Center vents non OP - but check this out - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-12-2019, 12:00 AM Thread Starter
vdubpower's Avatar
Date registered: Nov 2003
Vehicle: 1985 500sel and 500sec 2012 E63 1989 Porsche 911
Quoted: 554 Post(s)
so the other week, i noted that the center vents went out....i had my pods sorted 14 yrs ago so figure its the usual culprit again this time.
i usually always drive with the EC button depressed on LOW fan just to get some air in the car, and i had noticed that i wasnt getting any except the sides and near winshield
SO today, randomly the center vents starting working again...but check this out
as i am accelerating they work until i hit 1500 rpm, then they die.....if i coast, and rpm drops, they come back on....aint that a bitch
and not check this...sometimes randomly today if im over 2000 lets say im on freeway, at steady speed, the centers come back on...crazy
has anyone ever had this issue.
1985 500SEL Euro Nautic Blue - A Classic Beauty
1985 500SEC Euro Nautic Blue
1989 Porsche 911 Carrera Silver Anniversary Edition
2012 E63 AMG Iridium Silver - Performance Package
vdubpower is offline
post #2 of 8 (permalink) Old 07-12-2019, 08:10 AM
gogi's Avatar
Date registered: Jan 2008
Vehicle: 1991 560sec. 1969 280SL
Quoted: 236 Post(s)
Yes. When rpms are low there is more vacuum in the intake manifold. You have a vacuum leak probably one or both of the pods. On mine it was only the one on the left of the two pods that work in tandem behind the glove box or passenger air bag. Mine also had a leak at the defroster pod too. Both those can be done through the same access point. Replacing just the diaphragms in the fresh air pod fixed the problem but I did fresh and defroster pods at the same time labour time 1.5hrs at the most.
AxelWulff likes this.
gogi is offline
post #3 of 8 (permalink) Old 07-12-2019, 09:32 AM
Date registered: Apr 2014
Vehicle: 1984 300SD
Quoted: 9 Post(s)
How easy is it to access.the middle vent and floor vent pods? Mine only blows out the defrost and an eek out the middle. Nothing out the floor.
Sent from my ONEPLUS A6000 using Tapatalk
CGeromi is offline
post #4 of 8 (permalink) Old 07-12-2019, 11:49 AM
gogi's Avatar
Quoted: 236 Post(s)
Pull a vacuum on all seven ports of the gang of seven manifold behind the passenger side center consuls vertical carpet panel. That way you can identify exactly which vacuum actuators are faulty.
gogi is offline
post #5 of 8 (permalink) Old 07-12-2019, 11:59 AM
Vehicle: 1984 300SD
Quoted: 9 Post(s)
Can I get new ones or have to rebuild old?
CGeromi is offline
post #6 of 8 (permalink) Old 07-12-2019, 12:50 PM
gogi's Avatar
Quoted: 236 Post(s)
Iím not sure if all part numbers are available but yeah you can get new. AutohausAZ has them I think for $85 each. I just rebuilt the two that leaked cost me a total of about $30
gogi is offline
post #7 of 8 (permalink) Old 07-12-2019, 01:05 PM
Vehicle: 1984 300SD
Quoted: 9 Post(s)
How did you rebuild them?
CGeromi is offline
post #8 of 8 (permalink) Old 07-12-2019, 01:42 PM
gogi's Avatar
Quoted: 236 Post(s)
I ordered the diaphragms from Performance Analysis. But first you you need to know how many you need. But if you want to orderer for all your pods then you will buy nine of them. I just ordered what I needed. The delivery charge is about nine bucks. The package comes with instructions. Just use a small blade screw driver and be gentle.
Good luck.
jsebastian likes this.
gogi is offline
