
Input would be really appreciated!
Cheers,
Aaron.
STOIE is offline
post #2 of 8 (permalink) Old 07-14-2019, 09:11 PM
luckymike's Avatar
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 583 Post(s)
No, I don't think the bushings go on top of each other, though it can look like that in parts diagrams. One is on top of the body sheet metal and one is underneath, like a standard shock mounting.
My question is which bushing goes on top and which goes underneath? I can't find an answer on this for my 560SEC and SEL, either. My part numbers are 1153261668 and 1143260068.
The manual (for my cars) says 1668 is the top bushing. But 1668 is physically larger than the 0068 and the picture in the manual shows the larger bushing on the bottom.
I personally think the larger bushing should go on the top but really would like a definitive answer.
luckymike is online now
post #3 of 8 (permalink) Old 07-14-2019, 10:10 PM Thread Starter
Quoted: 5 Post(s)
I'm guessing these two P/N's would be the ones that apply to my 420SEL with SLS also then.
I plan on changing both, but just need the right P/N's.
STOIE is offline
post #4 of 8 (permalink) Old 07-14-2019, 10:27 PM
luckymike's Avatar
Quoted: 583 Post(s)
Where did you get that 1153261768 number? I can't find it anywhere to help confirm.
post #5 of 8 (permalink) Old 07-14-2019, 10:29 PM Thread Starter
Quoted: 5 Post(s)
Don't really know to be honest, like a 280SEL I think.
STOIE is offline
post #6 of 8 (permalink) Old 07-14-2019, 10:31 PM
luckymike's Avatar
Quoted: 583 Post(s)
I think you'd be safer using the numbers from my 560 or getting the numbers off your existing parts.
post #7 of 8 (permalink) Old 07-14-2019, 10:44 PM Thread Starter
Quoted: 5 Post(s)
Existing parts... ha!
Those rubbers are non-existant lol
But yes, I'm pretty sure a 420SEL vs a 560SEL both with SLS, the suspension is virtually the same.
STOIE is offline
post #8 of 8 (permalink) Old 07-14-2019, 10:46 PM
luckymike's Avatar
Quoted: 583 Post(s)
If they're literally non-existent, you're out of luck. But if they're just old, you might be surprised at how you can still read the number, even on an old, compressed part!
